Question about Little Giant Submersible Sump Pump 2760 Gph, 3/10 Hp, 1 1/2in., Model# 506158
2E 38N two year old pump runs for twenty minutes or so now and shuts off or shorts out. I reset gfi and can get another twenty minutes shortly thereafter. Noticed the green rubber/plastic housing has worn through on the bottom. Do I need to replace pump?
    Problem Solver:
  • 19 Answers
I would, if its kicking out the gfi that means the integrity of the electrical components of the pump are compromised.Either a cord leak or seal leak, buy a new one, cheaper than fixing it
Posted on May 18, 2010
2 Suggested Answers
  • 119 Answers
SOURCE: 2E 38N two year old pump runs for twenty minutes
replace the pump, sounds like it is over heating and shuting down so it doesnt burn out.
Posted on Apr 19, 2010
1993 Eagle Vision.. Car runs great... for 15 min. Then falls on its face..try to start..barley runs...rapidly pump gas pedal car will run barley. shakes and chokes and sputers... shut the car down for...
Could be fuel pump is going out. Its getting hot not working properly and when it cools down it works right again for a short period. Ive seen this happen several times.
Oct 05, 2013 | Eagle Vision Cars & Trucks
I have a 5 year old heat pump (electric) Home is 5 years old and is very energy efficient with 6 inch outside walls. Do I have a problem as the air will run for 5 minutes and shut off for 5 minutes and...
One thing you might check is to make sure there is not cold air blowing across the thermostat from one of the vents. I've seen this many times make the thermostat short cycle.
Some less expensive thermostats may be programmed to short cycle. If you have instructions available for the thermostat, try to find information or the "heat anticipator". It may have an adjustable setting.
Jun 30, 2011 | Heating & Cooling
The refrigerator run loud for twenty minutes or so then it stops for ten minutes and starts running loud again
If the noise is coming from the back of the fridge, it could be the compressor is dying. Its cycling and over heating shutting off then trying to restart a short time after once the thermal overlaod resets. You hould call a service tech sooner than later.
Apr 04, 2010 | Kenmore 20.6 cu. ft. Top Freezer...
Polaris booster pump runs for minute but quits. Tries to restart
The motors are usually dual voltage and factory connected for 230V. Are you sure it is properly wired and set for the correct incoming line voltage?
Aug 24, 2009 | Polaris Pb4 - 60 Booster Pump
Unit is 2 years old, worked fine. now it trips the GFI after a few sec's running. no other things are pluged into the line at all.
Motor windings are overheating and expanding inside the potting seal causing an intermittant short to ground. Need to replace the pump.<!-- from fixya rte -->
Jun 27, 2009 | Intex Krystal Clear Model 635 Pool Filter...
10 year old air compressor cuts off at 10psi
hello, if you plug the compressor into a none gfi outlet does the compressor still cut off ? it could be one a short in your compressor causing the gfi to trip our your gfi has a ground try the compressor in a diffrent outlet, when you use any other electronic equipment on the gfi does it still trip ? if you use the compressor in a diffrent outlet that's none gfi this should sholve your problem most likely a bad gfi outlet or the compressor is drawing to much amp's.
Mar 28, 2009 | Craftsman 1 Hp, 4 Gal. Air Compressor
Little Giant Submersible Sump Pump 2760 Gph, 3/10 Hp, 1 1/2in., Model# 506158 Logo
143 people viewed this question
Top Little Giant Plumbing Experts
Mack Baxter
JOHN LAPIER
Gary Nitowski
Are you a Little Giant Plumbing Expert? Answer questions, earn points and help others
