hi im josh in cebu phils.may i help you? Friend try to do this solutions it will help you.
Problem: You Type One Key, and a Different Character
Appears Onscreen
This is an interesting problem with four possible causes:
You really didn't type what you thought you did. Look at your
fingers. Now look at the screen. Now look at your fingers again. Is everything
the way it should be? Good!
If you have a programmable keyboard, you or someone else might
have reprogrammed the keys so that they don't do what they normally do. Refer to
the keyboard's manual for instructions about how to reprogram the keys.
If you're in a specific software program, some programs let you
reprogram the keyboard from within the program. When you exit the program, your
keyboard should be back to normal.
It's possible your keyboard is broken. Try hooking another
keyboard up to your system and see how it works.
Problem: Your Keyboard Isn't Responding Properly
What do you do if you hold down a key and it repeats too fast
or too slow? Windows lets you make adjustments to your keyboard via the Keyboard
Properties dialog box.
Just open the Control Panel and select Keyboard, and then
select the Speed tab. Adjust the Repeat Delay and Repeat Speed settings to your
liking, and then test your settings by clicking in the blank box and holding
down a key. After you have things adjusted to your liking, click OK.
Problem: Your Wireless Keyboard Isn't Responding
Properly
This is the same issue as with a wireless mouse—your batteries
are getting weak. Replace the batteries in your wireless keyboard to put things
right.
It's also possible that you're experiencing interference with
some other wireless device. Try moving your wireless receiver or the offending
device, or turning off the other device while you're at the computer.
Just try these solutions friend. Hope I helped you Good luck
