Question about Hayward H Series Pool & Spa Heater 400k Btu Propane Gas Milivolt Ignition H400p1
I have a hayward H200 series heater and th eheat exchanger is leaking. I have pulled the heat exchanger out and cant see anything visible it is probably leaking inthe area covered by the fins. I have looked online and can see plenty of places selling the heat exchanger with the headerplate etc included but all of that on my current unit is fine is it possible to buy just the heat exchanger part without the header plate to help save on the costs??
  • 64 Answers
NO. The heat exchanger comes complete with the header and as you know, is very expensive. You will not be able to see a hole wherer it is leaking. It is nakes to the eye. But if water is coming out, the exchanger is bad and will need to be replaced. Where are you located? I can probably beat any price out there. Part number is idxlhxa1400.
You can contact me at aquatechpoolservice@earthlink.net
Posted on May 20, 2010
Hayward h200 pool heater (LO) Error code
check gas pressure sounds like gas meter is too small
Jul 12, 2013 | Hayward H-series Electronic Gas Pool...
My pool Heater is leaking
You will need to take the top off the heater to see exactly what is leaking. It could be something as simple as a header gasket, or as bad as holes in the heat exchanger.
Jul 22, 2011 | Hayward H-series Electronic Gas Pool...
Leak from both top and bottom of the recessed area which holds the thermol coupler senor bulb inside the copper water priping
Not sure i quite understand, but if your saying the water is leaking from the copper heat exchanger, then you need to replace the exchanger itself. Not cheap.. but do-able. 9 times out of 10 a leaking heatexchanger is caused by chemical abuse ( low pH)
Aug 22, 2010 | Hayward H Series Induced Draft Abg 100,000...
Pool heater shuts off after a few second
You didn't indicate your exact model. There are different versions of the H200 series. If it is milivolt then there is no electric, Must have correct milli-volt pilot generator. If it's electronic, check the air flow pressure switch on the combustion air.
Jul 17, 2010 | Hayward H Series Pool & Spa Heater 400k...
Water coming out of heating element. How to fix?
If it is coming out of the heat exchanger you could have a big problem. You want to remove the top of the heater to find exactly where the leak is. If it is pinholes in the exchanger from a salt system or bad chemistry you may need to replace the exchanger. It could also be from a gasket on the sides of the exchanger. Remove the tops and sides of the heater until you find exactly where the leak is.
May 23, 2010 | Hayward H Series
Hayward Model H250IDL is leaking water from drain valve.
Water leaking from the heater is not a good sign. This is an indication of a leaking heat exhanger. The heat exchanger will have to be replaced and the part is made of copper. It is very expensive, depending on the age, you may just want to replace the entire heater. Exchangers usually leak due to bad water chemistry.
May 09, 2010 | Hayward H Series Pool & Spa Heater 400k...
I have a hayward H200 series heater and th eheat exchanger is leaking. I have pulled the heat exchanger out and cant see anything visible it is probably leaking inthe area covered by the fins. I have...
You need to buy the whole unit as these are pressed in place together. If you have a leak it is most likly due to chemical damage and goes further. So at the least you will need an exchanger. I will usually try to get people to go with a new heater if it is more than a couple of years old due to cost and hidden damage that can only come out after you install a new exchanger. Sorry for the bad news.
Mar 17, 2010 | Hayward H Series Pool & Spa Heater 400k...
LED display HI and visible leak in unit
HI indicates an open limit sensor.as far as the leak goes i would need to know the location of the leak.if its leaking inside the unit, more than likely it it would indicate a heat exchanger and that would not be good news because exchangers are rarely repairable and are the most expensive component of your pool htr.
Sep 15, 2009 | Hayward Pool & Spa
My hayward H series above ground heater. Will not keep heating.
Sounds like the heat exchanger is sooted up. Desoot...messy job but sounds like you know your way around the heater
Jul 27, 2009 | Hayward H Series
Loud noises, shaking, visible white powder in chlorinator
Stop using the heater immediately. You are boiling the water inside and this can lead to a dangerous situation if a limit switch fails to act in time.
You will likely find the diverter in the inlet side of the heater is broken. You are looking for a stainless steel plate in the water path. If you can move it by hand, it is broke. It is not replaceable and requires a new heat exchanger assembly to repair it.
Your part number is IDXHXA1101. We sell it as will most pool dealers. If you would like a quote, contact us at www.arrowmotor.net
Jun 16, 2009 | Hayward H Series Induced Draft Abg 100,000...
Hayward H Series Pool & Spa Heater 400k Btu Propane Gas Milivolt Ignition H400p1 Logo
378 people viewed this question
Top Hayward Pool & Spa Experts
Jay Finke
Jay Finke
Craig Butler
Craig Butler
Charles T Nevin
Charles T Nevin
Are you a Hayward Pool and Spa Expert? Answer questions, earn points and help others
