Question about Samsung ML 1710 Laser Printer
ML-1710 online/error LED turn red.
Why ML-1710 online/error LED turn red? the toner is oK.
  • Anonymous Jun 19, 2008
    me marca una luz roja en on line/Error
  • sasar May 21, 2009
    Online/Error LED turn RED whenever printer is switch on
samkong
  • 106 Answers
SOURCE: ML 3561ND engine fuser. low heat error??????
If you have annother tonner cartridge, (the old one will do)fix it and see if it works. If not there might be a component faillure related to the Fuser Unit. Also check for any Jam in the Pinions(Sometimes Samsung Laser Displays wrong MSG.)
Posted on May 06, 2007
SOURCE: Dell 1710 Laser Printer
i had the same issue, but i fixed it. For whatever reason the contacts that are inside the printer were not making contact with the PCB ( printed Circuti board ) on the underside of the drum... i fixed the issue by cleaning the pcb and re-aligning the contacts inside the printer.
Posted on Jan 25, 2008
SOURCE: Samsung ML-1710 on-line problem
selam bende samsundan tanisallimmi?sizi facebokkta gördüm ve begendim tanismak istiyorum boy 1.70cm göz yesil omuzlara kadar sari saclarim var kilom 60kilo ben buyum sizde isterseniz cok tanismak isterim
Posted on Feb 12, 2008
SOURCE: online/error light
Pull out the toner cartridge. Carefully put your fingers into the opening just beyond the chrome roller. A little to the left of center you will fell/see a small black plastic finger which sticks up. It should be loose - push it forward and it springs forward, release it and it returns to the original position. If your paper jam catches this finger it can become jammed and will feel rigid. Put light pressure on it either pushing to the back or pulling forward until it becomes free again. Replace the toner cartridge, close the cover and your red light should go out.
It worked for me - hope it helps someone else.
Mary Lou
Posted on Oct 22, 2008
SOURCE: after replacing toner cartridge, error/toner lights stay on
Open the front of the printer then hold down the cancel button. When the lights flash close the front and it should Reset.
Posted on May 14, 2009
Red light on all the time will not print Samsung ml-1640
Depends which LED light is red. The upper one with two symbols is the error LED, while the lower one is the toner LED.
If it's the top LED, then it could be a number of issues, such as an open cover or some software problem. Could be an LSU error. Try updating the driver and firmware.
If it's the bottom LED, then your toner is probably finished (or has hit the 2100 mark). Try redistributing the toner by giving it a little jiggle, or just change the whole thing.
Apr 05, 2010 | Samsung ML-1640 Monochrome Laser Printer
Samsung ML-1710p - error
It is problem your fussier unite may be thermostat or or lamp is fuse.If you are not a technician you go to a service center.Or you are a technician open it and clean thermostat and heater lamp check by ammo miter.
Nov 27, 2009 | Samsung ML 1710 Laser Printer
Samsung ML-1710p - when attempt to print, leds start slowly blinking simultaneously, "on line / error" - red, "toner save" - green
May be rejected this toner unite or paper could not feed properly.Service thoroughly your printer and Fuser unite.
Error light is red, and nothing prints
i think your paper sensor is damaged, replace it
red light show : when paper is not present or toner is not accepted, or door open
We have Zero cost solution for samsung -scx-4300, scx-4824/4828
ml-2240,ML 2245, ml 1640. clp 310/ 315, It is working permenently.
Refill cartridge is working for ever. which is running successfully.
also provide other new model reset solutions.
www.nakshatraworld.com
mob: 9713862555, 9893282285
vivekryp@yahoo.co.in
Nov 22, 2009 | Samsung ML 1710 Laser Printer
Online error red led blinking,but tonar save led off
Any kinds of paper jam,please check it input and out put section.
May 07, 2009 | Samsung ML 1710 Laser Printer
ML1640 not working after toner refilling
Download the firmware from here http://org.downloadcenter.samsung.com/downloadfile/ContentsFile.aspx?CDSite=in&CttFileID=2238869&CDCttType=FM&ModelType=N&ModelName=ML-1640&VPath=FM/200904/20090416100856890/ML-1640_V1.01.00.83.exe
run the software and this will reset the page count to 0. Samsung printers generally do not support a refilled cartridge and thus the red light.But resetting the page count to 0 makes the printer detect the cartridge as an intoductory one.
Mar 23, 2009 | Samsung ML-1640 Monochrome Laser Printer
Samsung printer ml 1510 red light flashes after self test
Red Error Light Stays On The following conditions can cause the On Line LED to glow solid red:
  • Printer paper is jammed inside your printer.
  • A cover is not be closed properly.
  • The toner cartridge is not inserted properly and needs to be reinstalled.
  • The toner cartridge is running low.
  • There is no paper in the paper tray.
  • The paper inside the paper tray is not be installed correctly.
Red Error Light Blinks If your printer's On Line LED is blinking red, your printer's toner is exhausted and needs to be replaced. On Line and Error Light Blink Simultaneously
If your printer's On Line and Toner Save LEDs blink simultaneously, your printer requires service.
You can go to samsung online service request http://www.samsung.com/us/support/repaironline/supportOnlineServiceRequest.do
Mar 21, 2009 | Samsung ML 1510 Laser Printer
Samsung ML-1710 Printer: Online/Error (red) lite ON: won't print
It is not a computer problem, when your printer won't come to ready. The lights flashing are due to a failure of some sort - electronic, or perhaps a fuser warm up problem. The fact is, whatever the fault, it is cheaper to replace this printer than have it repaired.
Mar 16, 2009 | Samsung ML 1710 Laser Printer
Printer- On Line/Error
Download the status monitor for the ML-1710 and when you switch on the machine the monitor should help to give you an indication of what the error is. Post that info back here for further help. Unfortunately there is insufficient information here to help you further. The status monitor may give you an error code - this will help us help you further.
Sep 16, 2007 | Samsung ML 1710 Laser Printer
Samsung ML 1710 Laser Printer Logo
328 people viewed this question
Top Samsung Office Equipment & Supplies Experts
mukhtar21 shaikh
mukhtar21 shaikh
HEMANT GROVER
Victorman
Victorman
Are you a Samsung Office Equipment and Supply Expert? Answer questions, earn points and help others
