Question about Cameras
Memory card I have a power shot S5 IS what memory cards are compatable?
  • chezo Jan 17, 2009
    i have put a sd adapter card in my camera but when i turn the power on, the light comes on but nopicture or control over the camera i.e. can't turn the camera off need to take the batterys out.
  • 477 Answers
The camera takes a SD memory card if you have one that is not working you can try to format it with a computer that has a memory card reader and see if that fixes it or try to format it from the camera under the setup menu. Eather way some camera format process and block struckure is diffrent so a memory card needs to be formatted for each camera so work fine between each other and some don't.
hope this helps.
Posted on Mar 28, 2008
What memory sticks do i need
Quoted from the technical specifications available on the Sony website UK. http://www.sony.co.uk/electronics/cyber-shot-compact-cameras/dsc-h300/specifications Storage Media Internal MemoryApprox.55MB Compatible Recording MediaMemory Stick Duo, Memory Stick PRO Duo, Memory Stick PRO Duo (High Speed), Memory Stick PROHG Duo, Memory Stick Micro*10 , Memory Stick Micro (Mark2)*10 , Memory Stick XC-HG Duo, SD Memory Card, SDHC Memory Card, SDXC Memory Card, microSD Memory Card*10 , microSDHC Memory Card*10 , microSDXC Memory Card*10
Mar 26, 2015 | Sony Cyber-shot DSC-H300 Digita Camera -...
Is the SDHC memory card compatible with the Canon Powershot S5is Camera?
Yes, the S5 IS is compatible with SDHC cards. You can use them freely.
Nov 27, 2010 | Canon PowerShot S5 IS Digital Camera
I cannot get my canon power shot s5 is to transfer pictures to desktop
Try NOT connecting your camera to your computer.
The best way to download pictures from your camera to your computer involves removing the memory card from the camera and plugging it into a card reader (either built-in to the computer or connected via USB or FireWire). This is likely to be faster than connecting the camera to the computer, and won't run down your camera's batteries.
Once the card is plugged in, it will appear to your computer as a removable drive. You can use the operating system's drag&drop facility to copy pictures from the card to the computer's hard drive, the same way you copy any other files. Or you can use ZoomBrowser or any other photo cataloging program.
Sep 28, 2010 | Canon PowerShot S5 IS Digital Camera
No Memory Card message on Canon S5 IS
There are several possible causes for "memory card locked", "memory card error", or "no memory card". Some include trying to use of a 4GB SDHC card with an older camera made before SDHC format came out. Others include problems with the switch on the side of the card, and the switch internal to the camera. The problem may also arise from simple formatting problems if the card has never been formatted in the camera (note that this will also erase the card). Troubleshooting tips for this problem may be found at this link.
Jun 05, 2010 | Canon PowerShot S5 IS Digital Camera
Is a PNY SDHC 4 GB Memory Card compatible with a Canon PowerShot A530 camera? The card currently in the camera is not a HC card.
I think the maximum size card you can use in the power shot is a 1Gb card unless nes firmware has been istalled to allow 2Gb card.
Using large capacity cards also delays the write recovery time. So if you are trying to capture moving objects , often you get one shot and then it takes almost 20 seconds to recover for the next pic. Too late for most things that move
hope this was of some help
V
May 09, 2010 | PNY 4GB microSD High Capacity Mobile Media...
What battery do I need
The battery for the PowerShot G3 is the Canon BP-511A.
Mar 26, 2010 | Canon Accessory Kit (ACCS) Battery Case...
Can I use a 4GB SDHC memory card in my Canon Power Shot SD450 Digital ELPH camera?
If not you'll most likely get a "card error" message.Check with manufacturer for compatible memory.
Sep 22, 2009 | Canon Cameras
New San Disk memory card not working
vebhat,
Make sure the little slide on the SD card is in the right position, and if it's a high capacity SD it might not be compatible with your camera...
randy320sgi
Jan 09, 2009 | Canon PowerShot SD600 Digital Camera
Memory card
Hi - no, the DSC-P7 isn't compatible with Memory Stick Pro, only original Memory Stick, meaning you're limited to 128MB/stick. Having said that, the P7 is only a 3.2MPixel camera, 128MB will hold quite a few pictures, even at full resolution.
Oct 26, 2007 | Sony Cyber-Shot DSC-P7 Digital Camera
Cameras Logo
99 people viewed this question
Top Cameras Experts
Are you a Camera Expert? Answer questions, earn points and help others
