Question about Jenn-Air SVE47100 Slide-In Electric Kitchen Range
RELAY BOARD JENNAIR RANGE 1200/693
Since Dec. 2003 we have had 3 relay boards replaced, We are wondering if this part has always been defective since our purchase . As of today we have spent $1340.40 for parts and labour. Is there any way we can recoupe our last cost of for the board $293.48 the previous board was installed l6 months...we have in touch with WHIRPOOL without any satisfaction
    President:
  • 1,314 Answers
Yes check your warrenty i think that bd is under a five year warrenty so the installer if he is an authourized service tech for jen air or whirlpool should not have charged you for the part and any new part you bought should have came with a full year warrenty call cust relations not cust service at whirlpool as they are not the same branch
Posted on Mar 28, 2008
I just got my pump replaced and now i need to reset my samsung washer it still shows nd and stops
The problem is probably in the control panel or water level switch. I just posted a procedure to clean the relay contacts for the pump motor relay. This little relay is on the control circuit board and is not normally customer accessible. But the alternative is purchasing a new control circuit board (which in my case was not available) or replacing the washer. Please refer to my solution for the problem "Drain Pump doesn't work" posted today.
Oct 18, 2014 | Samsung WF206ANS Front Load Washer
One year ago i ran over a fire hose which tore through my exhaust and cat converter. since then, my 2003 honda element began to lose what appears to be, electrical power while driving, sometimes not...
probly gut a blockage in exhaust system-will cause engine pwr loss-dealer didnt kno wat he was doin-typical------the alternator just doesnt generate at full strenth if motor is affectd-------get a diagnostic readout with values at an independent shop sometime
Nov 18, 2013 | Cars & Trucks
AC LIGHT FLASHING,2003 TOYOTA CAMARY..I CAN NOT GET OUT THE (MGCLT) RELAY.HOW DO I GET THIS OUT TO REPLACE?
Hello and welcome to FIxYa. Please allow us to assist you.
The AC MAG CL relay is just a press fit into the connectioin the relay box. It does, however, fit rather tightly. First purchase a replacemet AC Magnet Clutch relay at your nearby Toyota dealership. Tell the parts guy that you want the UPDATED relay, the one that Toyota has produced a technical service bulletin on, they will have the bulletin on file, and will most likely have the new relay on the shelf, this is a common replacement item.
Since you are removing a defective relay, use pliers and grab the sides and pull straight up. Just make sure that the key is not in the ignition when you do this; to avoid any short-circuits.
Thanks for choosing FixYa for assistance today.
Jun 08, 2010 | 2003 Toyota Camry
Microwave does not heat everything else works but does not heat
Same issues here, power up as usual, everything works except it doesn't heat. Usually when the magnetron kicks in, you know it because the unit bogs down from the load, well no bogging here just steady running of the fan. (Manufactured in 2007), do I detect a class action lawsuit in the works? I was fortunate enough to have purchased the extended warranty.
Repair man showed up day one with the most likely culprits (Magnetron & Diode), replaced them both and no help, there goes thanksgiving.
2 1/2 weeks later the tech showed up with a couple of (Micro Switches and a Thermostat), replaced those, ho help.
Now he suspects it the (PWB/PCB Power Control Board), because there isn't any power coming from the board to the tell the huge transformer to power up and sent the required voltage to the magnetron.
We will see when that is replaced if I'm back in business.
Just an FYI folks, if you're going to tinker with this use EXTREME CAUTION, as the transformer could put out upwards in the range of 4,000 volts, not to mention what the mag can do to you, so be SMART and be CAREFUL.
Comments: Dec 16, 2009 - Third time is a charm, the tech replaced the (PWB/PBC) today and we have a winner. That was the problem, either the Power Control Board itself or one of the relays on the board. Replacement was free because it was under extended warranty, but still reasonably affordable at repairclinic dot com ringing in at about $60. So good luck.
Oct 29, 2009 | LG LMV1630ST Microwave Oven
Flashing light on my 2003 Toyota Camry Ac
What is exactly the problem? I don't know which light is flashing I maybe able to help
Aug 11, 2009 | 2003 Toyota Camry
HOW DO I REPLACE MY TURN SIGNAL LIGHTS ON 2003 HYUNDAI TIBURON
I just found out today that it is a problem for alot of 2003 tiburons that the flasher relay for the turn signals will go out causing the turn signal lights to stay on even with the car off. The relays are internal and located on the circuit board of the BCM. In order to fix you will have to remove and disassemble the bcm circuit board from it's housing and resolder a new flasher relay. Haven't figured out where to get that flasher relay though.
Jan 19, 2009 | 2003 Hyundai Tiburon
Turn signal doesn't always work Jeep Grand Cherokee 2003
try replacing the turn signal relay, i had the same problem.
Dec 10, 2008 | 2003 Jeep Grand Cherokee
HUMMING/CHATTERING NOISE ON SANYO TV
Confirmation: Lee2fixit's solution also worked on a Sanyo 19" TV Model DS19580with 'buzzing relay'. Chassis carriessimilar relay (Type DG1U 12VDC II TV-5 8A 250V~ also by DEC) at location RL601and a 25VDC 470uF electrolytic cap at C622. After confirming the relay was sound and finding no obviously faultedcomponents tied to it, replaced the cap. Bingo, normal operation and a quiet relay. Will post a follow-up ONLY if the fix failsbefore the rest of the TV .. it's almost10 years old after all. Thank youLee2fixit and FixIt.com.
Jul 05, 2008 | Televison & Video
I purchased a Digital Camera in Dec.07 and it quit working about two months later.Model#A730 GE.It won't do anything except the green light comes on.To turn light off u have to remove batteries.I purchased...
You will have to send the camera for factory service. It sounds like the main processor board is defective, or it is halted and cannot start. The service tech will most likely repalce the processor circuit board to start.
Jerry G.
Jul 03, 2008 | Cameras
Jenn-Air SVE47100 Slide-In Electric Kitchen Range Logo
123 people viewed this question
Top Jenn-Air Kitchen Ranges Experts
Dan Webster
Dan Webster
Sal De
Craig Butler
Craig Butler
Are you a Jenn-Air Kitchen Range Expert? Answer questions, earn points and help others
