Gateway HD2201 22" LCD Monitor Logo
A
Anonymous Posted on May 09, 2010
My Gateway HD2201 turns on and off
My Gateway HD2201 is connected to my laptop via vga. The monitor just started turning off and on about ever 5 seconds consistantly. I have checked the plugs for the vga and power cord. What else could be causing this to turn off and on?
Anonymous
Level 1:
  • Contributor 80 Answers
  • Posted on May 15, 2010
Anonymous
Contributor
Level 1:
Answers
80
Questions
0
Helped
23187
Points
98
Open it up and look at the capacitors. The round "tin can" looking components. If the tops appear bulged, then replacing them may help. Check out the YouTube video... and web site...
http://www.youtube.com/watch?v=9Q6_TgNJvQw
Good Luck!
1 Related Answer
RAGHU
  • 401 Answers
  • Posted on Mar 17, 2010
SOURCE: My Gateway HD2201 turns on and off
change the resolution of vga to 1024x768
When i connect a monotor to my laptop with vga nothing occurs. when i press fn and f8 nothing. i try pressing windows key and p after that i turn on project, nothin. i press on monotor icon, nothing
turn on monitor first with it plugged into laptop via vga cable.
THEN turn on laptop and start it from OFF .
it has to detect the monitor is plugged in to laptop before it will offer video selection via FN F8 key
I am trying to connect sound bar to a Gateway Monitor HD2201 It looks connected. I used a VGA monitor replacement cable to connect to my dell laptop, but there still isn't any sound from either.
Hi Laura Boquet,
Please provide the sound bar model and the laptop model then I can check and help you further.
Thanks and Regards.
Kiran Kumar.
#iworkfordell.
I am trying to connect to gate way monitor
You need a cable from the "audio-out" from your laptop to the "audio-in" port on the Gateway, to transmit the sound to the monitor.
The monitor won't come on it shows RGB no signal
Are you using the correct cord (HDMI, VGA, etc.)?
My screen keep going white
To me this is a hardware problem.
Let's diagnose, and see Shunka_Reid.
Connect a VGA monitor to the laptop.
A) Laptop OFF, monitor OFF, connect a VGA monitor to the VGA port, on the laptop.
http://support.gateway.com/s/notebook/2009/gateway/nv/NV78/NV78lv.shtml
Number 3 - External VGA display port
General example of VGA connector (port), and VGA cable,
http://en.wikipedia.org/wiki/VGA_Connector
Scroll down a little for the VGA cable example.
You can use a CRT type of monitor, (Looks like a small TV), or a flat LCD screen monitor if it has a VGA cable.
General example of a CRT type of monitor,
http://www.wisegeek.org/what-is-a-crt-monitor.htm
B) Turn the monitor on. If a CRT type allow it to warm up.
Turn the laptop on.
By factory default settings, the display should show on the external VGA monitor.
IF not;
There are at least 3 display options available;
1) Internal monitor of laptop ONLY
2) Internal monitor of laptop AND external VGA monitor.
3) External VGA monitor ONLY.
Press, and hold the Fn key down, and at the SAME time tap once on the F4 key.
The F4 key is the Display Toggle-Over key.
Still no?
Hold the Fn key down again, and tap on the F4 key once more.
Do you get a good display on the external VGA monitor?
Post back in a Comment.
Also, has the laptop ever been cleaned on the Inside, to your knowledge?
Regards,
joecoolvette
1helpful
Is there a special driver for hd2201 or is the 'generic pnp monitor' driver the best/only one?
If your monitor is a Gateway FHX2201Q, then your driver is at:
http://www.support.gateway.com/product/default.aspx?tab=1&modelId=3261
If your LCD monitor is an HD2200 series LCD monitor, then "generic PNP monitor" is it.
You can confirm by spending some time at the Gateway support site:
I purchased a gateway HD2201 monitor all I see is white screen
Maybe your resolution is not set to the right settings for your new screen, set the resolution and refresh rate lower with the old screen attached and try again with the new screen
1helpful
Where i download the driver xp for gateway hd2201 monitor
Download from the gateway site. You will need your serial number.
2answers
When attached via HDMI, monitor goes to "sleep". When using VGA cable, no problems. Gateway website has ZERO drivers for this monitor. Running Windows 7 Ultimate x64
First shut down the pc and then plug in new monitor then boot up and see if windows 7 will auto find the monitor.
is this a single display or are you using 2 monitors, i had 2 monitors and used the other to change the display on mine when i had this problem i am also using windows 7 and reboot usually fixes display problems because it wont see old monitor any more and detect the new one.
also update any video drivers you have like nvidia or ati(catalyst controll center)
Top Gateway Computers & Internet Experts
Grand Canyon Tech
Grand Canyon Tech
Are you a Gateway Computer and Internet Expert? Answer questions, earn points and help others
