Question about LG LRE30755 Electric Kitchen Range
Film between layer of glass on LG range
I have streaks and a film on the layers of glass on my LG range door. Sears Canada says its purely cosmetic (?) and a service technician will call to advise whether or not this is covered under warranty. The range is 6 months old, and I wonder whether the seal between the layers of glass is defective. If this is not covered, I will return the range to Sears for a full refund, as I am concerned with running a high temperature self-cleaning cycle with a non-intact seal on the glass. Thanks tech17!
  • Nogosears000 Mar 29, 2008
    Thanks!
    Why didn't my old range, which was also self cleaning NEVER develop a film even after 20 years?
    President:
  • 1,314 Answers
Its not covered by warranty and it is cosmetic all ranges do this after a while its caused by the vents in the door for self cleaning i doubt the seals are defective as all ranges do this i get this quite a bit i can tell you how to disassemble it to clean but its more of a hassel than its worth for real because it will just do it again dont call a repair person because he will come over and charge you to tell you what i just did so what do you want to do reply ande let me know im here to help
Posted on Mar 29, 2008
Window tint removal
Here's a link on tint removal.
Jun 08, 2013 | Home
Outside door glass has slid down
Sounds like the door gasket/seal has pulled away from the rest of the door frame and layers. You might be able to take the door off of the hinges, and cabinet, and take apart the layers to readjust.
Dec 26, 2012 | Frigidaire 30" Self-Cleaning Freestanding...
I have a color lazer jet 2600n and the film on front cover that moves is dirty and i get steaks on my printing is there a way to clean it to see if they go away
The part you are talking about is called the transfer belt. This part can't be cleaned because the surface is coated with a photoconduction layer that will be further damaged by touching it. It sounds like the film layer is already scratched and that is why you are getting the streaks on the pages you print. The part number you need for the replacement transfer belt is: RM1-1885-020 You can do a Google search for sources or check with Office Depot, Staples or Office Max.
I hope this helps, if so please rate our solution.
CCL_Tech
Corporate Computer
www.ccl-la.com
Sep 15, 2010 | HP Office Equipment & Supplies
The front top inside glass on the door ofre my Gemini has some drip streaks. How do I clean it?
you have to take the door off
I DO NOT RECOMMEND CLEANING IT
there are 3- 4 layers of glass you have to take apart
so there is a big risk of breaking something
but if you dare
open the door
look at your hinges
you will see a tab
pull them down
open door
and lift upwards the door will come out of the socket
remove all the screws and you will be able to access the glass
good luck
Feb 10, 2010 | Maytag MER6769 Gemini Electric Kitchen...
Hp dual layer dvd burner with light scribe doesnt recognize the dual layer disc as dual layer
You may have to install some kind of DVD burner software such as Nero burning ROM to burn dual layer DVDs. the default windows CD burner does not recognize dual layer disks. You can also use this free software for burning dual layer disks
http://infrarecorder.org/
Dec 04, 2009 | Computers & Internet
Streaks of color when scanning film
you need to clean of reflection glasses of lens so if you are handy on it then take off fron scanning glass and take out glasses and clean the out with clean cloths.
and put them back.
note: if you are not aware of it please do not mess up with them because it will be more annoying.
good luck
please rate all answers.
Apr 06, 2009 | Epson Perfection 4490 Film / Flatbed...
Window tint Glue Removal
Materials:
  • Warm sunny day
  • Tarp
  • Large plastic garbage bag
  • Undiluted Ammonia
  • Windex (a glass cleaner)
  • Paper towels
  • Fine steel wool
  • Razor blades
Tips:
The difficult thing about removing tint is that most film is constructed of two layers of tinted polyester. When you try to peel the film off the glass, the top layer will usually pull right off leaving the second layer behind. This second layer will not peel off, it will just flake and tear like a price tag.
Step 1:
To over come separation between layers you must soften the adhesive so that both layers peel at the same time. This is very important, if you peel the just the top layer, you may as well just use razor blades as there is no way to peel the second layer off without picking at it for a few hours. You MUST try to peel both layers at once.
NOTE:
You are more than likely to damage one or more of your defroster lines, when this happens, the cut line will not work anymore. Some cars have radio antennas mounted alongside the defrosters made of the same material. If you damage these, your radio antenna will not work! Be careful! Taking it to a tint shop to be done greatly increases the odds of saving the lines, but even a tint shop can not promise to save your lines, sometimes the film is just to far gone.
Mar 27, 2009 | 2003 Honda Accord
How a cd drive works
A intense laser burns "micro-holes" in the film to represent the data...
A low intensity laser reads the spaces the high intensity laser left behind because the film casts back a reflection
DVD's work very similar; one low intensity layer and one high intensity layer. Furthermore, the laser makes much better use of the surface space so the DVD can hold more data
Nov 28, 2008 | Computers & Internet
TyTn II unresponsive touchscreen
Try to calibrate the touch screen. Also clean it with a soft cloth. But calibrating it should help the film when you tap the screen.
Apr 16, 2008 | HTC TyTN Smartphone
LG LRE30755 Electric Kitchen Range Logo
196 people viewed this question
Top LG Kitchen Ranges Experts
JP Services
JP Services
Dan Webster
Dan Webster
Oloyede Monsuru
Are you a LG Kitchen Range Expert? Answer questions, earn points and help others
