Question about Welding Tools
My airco dipstick 160 just powered down I was welding au with tig at the time help please
  • 2712 Answers
SOURCE: How to TIG Weld
TIG stands for Tungsten Inert Gas welding. Also called GTAW (Gas Tungsten Arc Welding) and HeliarcĀ® which was Linde's trade name for the TIG process when it was introduced many years ago. The arc is started with a tungsten electrode shielded by inert gas and filler rod is fed into the weld puddle separately. A slower process than MIG, it produces a more precise weld and can be used at lower amperages for thinner metal and can be used on exotic metals. TIG does require quite a bit more time than MIG to learn. It is similar in technique to gas welding.
Posted on Aug 27, 2008
  • 3 Answers
SOURCE: bad tig weld job
Wow you have a lot of variables here. Let's go over some of them.1.AC current 2.100%argon shield gas 3.Check your Tungsten, it must be the recommended 1or 2% and the right size, clean and the tip rounded by meting 4. High freq. turned to continous-not just "START"
5. CLEAN,CLEAN,CLEAN your Alum. with a S.S. brush that has touched NOTHING else in in it's life!
Start here and GOOD luck
Posted on Dec 28, 2008
  • 3 Answers
SOURCE: TIG 250/250
have you checked your regulator if its gone you wont get gas
Posted on Jun 02, 2009
co7196
  • 3433 Answers
SOURCE: i have a airco super hornet welding
Adequate ground?
Power output at receptacles?. Connections are yusually the problem Engine speed 1800 rpms (high idle) good luck
Posted on Jul 26, 2009
  • 176 Answers
SOURCE: lincoln precision tig 225.
Hello; Make sure AC Auto Balancing is Enabled; And when Welding Aluminum Aways use 100% Pure Green Coded Tugsten.Make Sure you dont have 75/25 or possibly if you know for sure your frequency balancing on your machine is working you could possibly have a bad bottle of gas try the bottle of gas on the machine that you say that runs good if it runs good put it back on the 225 if the problems still exist there is something wrong with your machine`s Ac high freqency Auto Balancing.Make sure all connections are good,check tig head for loose connections. Step Up to A 1/8 size tugsten it will carry more heat and gets less contanimated.Every time you stick your tugsten it will run contanimated untill you burn it off or clean it ,if you stick you tugsten go ahead and put a clean piece back in the tig head, Contanimated tugsten wil run dirty for 5 to 20 minutes Untill you BURN it Back Clean !?
Posted on Sep 03, 2011
As soon as I weld tig the arc goes so bright that I cannot look at it. What is causing this ?
normal
the light emitted from a tig arc is many more times intense that normal arc light so you will need much darker lens to view the welding process through
if you are using automatic darkening lens thenhave it checked that it is suitable for tig welding as the dark settings may not be low enough or adjust the settings on the helment to lowest possible
Mar 24, 2018 | ARC Welding Tools
What mig gun is on a Nevada 220BZ Mig Welder
Nevada MIG-220BZ MIG TIG MMA ARC DC Inverter Welder ...
www.ebay.com.au > Industrial > Welding > Welders
eBayNevada MIG-220BZ MIG TIG MMA ARC DC Inverter Welder Welding ... Nevada Welding machine; MIG Torch; Earth Clamp; Electrode Holder; Safety Mask ..
Dec 20, 2015 | Welding Tools
I have ahardly used new Lincoln 225 tig machine. The first time I tried to weld in AC, I starts the ark fine then all of a sudden there is a power surge that blasts from the electrod and blows a hudge hole...
If your starting it on strike turn the power down until you start the power up if you have hf check the gas is coming constantly by listening for the solenoid to open and close when the trigger is pushed and change the settings around on 2 and 4 cycle.
Aug 29, 2017 | Lincoln Precision Tig 225 K2535 1 Ready...
Miller welder 330a/bp it will not weld in D/C straight or reverse no ark but will work in A/C its like there is very low volts I was welding and then could not strike a ark
It's likely that your pedal is the problem. Pull the cover and check it electrically - these have been problematic in the past. You can further troubleshoot by selecting constant output and test the output.
Nov 09, 2011 | Miller SYNCROWAVE 250 DX TIG RUNNER WELDER...
Not forming a continuous bead on the inside of a 3'' carbon steel. set amps at 85/ 90 argon at 10, what am i doing wrong. please help me
I need more info, you are Way too vague.
What type of weld are you trying to do? A Fill weld?
Are you trying to fill a V in-between two pieces of hard steel, (Carbon), that is 3 inches thick?
1. If you are, the electrode should be held at a 90 degree angle to the metal. Straight up, and down.
Moving the electrode too fast will cause a intermittent bead. Slow down. TIG welding takes time. It isn't like ARC welding.
If the electrode burns off to one side, you don't have the electrode in the correct position.
2.Too little heat, (Amperage) will make a 'Cold' weld, and you won't have the penetration that you need. Too much gas (Argon) will do this also. Too little gas, and you'll burn through.
Nov 08, 2009 | Welding Tools
Syncrowave 180 sd. I was welding when it shut
Sounds like a bad thermister on the rectifier or a bad control board.
Aug 12, 2009 | Miller SYNCROWAVE 250 DX TIG RUNNER WELDER...
GIANT 200AMP INVERTER ARC WELDER NO POWER TO THE LEADS
remove the fan from the circuit and try it then, does it weld ok with the fan removed?
Dec 13, 2008 | Inverter 220 Volt Tig Arc Welder
TIG MIG Difference
For certain type of work TIG is required, like welding chrome moly for some racing organizations. Intricate work, like gunsmithing is also well suited to TIG. TIG is used by many auto restorers who prefer a more precise, perfect finish that requires little to no finish work. TIG is most similar to gas welding in technique, so if you've done oxy-fuel welding, TIG should be a natural transition. MIG is required by law and by insurance companies in many localities for structural repair of automotive frames. MIG is also much easier to learn and faster to weld. For doing other types of welding, like sheet metal, it can be a matter of personal preference. For an auto body repair shop or a novice welder, a MIG is a good, practical all-around welder.
Aug 27, 2008 | Radnor A35HP 350A Water Cooled 25' TIG...
How to TIG Weld
Aug 27, 2008 | Radnor Model 105Z55 Push On Smooth TIG...
Welding Tools Logo
96 people viewed this question
Top Welding Tools Experts
Bill Boyd
Are you a Welding Tool Expert? Answer questions, earn points and help others
