Question about Samsung LE32R74BDX 32 in. HD-Ready LCD Television
Shadow Problems Have just received a new Samsung TV.. Model No. LE32R87BD... There seems to be a problem with the picture quality, from when i first switched it on there appears to be a shadow effect across the screen which distorts all the texturing of objects!!! Any advice would be great
  • Anonymous Jun 17, 2008
    help
  • Anonymous Nov 09, 2008
    Right, I have the same issue, model LE32R87BD.
    The image sometimes (and more and more often) at startup is very bad with:
    => Great image latency : fuzzy effect
    => All colors are dark. Pure white is OK, pure black is OK, all other colors are much darker. This makes watching impossible.
    => Same symptom on all input : HDMI, Analigue input, Digital TV... Tries done with unplug of all others input.
    => Sound is OK.
    After a while (more than 10 minutes), image gets back to OK automatically, which makes me feel uncomfortable with technician support that I could request. (still under warranty)
    Image settings modification or default restoration has no effect.
    Look like a Samsung bug.
    Software version : T-BDXPDEU00-1014 of 28/02/2008
    Microsoft : T-ST1DEU7-1000
    Que faire ?
Cf my issue above on LE32R87BD The repair guy came here two times and finally changed the LCD panel which is very expensive. So far, it is working again properly.
Posted on Nov 26, 2008
SOURCE:
Picture quality has suddenly degraded
Some time you get a bad one out of the store,still under warranty period.Yes best just return it to the store get a new one or get some store credits buy another one.Tried research if this brand and models of tv you have this problems happen to it more than the other tv brands out in the market.Tried to proof it to Samsung to get a replacement from them.U tries other incoming live tv broadcast make sure it it not the tv station signal or u tried tv with other media devices like BLURAY or DVD players see u have the same problems correct.
Jan 05, 2013 | Samsung 46" Full Hd Led Lcd Slim 1080p...
Hi, im having picture quality problem. kind of a blue shadow mixed with a little orange mostly on top of the screen. you see double of the image in a shadow haze. should I junk this tv or is there a fix...
No,this tv it is fixable and still can be in used for many more years to come.This tv have a problems known as a convergence pictures problems,it is dead.Tv problems have any colors lines R,G,B mis alignments,have colors shadows pictures or 3D pictures look alike?Yes,than the tv have a dead convergence board to causes this problems.Must have the tv convergence board to be repair like replacing 2 STK convergence ICS and some or all of it resistors too.To fixed the tv convergence board to solved the tv convergence pictures problems.The tvs shops will cost u like $300-350 for parts and labors.
Aug 16, 2011 | Hitachi 57F500 57" Rear Projection...
Screens distorted, and shadow on screen
ladut
What type cable do you have between your TV and DVR receiver? Do you have any other component connect to your TV, DVD or gamebox? If you have a DVD player, do you have a good picture or the same shadow and distortion? If you have the same problem, there may be a problem with your TV. If you have a good picture, try unplugging the cable between the TV and receiver and plugging it back in. If you still have the same problem, try a different cable. If you still have the problme after replacing the cable, you may need a new receiver. I hope this helps.
Ray Calo
DISH Network
Mar 16, 2011 | Samsung Televison & Video
Got and RCA Scenium CRT HDTV (D52W135D) which seems to have a convergence problem, green shadow over picture. DVD picture is very dim also
This tv have 2 problems than,the tv projection lamp life is over,that why the picture is dim,must be to replaced with a new picture lamp.The tv convergence board the 2 STK convergence ICS and some or all the resistors are dead.Replaced all these parts to solved the convergence problems.
Jun 24, 2010 | RCA D52W135D 52 in. TV/DVD Combo
Screen on my Samsung LE32R87BD goes black for a
Contact Samsung . There is a software upgrade for this.
Sep 01, 2009 | Televison & Video
Samsung 52' TV Is showing red
MY SAMSUNG TV MODEL NUMBER LE32R87BD IS DISPLAYING A RED FLASHING LIGHT ON THE POWER BUTTON AT THE FRONT OF THE TV THERE IS NO PICTURE PLUS IT WONT TURN ON CAN ANYONE ASSIST ME WITH THIS PROBLEM
Feb 06, 2009 | Samsung PCN5425R 54" Rear Projection...
Receiving digital tv service in Australia using samsung LE32R87BD
rest tv to manufacture settings then in the menu it will ask for your area i think its on there for australia. you will need to go down the menu. and then setup it would ask for the area you are as well, make sure you have a aerial in and its pointing in the right direction .
Jun 04, 2017 | Televison & Video
Picture shadow on rear projection Sony big screen TV
You have 2 distinct problems that should be addressed separately. Please repost the Samsung problem. I will address the Sony problem here.
If the "shadow" makes the picture seem somewhat of a 3D one, the problem is with the convergence circuit. This could be as simple as bad connections on the pins of the convergence ICs or defective ICs. If you can solder and would like to attempt the repair, update this and I'll provide more details and instructions.
Dan
Sep 25, 2008 | Samsung HCM4216W 42" Rear Projection...
Samsung LN37A550P3F shadow image
It seems new TV.
But that kind of problem is related LCD panel.
If you can replace LCD inverter first.
then not working need to replce LCD panel.
Jul 22, 2008 | Samsung HP-P3761 37 in. HD-Ready Plasma...
When i switch my samsung lcd tv model le32r87bd it starts alright but after about 2 seconds the picture goes and the screen turns black i can still hear the sound and the remote seems to still work but no...
Sounds like you need an inverter board which is the power supply for the screen lights. I tried to look up the part but samsung dosen't have a service diagram posted for it yet. Since it is so new you may want to find a samsung authorized service center because if the part is not available yet Samsung will have to solve the problem.
Jun 27, 2008 | Samsung Televison & Video
Samsung LE32R74BDX 32 in. HD-Ready LCD Television Logo
809 people viewed this question
Jerry Greenberg
Jerry Greenberg
Ekse
