Question about Dryers
The dryer makes a loud banging and squealing noise. The top back panel on the dryer gets very hot as do the top of the dryer
  • Dryers Master
  • 43,501 Answers
Here is a tip that I wrote about dryers and noises...
It will help you determine what is happening there...
DryerThe dryer makes a loud banging and squealing - 2_bing.gif Repair Squeaks, Grinding, Clicking and Knocking Noise
http://www.fixya.com/support/r4416566-dryer_repair_squeaks_grinding_clicking
heatman101
Asker's Testimonial " This should give me an ida of what to look for once I open er up " -
Posted on May 12, 2010
Problem with tumble dryer that has started making loud noise.
Dryers are designed to operate in one direction. Some models turn clockwise and some turn counter-clockwise. Do not run it backwards. The direction of air flow will be impeded or reversed.
Mar 07, 2017 | Whirlpool Dryers
I have p 1508 Make noisy sound and move like about to explode But when work without cloth nothing So what is the problem
Hello. If the dryer is making a loud "banging" sound with clothes in it, the problem might very well be a worn out drum support roller. I need the complete model number to help you accurately. Most dryers have 4 drum support rollers--2 mounted on the back wall and 2 mounted on the front bulkhead. They generally are made of thick rubber with a machined steel core--polished so it glides smoothly on a matching machined shaft. The rubber can become worn and develop a flat area that "thumps" loudly. If the drum is empty, it may just "skip over" this damaged roller area. Now, if the dryer is squealing loudly, this is a good indicator of a bound-up idler pulley. It's a spring-tensioned pulley that the drum belt rides on to keep it tightly in contact with the drum to make it spin. Hair, lint, other debris often gets in-between the roller and shaft, causing it to bind up and wear on the belt--also causing a loud squealing sound. Next, a loud sound could be caused by an object getting caught in the blower housing and binding up the fan which pushes hot air. Socks, underwear, small pieces of clothing, etc. are NOTORIOUS for causing this! Check the blower for obstructions. I hope this helps you!
Oct 30, 2015 | Dryers
Maytag neptune dryer makes loud noise on the right side when top dryer is on
The belt tensioner bushing could be shot or there may be a piece missing from the belt. Did you check the back for a removable observation cover?
Jan 05, 2014 | Maytag Neptune MCE8000AY Electric Dryer
Maytag neptune dryer making loud banging noise mde6700ayw
First, check the vane's (paddles inside the drum) to see if one is loose. Post back the results.
Nov 06, 2012 | Maytag Neptune MDE6700A Electric Dryer
Drum makes loud banging noise.
Maybe the heat in your dryer over time has melted weak glue and loose components are hitting against the drum
Jan 16, 2012 | Frigidaire Electric Dryer
Bosch WTMC3500UC Gas Dryer Dryer...as it is turning makes LOUD clanging banging noise. Will make the noise when turned by hand does not make the noise when tuned by hand in the other direction.
Dryer Repair Squeaks, Grinding, Clicking and Knocking Noise
heatman101
gkjlgkj
Feb 15, 2010 | Bosch WTMC3500UC Gas Dryer
Hi, our washing machine started making very loud banging and whining noise in the final spin cycle and the machine was shaking. We have taken off the back. The springs look ok. any suggestions?
Loud banging is usually an unbalanced load. whining noise is some times debris trapped in drain pump causing it to squeal like a fan belt on a car. Strings, threads and hoses tend to get wrapped under agitator and cause noise, too.
Jul 24, 2009 | Frigidaire Affinity ATF6000F Front Load...
My Maytag HAV2557AWW Loud Noise
pull hoses off the pump and see if there is anything stuck in it
Jun 12, 2009 | Maytag HAV2557 Top Load Washer
Loud noise
First, UNPLUG YOUR DRYER! Now open the dryer door and remove the 2 screws at the door hinges... remove the door and set aside, then remove the 2 screws opposite the hinges. Grasp the front panel near the top, just below the top panel and pull it toward you... do this on both sides. Tilt the panel forward then lift it off of the lower clips.
With the front panel gone, you'll see a 5/16" screw just below the top panel on both sides, top left and right. Remove these and the clips too... now you can lift the top panel like the hood of your car.
To gain further access, remove the 6 (3 on each side) screws holding the front drum support/blower vent panel, then set this aside.
If you want to remove the drum... first, take a flashlight and look closely at how the belt is routed around the idler pulley and the motor shaft. (You'll have to re-route it for reassembly.) Reach in there with both hands, with one hand rotate the spring loaded idler pulley back to release tension off the belt, then with the other hand remove the belt from the motor shaft. Now lift and pull the drum out the front of the cabinet.
Check to make sure the rollers in the back rotate freely. You can remove the rollers, buff the roller shafts with emery cloth, lube the shaft with light oil (like sewing machine oil) and reinstall the rollers. Lube the idler pulley also. Rotate the motor by hand and listen for the squeak you described.
Also check the front drum support panel you removed earlier. The drum rides on this as it rotates... As you are looking at the drum support from the drum side, inspect the 10 o'clock to the 2 o'clock area closely. If the glides (teflon) are worn it'll squeak when it rotates.
Hope this helps. Oh yeah! Almost forgot.... the belt won't squeak at all. It'll be the motor, rollers or drum glides.
Nov 02, 2007 | Maytag Neptune MDE5500AY Electric Dryer
Dryer makes banging noise
basscat, you first remove the door by removing the screws from the hinges. The door will lift up a litte and pull off. Next remove the spacers on the other side. Now the front panel will pull out from the top. There will be two 1/4 inch screws with latches on each side of the frame, remove these and the top will lift up. Now by holding the door switch and starting the dryer, you will be able to see what is banging. Once you determine that, you can remove the bulk-head, should be 4 screws, be sure to unplug the door switch. Unfasten the belt, remember the configuration and remove the drum. You are now able to get at the insides. Catriver..post back.
Oct 02, 2006 | Maytag MDG9206 Dryer
Dryers Logo
101 people viewed this question
Top Dryers Experts
