Question about Numark iDJ2 - DJ iPOD Mixer Docking Station
Cant use external hard drive when hooked up nothing happens
  • 6,831 Answers
Hello
Okay , so there are some steps to figure out what is wrong with your external.
Firstly , if your computer makes a sound when you plug in your external , go to Start-Control Panel-Administrative Tools-Computer Management-Disk Management , and see if your external drive is listed here with your local drives. If it is listed , right click on the drive and change the drive letter to make it appear in "my computer".
If your drive does not make a connection sound when connecting to your computer and also does not show up , please follow the next step.
Remove the hard drive from the casing if possible and install it in your computer case or another external case.If the drive works , the problem is with the casing and you can ignore the drive.
Now , if the problem is with the casing , there are still 3 possibilities.
  1. The USB cable between the drive and the computer may be damaged.
  2. The circuit board which connects your drive to the interface of the external may be blown.
  3. The power supply (if applicable) may have a blown transformer.
The latter is the easiest to diagnose , does your external light up at all when you plug in the power? If not , then this is probably your problem. On the bottom of the adapter is a label which you will be able to use to have a new adapter made at your local electronics shop and this will cost about $30 max. They will also be able to test the adapter with a clamp meter to see if this is really the problem and this should be free.
The second component you want to test is the USB cable. If you have a printer , swop out the cables and see if your printer functions normally. Most externals use the same connector so you should be able to test it in this manner. If the cable works go on to the last step. If the cable is defective , replace it with a new one which you can find for about $10 at most electronics and chain stores.
The last component to test is the circuit board. This is a bit of a grey zone as you probably won't be able to spot the blown component unless it failed really badly. With the casing already opened , locate the external's circuit board and check to see if you have any blackened components or fluids leaking from some components. If all the other components of the external worked perfectly , then this is the faulty part. It is not really economical to replace the circuit as most of the time it is out of production by the time you need to replace it and it still costs a lot even if it is available so if your drive is working perfectly when connected via sata or IDE on your computer , the best is to buy a new casing and place your old drive in the new casing.
A casing costs about $50 and you could get it at most tech shops and big chain stores like Best Buy.
I hope this solves your problem and please reply if you need more help.
Kind Regards
Andrea
Posted on Sep 29, 2010
Cant eject my toshiba external drive
Is it listed in Computer? if so, right click, scroll down to Eject. If that fails shut down computer, unplug external drive USB and pry the door open or disassemble the case.
Dec 25, 2012 | Toshiba E05A050CAU3XW Canvio Hard Drive...
I cant open my fujitsu siemens external hard drive, 3.5", storagebird, 35EV840. Tried uninstalling and reinstalling but still no luck. Not visible in 'My Computer'. Please help.
try this one
turn off computer and ext drive
keep drive plugged in but not powered
turn computer back on and stabilize
power up ext drive
does windows see it now?
May 31, 2012 | Fujitsu Computers & Internet
I have connected my iomega model number LDHD-UP the light comes on but nothing happens and i cant locate it on my competer ive tried 3 diffrent usb connectors that i know work but nothing happens it worked...
is it an enternal hard drive or and external hard drive if it is the internal hard drive you must put all the wires in hard and properly the wire must be tight and in the external hard drive you must check if your usb in in the working slot and if the cable is connected.
Jun 05, 2011 | Computers & Internet
PC won't boot some external devices attached/on
some computers need to have all external drives unplugged before they will boot up because it cant tell the difference between which drive to boot from.
hope this helps.
Apr 30, 2010 | Computers & Internet
Can't view my files
device manager, right click, scan for changes
Mar 15, 2010 | Computers & Internet
Computer will not recognize one 500 external hard drive- nothing wrong with connections- other external hard drives are fine. I have tried everything
What OS are u working on? some old ones dont recognize this big hard drives, cant remmember the limit but it was around 300. Try updating ur OS if u are working on windows xp(get it to Service pack 3). I think this problem was fixed at sp2, but just to be sure.
Nov 02, 2009 | Western Digital 500GB My Book World...
There..but not!
didn't fix it..can't ..on disability..don't have money for your plan..I thopught yous were a tech support that we could get help period..not one of these where people always had to pay first. too bad sometimes people weren't just helpful...us older ones on disability could use that.i have a put to gether computer..no extra money,,and was just in need of help...and everything always costs but sorry...no its coneccted but not there and isnt working as my book so i have no idea. thanks but i cant. Diane
Jan 08, 2009 | Western Digital My Book Essential 500GB...
Computer not seeing the external Hard drive
try the drive on another pc - if you sill cant see it, you may have had drive head crash in the new drive and that is a write off.
Aug 16, 2008 | SimpleTech 250GB USB2.0 7200 RPM External...
Numark iDJ2 - DJ iPOD Mixer Docking Station  Logo
118 people viewed this question
Top Numark Audio Players & Recorders Experts
 Grubhead
Grubhead
Colin Stickland
Colin Stickland
Are you a Numark Audio Player and Recorder Expert? Answer questions, earn points and help others
