Question about Dmm Iwata LPH400 LVB Gravity Fed Spray Gun, 1.3mm with 1000ml Aluminu
After switching from a 1.2tip to a 1.4 tip when i
After switching from a 1.2 tip to a 1.4 tip when i pull the trigger a little to get only air coming out of the gun fluid comes out? Iwata lph400 lv
2 Suggested Answers
  • 98 Answers
SOURCE: After switching from a 1.2tip to a 1.4 tip when i
adjust the knob that holds the needle inside the gun
Posted on Mar 17, 2010
How to stop buzzing sound on hilti te 706-avr
  1. try to pull the trigger more back then its stand free , because i think that a dust ring insite the trigger was come loose and get inside the trigger so it will not fully come back in its normal rest position but its stands maybe a little fraction triggered , replace the switch .
Apr 24, 2015 | Hilti Drills
Black and decker electric power washer nothing coming out of wand all water coming out trigger.
Either the pressure tip or wand are blocked or the valve in the trigger is broken. Remove the high pressure tip and either try another tip or pull the trigger without a tip on the wand to see if you have the same problem. If available, try another pressure gun on the hose.
Jul 25, 2012 | Garden
I have a bostitch n62fn finish nailer that wont fire. when i pull the trigger, air comes out of the trigger assymbly. the gun is not jammed, and is receiving correct air pressure.
this may sound stupid but are you pushing it against the wood when pulling the trigger. it has a safety switch on the front so it will not work just by pulling the trigger.
Nov 12, 2011 | Stanley Bostitch N62fn Finish Nailer Parts...
I installed a new grease cartridge in my grease gun and grease does not come out when triggered.
If the gun was working properly before you changed the cartridge, The gun is air-locked
Two things: 1. Make sure the bottom rod is pushed in. 2. Holding the gun by the handle on the top left of the gun, below the hose there is a little metal valve. Push that vent valve down and pull the trigger repeatedly until grease starts to come out.
If that doesn't work. Remove the grease hose, hold the vent valve down, pull the trigger a few times. Then release the valve and pull the trigger until grease comes out. Replace the hose.
And if that doesn't work. Sometimes when you put in a new cartridge the metal "washer" that actually pushes the grease up the cylinder will get caught at the bottom of the new cartridge. Make sure the washer will move freely into the cartridge.
That should do it!
Jan 14, 2011 | Lincoln Automotive Pneumatic Grease Gun...
Stanley bostitch double fires. It is an older stick feed. Works fine when I hold the trigger and tap the tip. But when I press the gun into the wood and pull the trigger it double fires. Gun is older, but...
You did not list your model number, however most bostitch nailers use the tva6 trigger valve. As this valve wears it will be erratic. Examine the firing pin that makes contact with trigger. If it looks worn or wabbles from side to side, then time to replace. To remove valve first remove trigger by removing roll with 3MM punch. Next remove one or two roll pins just above the valve, also 3mm. With roll pins removed air pressure will pop out valve. Be carefull because valve can come out with force, use glove or rag to catch. Parts available at www.toolpartsdirect.com, or generic valve at www.ebay.com. Good luck
Sep 18, 2010 | Stanley Bostitch Coil Framing Nailer
Mar 17, 2010 | Dmm Iwata LPH400 LVB Gravity Fed Spray...
My little 110 mig welder is arcing without trigger pulled
i believe that the trigger only send out the wire and does not control the arc the tip should be live as long as the welder is on
Feb 28, 2010 | Lincoln Welding Tools
Must pull the trigger every time to shoot a nail, should be able to hold trigger and tap where i want the nail.
On some models the contact fire is not available. There is a flap that is under the actual trigger. When you press the safety in, it engages this little flap which allows the trigger to be engaged. As soon as the safety comes up this little flap falls back down disengaging the trigger.
There is an optional trigger assembly that you can put on this nailer. You need parts 174299 and 174300 to make this gun a contact nailer.
Sep 10, 2009 | Stanley Bostitch HP118K 23 Gauge Headless...
Porter/Cable 15 gauge angle finish nailer
The driver assembly can sometimes get bent or the tip can get a little deformed causing it to hang up in the nose. Other than that, not much else it could be if you rebuilt the whole thing
Dec 31, 2008 | Porter Cable 16 - Gauge Finish Brad Nailer...
Thermal dynamics cutmaster 50 2004 yr.
Check contacts in tip and be sure it is all lubed correctly. If you have good air pressure and flow it should arc after pulling the trigger for about 2-3 seconds.
Sep 27, 2008 | Welding Tools
Dmm Iwata  LPH400 LVB Gravity Fed Spray Gun, 1.3mm with 1000ml Aluminu Logo
Top Dmm Air Tools & Compressors Experts
John Trevino
Joe Garcia
Joe Garcia
Are you a Dmm Air Tool and Compressor Expert? Answer questions, earn points and help others
