Lg intellowasher wd-8013f is very noisy
My lg intellowasher wd-8013f is very noisy when spinning. i have taken off the belt from the motor and turn the drum manually. It is still noisy when turning freely so i suspect the bearings
  • Washing Mach... Master
  • 713 Answers
It will definitely be the bearings and possibly the spider as well. the spider is attached to the bowl. the spider is made of aluminum and they corrode all the time. open the door to the machine and grab hold of the steel bowl, has it got movement on it. if it has then the spider and bearings are faulty, also the main shaft seal will need replacing.nearly every time i went to an LG 8013f that was noisy it was the bearings and or spider. hope this helps. please reply 4 more help. good luck.
Posted on May 13, 2010
  • widgeamedoo Sep 25, 2011
    I have just pulled apart my WD-8013F with the same noisy spin cycle problem. Rotating the drum manually you can hear the bearing noise. I dismantled the machine and found one of the bearings (immediately behind the drum) has had water in it, is rusty, and makes noise when it spins. There is a place on the internet selling spare parts called bigwarehouse.com.au but they want around $50 per bearing (that is a bit expensive in my opinion), The problem is the seal was also no good and the shaft that the seal runs on was also corroded and requires replacement, this shaft is attached to a three pronged device called a spider which bolts to the back of the drum, the bolts that hold this in are corroded and cannot be removed. The cost of this job properly is starting to get prohibitive and I am looking at a new machine. I purchased a replacement bearing ( 6206 2RS which is motorcycle wheel bearing for $7.50) and fitted it an reassembled the machine, it it all running sweet for the time being but it will only be a matter of time before the bearing fails again. Changing the bearing was not a simple job and requires a number of tools, the rusty bearing made the drum difficult to remove, and getting the retaining clip back on the door seal during re-assembly took me a while. The bearing I replaced was the same physical size but slightly different from the one that I removed in that it had tight plastic seals where as the bearing I removed wasn't sealed. My machine was 6 years old.
2 Suggested Answers
  • 30 Answers
SOURCE: lg intellowasher wd-8013f is very noisy
You suspect right.
It is a complete strip down job. I have just finished mine.
taking apart and reassembling is not too dificult.but you need to make up a tool to remove and replace the bearings which are two different sizes. It consists of a lenghth of studding, bolts and washers.
Download the manual from LG.
Good Luck
Posted on Mar 18, 2010
My washing machine turns on but will not start. It will only make a click sound then another click sound. Please help
Your timer swicth is defective or fuse inside but check first the cord if it not broken before you go to fuse and timer
Jun 15, 2012 | LG Washing Machines
I do not know how to undo the child lock on my LG intellowasher Model no.WD-8013F
The Child Lock can be activated and deactivated by pressing and holding both the Temp button and the right Option button simultaneously for 3 seconds as shown below.
Let us know if this procedure fails to deactivate the Child Lock feature for further troubleshooting and repair advice.
Aug 23, 2010 | LG Washing Machines
Drum will not spin
You will need to change the rotor and stator,
Jul 21, 2010 | LG WM1814CW Front Load Washer
LG Intellowasher 7kg, Model WD-8074FHB - noisy spin cycle
You are right!
Bearings have to be replaced. Replace with the same type and design. All the bearings connected to the washer center shaft has to be replaced at the same time with new set.
Replace the water seals also connected to this. Check the shaft where the bearing sits, for any abrasions or metal damage.
Check the bearing housing also. While carrying out these repairs check the drive belt also. If needed replace it.
If you are happy with the machine outer body and other aspects repair it and re-use it.
Apr 07, 2010 | Washing Machines
You suspect right.
Good Luck
Mar 17, 2010 | Washing Machines
LG WD 8013F drains then won't spin
  • Hi,
  • Try these:
  1. Test the lid switch
  2. Test the timer control
  3. Test the centrifugal switch
  4. Test the water level switch
  5. Inspect the motor coupler
  6. Inspect the drive belt (belt drive only)
  7. Inspect under the washer for soot (clutch)
  8. Test the motor
  9. Inspect the pulley
  10. Test the transmission
please rate my suggestion...
May 21, 2009 | LG Washing Machines
It doesn't let me choose a cycle - doesn't work
the control pannel faulty needs replace ment. press the cancel/pause button and clean button together to reset the board.check it if gets reset then it will work orther wise replace control board.
Mar 07, 2009 | LG Washing Machines
Front loader noisey
Hi.
If you remove the belt and turn drum by hand, it should revolve freely and without any noise.
If it is noisy or feels stiff, then you proabably have main drum bearing failure.
Could be expensive to put right
Nov 21, 2008 | Hotpoint Ultima WF860 Front Load Washer
Wm noisy
drum bearings, check and investigate, remove drive belt and then rotate, if still noisy then yes its the drum bearings, if the noise stops when the belt removed the motor bearings are faulty costly repair on most models, sorry oh there is also the possibility there is something lodged within the drum cavity between the lining and the drum casing
Sep 25, 2007 | LG WD-16110FD Front Load Washer
Washing Machines Logo
1,026 people viewed this question
Top Washing Machines Experts
Gerry Harvey
Gerry Harvey
