Question about Moen Posi-Temp Single HandleTub And Shower Faucet
Low water pressure. New installation, replacement
Low water pressure. New installation replacement stem is the same. There is plenty of pressure in the system but not when the posi-temp is installed
  • 94 Answers
Posi temp's usually have shut off valve's to the left and right of center.remove trim plate and check,make sure they are turned full on.i am pretty sure they are quarter turn type,and they have a screw driver slot,when there horizontal they should be fully open
Posted on May 18, 2010
I just installed new water pressure tank,it builds pressure to max then water runs low on pressure till pump kicks back on.whats wrong
Have to set the pressure switch
(instructions are under the cover)
65 # cut off
42 # cut in
Should install a new switch every ten years
& a new check valve before the tank & manifold
assy every 20 years
Oct 25, 2014 | Water Worker 44 Gallon Vertical Stand...
Cabin (tire) indicator light.
No, it will stay on cause the system is set up for tire pressure monitors. If you change to standard valve stems it wont be able to read tire pressure, therefore it thinks its low om air and the light stays on.
Jan 04, 2014 | 2008 Nissan Altima
Have a shower only no tub. replaced both the hot and cold stems because shower was dripping and water pressure was low. Thought if I replaced the water pressure would return. Tightened the top nut before...
Take the shower head off and see if the pressure is better or the same. If it is the same then you will need too look up-stream for blockage in the water lines. If it is better then replace or clean out the holes in the shower head. It may also have a filter screen before the shower head.
Apr 12, 2011 | Danco Faucet Stem
Hello, I replaced the seats and springs in my faucet Delta Leland 2578 and now my water pressure is low. So I thought it was the stem unit assembly because it had a lot of deposits on it so I replaced...
it would only be aerator if hot and cold were low..what happened is when u shut angle stop off on hot water to replace assmbly..the washer on angle stop separated and is blocking the supply
Nov 21, 2010 | Delta Faucet 2578-278 Leland Series...
Low pressure valve stem is leaking on my 1995 chevy truck
Low pressure valve stem? Do you mean on the A/C system? If so, just simply replace the shreadder valve.
Jun 15, 2010 | 1999 Chevrolet Silverado 1500
The posi temp valve has a little system built inside to anti scald you when your taking a shower, they have little parts that move back and forth, they get easily clogged from sediment and minerals in the water and always get stirred up when the water is turned off and back on from doing work.
Mar 17, 2010 | Moen Posi-Temp Single HandleTub And Shower...
We have a jenn-air jfc2087hrs (french door model) and the water pressure from the internal water dispenser is very low. the line has plenty of pressure.
If your ice maker is making full size cubes then it should one of 2 problems.
The water valve on the bottom back of the machine is a dual valve. One side feeds the ice maker, the other side feeds the water supply.
1. The dual water valve. is going bad. The water side is malfunctioning.
The dual valve must be replaced.
2. Your model should have filters for the water dispenser, and need replaced.
Try changing the filters first.
Oct 04, 2009 | Jenn-Air JFC2087HRS Side by Side...
We installed two new single handle shower faucets with both hot and cold supply lines pressurized to each of the faucets. The problem is that no hot water will come out of either faucets. Their seems to be...
Sounds like the valve is defective. The supply to the stems was not bored out at the factory giving you a valve that is essentially pretty on the outside and solid on the inside. To test it, uninstall the valve. Remove the stems. Then try running a pipe cleaner though the valve from the supply side and see if it stops before the stem.
Aug 15, 2009 | Moen & One Handle Tub & Shower Faucet
Low or no spray pressure
You sound like you diagnosed it pretty good, so I think you can change the impeller. The biggest problem is making sure everything is lined up so it wont leak after its re-installed. I've never had much luck removing the old impeller without breaking it into pieces. just be careful not to mess up the shaft. If its an older machine, some Whirlpool/Kenmore can have the whole thing changed in one part. Its a little more $$ but it has the motor and all. And its easier and faster!! Also, your pressure problem may be related to the motor.
Mar 15, 2008 | Whirlpool 24 in. DU920PW Built-In...
Moen Posi-Temp Single HandleTub And Shower Faucet  Logo
450 people viewed this question
Top Moen Home Experts
Mike
john h
Andrew Bugbee
Are you a Moen Home Expert? Answer questions, earn points and help others
