What is the no of convergence amplifier ic - Televison & Video
    President:
  • 788 Answers
Having the Model number and the Make of your television will help greatly.
thanks
Posted on May 13, 2010
The tv is turning red and green and shadowing everywhere in those colors
this is a convergence amplifier fault. Have to replace convergence amplifier ic's they are bad. Also several low ohm resistors in yoke return circuits are open. open an account at hitachiserviceusa.com and input your model no. in search field.
Jan 07, 2010 | Hitachi Televison & Video
How to adjust the picture, convergence is wrong on a 55'' prejection TV
If you cannot move or align the colors with the customer convergence menu, one or both of the convergence amplifier IC's have gone bad. These IC's are located on a common heatsink on the left side board looking from the back. It would probably be best to have a shop check it out for you. This repair can lead to a pretty in depth convergence adjustment. Fairly complicated. Thanks for using fixya.
Dec 13, 2009 | Philips Televison & Video
What is STK ICs?
STK-series integrated circuits are amplifier IC's that are most often used in projection TV sets as convergence output amplifiers. When these or other convergence parts fail, the three color images no longer line up correctly on the screen.
Jun 17, 2009 | Panasonic PT-56WXF95 56" Rear Projection...
JVC AV-56WP30 Convergence Problem
Hi
You have defective convergence correction amplifier IC replace the STK IC...
Thanks!
Jun 12, 2009 | JVC AV-56WP30 56" Rear Projection...
The picture on my tv is warped
Hello jbvail86,
This problem you are having is a convergence problem. The convergence amplifiers are malfunctioning. Both Amplifiers need to be replaced. You will need a schematic, and a multimeter to check the voltages on the pins of the convergence amp ICs. Once you find that the ICs are bad you will need to de-solder them and the biasing resistors and replace the ICs and resistors. The schematic will help you find the proper resistor values.
I hope this helps
Thank you,
Shuttle83
http://www.electron-age-technologies-llc.com
Dec 03, 2008 | RCA D52W20 52" Rear Projection HDTV-Ready...
COLOUR NOT ALLIENED COMES IN SHADIND AND SCREEN NOT ALLIINED
Hi
bad color and bad color alignment is cause by defective convergence correction circuit amplifier IC. Replace the convergence IC to back the color to normal.
Thanks!
Likha
Sep 23, 2008 | Televison & Video
Samsung HCN4226 Convergence IC Problem.
The problem is likely to be the digital convergence board that generates the convergence signal that is amplified by the output ICs.
Jun 22, 2008 | Samsung HC-R4755W 47" HDTV
Convergence
Seems like you need to replace its convergence amplifier ICs (2 pcs). The convergence amplifiers are attached vertically to two heatsinks. When replacing these, remember to reapply thermal paste (white paste for better heat transfer from IC to heatsink). If you don't replace these, over time other components will be affected.
Aug 26, 2007 | Akai PT4298HD Rear Projection Television
Where can I get parts?
STK392-110=CONVERGENCE IC USE TWO FOR REPLACECEMENT PART= WWW.bdent.com Product Details: The STK392-110 is a convergence correction circuit IC for video projectors. It incorporates three output amplifiers in a single package, making possible the construction of CRT horizontal and vertical convergence correction output circuits for each of the RGB colors using ust two hybrid ICs. The output circuit use a class-B configuration, in comparison with the STK392-010, realizing a more compact package and lower cost. www.partstore.com
Apr 12, 2007 | Panasonic PT-56HX41 56" Rear Projection...
Televison & Video Logo
Top Televison & Video Experts
Electro Med Services...
