Question about Sony FD Trinitron WEGA KV-21CL10 21" TV
No display after on the tv
Te .. te..te ..te souund inside the tv casing
Check horizontal transistor , if it is ok check the regulators 5v and 9v , check all diodes at the secondary side of the power supply
good luck
abebe
Posted on May 12, 2010
Can a tv working normally after been stuck by lighting
In most cases no, depends on level of surge. I've seen cases where a surge came in through an HDMI cable and take out the HDMI port on a TV, everything else worked. I've seen cases where a surge damaged multiple boards on a set. So again it depends how how big of a surge, and whether the surge comes in through the power cable or an video/audio input.
Sep 07, 2012 | Toshiba 40WL753B Regza Wl 40 Inch Full Hd...
Marantz 7300 pcm flashing no audio
Try upgrading your firmware and do a reset on the receiver. If this does not help your problem, then you might have an HDMI issue or a bad DSP chip.
Aug 02, 2012 | Audio Players & Recorders
I have a Sony KP-48S35, Rear Projection TV and the picture goes on and off but the audio works fine. When I first turn the TV on, it takes around minutes for the picture to even come on.Which meens for...
i would say the bulb is on its way out and needs changing. on the back there is a hatch with one screw remove the screw and unclip the bulb holder, then pull out by the handle part number is on the bulb housing or the tv case.
May 23, 2017 | Sony KP-48S35 48" Rear Projection...
Not reading my disks
the eye in your game drive mite be dirty or scratched. if thats the case tr y to buy a can of air duster (caned air) and spary it inside the drive when its open. make sure the can is level or youl get liquid from inside te can prayed into your drive. if the diskes stillc ant be read then your drive mite be messed up. if so you will have to take apart your consel and replace te game drive. this will void the warenty if any and. for instructions on how to take apart you consel there are some videos on y ou tube that can assist you.
Dec 14, 2009 | Microsoft Xbox 360 Console
I have a toshiba 52hm95 DLP tv and i am trying to get the souund to run through my tuner. i attached the digital audio out on the tv to the "digital audio in" in my tuner and i am not getting any sound....
More than likely you need to set the tuner up for this. On your DUI "Digital User Interface" you will need to go into the digital in assignment and select the digital input, you should have the option's of, coax, optical or analog. Select COAX and you should get sound.
Jun 23, 2009 | Toshiba 52HM95 52" HDTV Projection...
HDMI to DVI-D conversion problem. Not in compliance?
It souunds like te TV is having problems with the streaming data being applied Most plasmas with DVI connections were actually designed for PC type input signals  Unfortunately the TV's input may not be able to stand up to the stream of signal the DVD or cable box wants to display. You can try and lower the output of both devices to 720P Good luck to you
Feb 17, 2009 | Televison & Video
Please Help !!!!!!!!!!!!!!!!!!!
1. hit menu, use right arrow and select 'Audio'.
2. hit menu use down arrow to scroll down and select 'Speakers'
3. hit right arrow to scroll thru options, select 'on'
4. hit menu 3 times to save and exit back to picture
Jul 28, 2008 | Panasonic CT-36D32 36" TV
Haier 42 inch edtv plasma
Make sure that you haven't pressed input by mistake i.e going onto scart or pc1.gif input press TV on the remote and try this.
also check that the scart cable is fully inserted into the TV as well as the digi box or VCR or what ever.
The control board part number is TV-5210-57 and retails for $214.45 plus shipping and tax. To order please contact us at 1-800-313-8495
Jan 21, 2008 | Haier 42EP24S 42 in. EDTV-Ready Plasma...
Compaq for Evo D300 Motherboard
The manual can be found here. There is a numbered diagram inside. http://www.eserviceinfo.com/downloadsm/5105/Compaq_Evo%20300-500.html Hack
Jul 09, 2007 | Compaq (281946-001) for Evo D300...
Sony FD Trinitron WEGA KV-21CL10 21" TV Logo
111 people viewed this question
Top Sony Televison & Video Experts
Jerry Greenberg
Jerry Greenberg
Are you a Sony Televison and Video Expert? Answer questions, earn points and help others
