Question about Mackie SWA1501 Subwoofer
I have a hole in my mackie sub How can I get a
I have a hole in my mackie sub How can I get a replacement speaker cone our speaker to replace the old damaged one
  • 4,234 Answers
See the link below to either locate a dealer close by or to contact Mackie directly for the parts.
Dan
Link: http://www.mackie.com/support/
Posted on Jan 12, 2011
Mackie 15 inch replacement speaker
To determine polarity of a sub, take a 9 volt battery and two one foot pieces of wire. Connect each wire to each terminal on the sub. Then touch one wire to one side of the 9 volt battery terminal and the other wire to the other side terminal. If the subs cone pushes upwards that is the correct way to hook it up(in phase which is normal). If the subs cone pulls down, is is 180 degrees out of phase. I hope that this answers your question.
Jan 14, 2014 | Insignia Car Audio & Video
How do I hook up passive subs to my board
Sub outs needs an active speaker.
An active speaker have a built in amplifier and preamplifier.
For a passive speaker it needs an amplifier.
Oct 01, 2012 | Mackie 2404-VLZ3 Mixer
SUB WOOFER CONE SPLIT LOGITECH Z5500 REPLACEMENT CONE
you should just buy a replacement speaker and install it, replaceing the cone would not be cost effective, in fact you could buy a better speaker and get better bass out of the sytem, try www.martinsoundproducts.com they are in Cleveland and sell many great speakers in all sizes.
Mar 19, 2011 | Audio Players & Recorders
I have a set of technics SB-5000a speakers. one of them the 10" sub is blown. there is no resistance accross it. the cone is in good shape so i think it is the driver. normally you can unscrew the...
if there's NO resistance, see if the lead running to the cone (coil) has broken.
If so, you might be able to solder it back on and save the speaker.
Sometimes they separate at the terminals, sometimes at the cone.
If it separated at the cone, you may need to peel back a bit of paper to get to the wire underneath, and scrape the enamel coating off the wire so you can solder to it.
Otherwise, it's off to your local audio mart to buy a 10" whoofer at the same or higher wattage and same impedance. Take the old one with you to make sure the screw holes align too! (although that's not 100% essential as you can always drill new pilot holes wherever the screw holes aare....unless the screw holes have a metal insert)
If you did have to peel back some paper to do the repair, reinforce the torn area with toilet paper and fingernail polish. Use several layers as you don't want the movement of the whoofer to rip apart your solder joint or any more of the cone.
Mar 15, 2011 | Audio Players & Recorders
Hercules XPS 210 sub problem. distorted sound
I think you've just answered your own question. It sounds as if you've coned the sub woofer. Meaning you've fractured the bond between the edge of the speaker body with the speaker cone. Or overheated the voice coil and it's distorted and not getting free movement. Excuse the Pun but it "sounds" like you need a new speaker as a replacement. If it's a particularly expensive speaker it can be reconed. A check of the Net for someone close to you will find a company who recones them. If it's a cheaper one then a replacement would be in order.
Apr 21, 2010 | Audio Players & Recorders
I have dropped one of my mackie srm450 speakers and i need a replacement woofer.. where can i get one?
If the cone is damaged, it is possible to get it 're-coned'. If you can find a shop that does this type of speaker repair.
Otherwise, call around music stores (by that I mean places that sell musical instruments and PA gear) and see if they sell/sevice Mackie. If you are comfortable taking the old woofer out, just order the part and DIY.
It is not critical that the woofer is an exact replacement (doesn't have to be a Mackie speaker), the important things are:
1) it fits and screws back into the speaker cabinet
2) it is electrically similar to the original (same impedance 4 ohm or 8 ohm) and wattage rating
Feb 06, 2010 | Mackie SRM-450 System
I have a set of mackie sr1530 what can i replace the midrange driver with
My background is live audio and was a tour manger and sound engineer for over 22 years
A couple of months ago I bought a pair of 1530's for $450. They were a bit dirty and had spider webs all over.
I cleaned them all up but was not happy with Mackie's open dust cover design on the mid. When I would slightly depress on the cone one could hear scratching. (it would later turn out to be debris, the coils were in good shape)
The mid speaker in part of the horn-mid flare and can not be reconed.
I my hunt to find a replacement I went as far as ordering a RCF recone kit from Legacy Sound Services but they went bankrupt before they could deliver my kit.
After another search I ended up buying two Eminence LA6-CBMR 6.5" speakers as their there specs and outside diameter of the frame seemed to be a good fit. (this was after I had removed one of the cones from it's hi-mid flare and measured the opening)
When the arrived they slide in perfectly leaving about a 1 mm gap. After removing the magnet from my old rear cover I purchased eight #8 x 3" screws.
I gently tightened down the screws and was ready for my test.
I was amazed side by side the eminence was much smoother around 1.5 khz
Note: the Mackie mid is 5.9 ohms and the eminence is 6.9 ohms and is 150w
One issue is that the new speaker sits about a 1/4" farther back than the original.
I don't have a realtime analyzer but over all the Eminence seems to be a great fit.
I did replace the rubber gasket at the base of the mid flare opening, there did not seem to be a noticeable change.
If you like you can contact me at lmcvery@gmail.com and I will send you pictures
Oct 26, 2009 | Bob Mackie SR1530 System
Where to purchase a bracket
Unfortunately there are two standards for the pole diameters. Some of the smaller poles have caps to accomodate the larger brackets. First thing is to measure what you have for poles and the two sizes of mounting holes. Many of the mounting bosses are standard and available online here is an example:
http://www.amazon.com/Speaker-Cabinet-Metal-Stand-Mounts/dp/B0035AJTL8
Sep 19, 2009 | Mackie SWA1501 Subwoofer
My fuse appears to have blown and i havent taking the speacker apart before. the speacker seems to get no power. what should i check for? if it is a fuse, what fuse should i order for it? MACKIE SWA 1501
Hi There, before you go out and buy any cones etc you need to check the 3 fuses that clip onto the main amp board. You can access them by undoing the two screws that are on the top and the bottom of the sub. They have flat large heads and you will need a hex key to unscrew them. If it is one of the fuses that has gone it will either be discoloured as in burnt or you will see the metal inside has split. Simply replace these with a new fuse and hey presto you should be back up and running. If you need any parts for the sub or fuses then www.LondonSpeakerShop.com will be able to supply them (that is if you're in the UK). Hope this helps. Grant (from www.LondonSpeakerHire.com)
Mar 20, 2009 | Mackie SWA1501 Subwoofer
Replacement subwoofer
1st, if you want a new speaker(just the sub, not the cabinet), ask Mackie for the nearest dealer.
2nd, If you want to have the speaker reconed, I can recommend :
Central Florida Speaker
714 W. Smith
Orlando,FL 32804
407.423.6566
They do good work.
Nov 14, 2008 | Mackie HR824-MK2 System
Mackie SWA1501 Subwoofer Logo
185 people viewed this question
Top Mackie Audio Players & Recorders Experts
 Grubhead
Grubhead
Are you a Mackie Audio Player and Recorder Expert? Answer questions, earn points and help others
