MY SCROLL KEYS ARE STUCK....CAN I DISABLE THEM?
  • 942 Answers
Try to click the scroll luck button on your keyboard. If your keyboard does not have that, press Fn + Scroll Lock so that the scroll keys will not stuck....
Posted on May 12, 2010
Microsoft excel 7 disable scrool lock fuction
First locate SCROLL LOCK key in keyboard (Normally it in function keys in laptop, and separate on desktop keyboard).
Now press:-
1. SCROLL LOCK Key
or
2. Fn + SCROLL Lock key (if it is colored as the color of Fn key in laptop)
Sep 30, 2014 | Microsoft Excel Computers & Internet
Well, my Netbook scrolls down randomly. Either up or down. No matter what I do it won't stop, I usually bang on the directional keys and it does stop for a short period. I really don't want to keep...
Sticky keys might be the problems.
1.Press SHIFT 5 times repeatedly
2.Cleanup the touchpad on the right corners ( unit OFF )
3.Seem the PgUp and PgDn keys STICKY >>> try clean it with a dry soft brush
Aug 16, 2011 | HP Mini 1000 Netbook
840,01 scanner disable error. how to solve it
This message indicates that the scanner has been disabled cannot be used. The MFP must be powered off and then press and hold the check and the right button and turn on the printer to access the configuration menu
1. In the configuration menu, use the arrow keys to scroll to the Disable Scanner menu item.
2. Press check button.
3. Use the arrow key to scroll to the desired setting. The options are Enable ADF/FB, Disable ADF/FB, Disable ADF only, Auto Disabled. (Please select Enable ADF/FB)
4. Press check button.
5. Press BACK button.
6. Scroll to Exit Config Menu.
7. Press check button. The device restarts.
8. Try running a copy from the ADF and flatbed.
For further assistance, please contact Lexmark Technical Support.
Jul 30, 2011 | Lexmark X364dn All-In-One Laser Printer
There are three lights on the upper right hand side of the keyboard. I know number lock and caps lock, what is the third light and what keys did i hit that made it go on? How do I turn it off?
The third light on your keyboard is normally the scroll lock, the key to enable/disable this function is the Scroll Lock key which is located above the Home key.
Mar 03, 2011 | GE Power Keyboard (97798)
Is it posible to disable the scroll lock
Yes, all you have to do is press the Scroll lock button. You have not specified what brand is your laptop but I can still explain you. Laptops have small keyboards thats why they use an additional key called "Fn". It works like the Shift key.
If you press Shift + the .(dot) key, for example, it will print >. Similarly, you press a combination of Fn and other keys for different things. Look for "ScrLck" , "Scroll" or similar on your keyboard. When you find it press Fn + that key to disable scroll lock. Hope that helps.
Apr 05, 2010 | Acer Computers & Internet
Some letters like ( a;e,i,o,p ,y) ar nt working on the keybo
for people who activate them accidentally. If you decide you need to disable a key, just follow these easy steps:
1. From the Tools menu, select Customize…
2. In the
Customize dialog box, click Keyboard
3. The Customize Keyboard dialog box will open
4. In the scroll box beneath the Categories label, select All Commands
5. In the Commands scroll box, find the command name for the key or keystroke (you’ll have to do some searching to find the specific key you wish to disable, but here’s a freebie: to disable the Insert key, select overtype)
6. Highlight the key or key sequence in the box below the Current keys label
7. In the drop down box beside the label Save changes in: select Normal to apply the change to all documents created in Word. To disable the key only to the current document, select the document name from the list
8. Click Remove and then Close
9. Click Close on the Customize dialog box
Dec 18, 2008 | Gateway 2520915 Keyboard
Scroll Lock on -- mystery
On the Logitech LX710 Lazer the Scroll Lock option is toggled by holding down the "Function" key and pressing the "Pause/Break" key. If you look at the P/B key you will see a little orange symbol of an arrow pointing down to remind you of this feature. This can be disabled in the Setpoint panel by selecting Keyboard and Keyboard Inactive Keys then place a check in Disable Scroll Lock so you may have to remove a check mark first.
Jun 25, 2008 | Logitech LX 710 Keyboard/Mouse
Computer locked
there are combinations of function or "hot keys" for enabling or disabling these functions. The NuLk is a combo of the functin key and the NumLk key pressed simultaneously. The scroll lock is the one keeping your mouse from working properly. I'm not familiar with your particular unit to advise which keys are necessary to disable Scroll lock, but they should be marked. Also, some notebooks have a switch to disable the mousepad...Usually indicated by a light located above the pad itself. Good luck Harvester3
Aug 18, 2007 | Averatec 3200 Notebook
Computers & Internet Logo
186 people viewed this question
David Payne
David Payne
