HP Pocket 2003. Need to restore information but not recognising profile. Where do I find the files on PC to copy mobile devise. Using XP student edition
  • griffyn Mar 29, 2008
    You have missed the point. The device is syncronising with the PC. To restore the files from the PC to the device I have stated guest/restore/profile/pocket_pc. The software states the profile is invalid/not recogised and therefore will not restore. How do I identify the files on the PC that I need to restore onto the device. Where are the files stored? Once identified I will copy them onto the device
  • 818 Answers
This document lists synchronization issues when using ActiveSync. ActiveSync is compatible with Windows XP or earlier Windows operating systems. If you are running Windows Vista on your computer, download Windows Mobile Device Center to synchronize your computer with the iPAQ. Click here for more information . Symptoms Following is a list of symptoms that may indicate synchronization issues are occurring:
  • No ActiveSync chimes sound (or a gray icon displays), and there is no activity in the ActiveSync window on your personal computer.
  • ActiveSync chimes sound, and the ActiveSync icon on your personal computer changes to a swirling green icon. The “retrieving settings�? message appears on your personal computer, but the ActiveSync connection drops prior to establishing the partnership.
  • ActiveSync is searching for a connection but none occurs. (The green icon on your personal computer continues to spin.)
  • Synchronization has been established between your HP iPAQ and personal computer but connection is dropped. (The green icon on your personal computer stops spinning and grays out.)
  • Firewall or other network protection software message box is displayed for ActiveSync to access the network or Internet.
Solutions Following is a list of troubleshooting tips if you experience difficulty while synchronizing your HP iPAQ and personal computer. Try the following solutions to troubleshoot any synchronization issues:
  • Confirm that you are running ActiveSync on your personal computer with a supported operating system (OS).
  • If you are running ActiveSync 4.0 or later and personal firewall software on your personal computer, please add ActiveSync to the firewall program’s exception list. (Firewall software, such as Sygate Personal Firewall, TrendMicro PC-cillin Internet Security 2005, Norton Personal Firewall, McAfee Personal Firewall, or Zone Alarm Security Suite may block synchronization.) Refer to the documentation that came with your firewall program to determine how to add ActiveSync 4.0 or later to the program’s exception list. To further troubleshoot a firewall application and enable ActiveSync 4.0 or later, visit: http://www.microsoft.com/windowsmobile/help/activesync/default.mspx .
  • During the ActiveSync installation, if you inadvertently left the Microsoft Exchange Server option box checked and are not planning to connect to an Exchange server, follow these steps:
    • Connect your HP iPAQ to your personal computer. Be sure an ActiveSync connection is established.
    • On your personal computer, click Start > All Programs > Microsoft ActiveSync.
    • Click Tools > Options > Sync Options tab.
    • Uncheck the boxes for the sync items listed under the Server group.
    • Place a checkmark in the boxes under the Desktop group for those items you want to synchronize.
  • Disconnect your HP iPAQ from your personal computer and wait for the ActiveSync message confirming that your device is no longer connected. Reconnect your HP iPAQ to your personal computer. Wait for about two minutes to see if your HP iPAQ connects to your personal computer.
  • On your personal computer, in ActiveSync, select File > Connection Settings. Confirm that USB is selected as a potential connection method.
  • Connect your HP iPAQ to a different USB port on your personal computer.
    • Check your USB synchronization cradle or cable.
    • Consider using another synchronization cradle or cable if one is available to you.
  • Try synchronizing via an infrared or a Bluetooth connection. Refer to the printed or CD-based documentation that came with your HP iPAQ for specific instructions.
  • Restart your personal computer and perform a soft reset on your HP iPAQ. (A soft reset does not erase any of your settings, programs or data.) Use the stylus to lightly press the Reset button. Your HP iPAQ restarts and displays the Today screen. Once your personal computer and HP iPAQ restart, reconnect your HP iPAQ to your personal computer.
  • Uninstall ActiveSync from your personal computer and then reinstall it. To uninstall ActiveSync from your personal computer, click Start > Control Panel > Add or Remove Programs > Microsoft ActiveSync. Then click the Remove button > Yes.
  • After trying the above solutions without any success in solving your connection problem, perform a hard or clean reset on your HP iPAQ. (A hard or clean reset clears all user-installed settings, programs, and data and restores your HP iPAQ to factory settings. For more details, refer to the printed or CD-based documentation that came with your device.) You can reinstall your applications on your HP iPAQ once the hard or clean reset is complete by using ActiveSync on your personal computer. Once your HP iPAQ is synchronized properly, go to ActiveSync on your personal computer and select Tools > Add/Remove Programs... and select any programs you want to reinstall.
For additional information about synchronization problems, visit:
NOTE: One or more of the links above will take you outside the Hewlett-Packard Web site. HP does not control and is not responsible for information outside of the HP Web site.
Posted on Mar 28, 2008
  • 790 Answers
Hello griffyn ,
Can u please explain it bit clearly ???
  • 13,433 Answers
Syncronation profile? you should make a new active sync profile.
or do you mean something else? please be more spesific.
if your device was hard reset and you need to restore something.
tell me what exactly.
How fo I fix Outlook issues after running HP system recovery?
Was it this article that led you to rename extend.dat? Did you do the registry updates, too?http://support.microsoft.com/?kbid=204951
When uninstalling 2003 may have been better if you used windows installer cleanup utility as an uninstall of 2003 still leave behind registry entries.
Uinstall Office again using the cleanup utility, and reinstall.http://support.microsoft.com/kb/290301
But first try to restore pst file using Recovery Toolbox for Outlook
and keep it. https://outlook.recoverytoolbox.com/
Sep 17, 2015 | Microsoft Office Outlook 2003 for PC
Tip
How to copy data from a corrupted user profile to a new profile
This article describes how to copy user data from your Windows XP profile to a new profile.
When you copy user data into a new profile, the new profile becomes a near duplicate of the old profile, and contains the same preferences, appearance, and documents as the old profile. If your old profile is corrupted in some way, you can move the files and settings from the corrupt profile to a new profile.
Note The method that is described in this article may not transfer the Outlook Express e-mail messages and address user data that are associated with the user profile where you are transferring data from. When you delete the old profile, you may delete that data if it you do not first transfer it by using other methods. For more information about transferring Outlook Express user data, click the following article number to view the article in the Microsoft Knowledge Base:
MORE INFORMATION
Create a New User Profile in Windows XP Professional
1. Log on as the Administrator or as a user with administrator credentials.
2. Click Start, and then click Control Panel.
3. Click User Accounts.
4. Click the Advanced tab, and then click Advanced.
5. In the left pane, click the Users folder.
6. On the Action menu, click New User.
7. Enter the appropriate user information, and then click Create.
Create a New User Profile in Windows XP Home Edition
4. Under Pick a task, click Create a new account.
5. Type a name for the user information, and then click Next.
6. Click an account type, and then click Create Account.
Copy Files to the New User Profile
1. Log on as a user other than the user whose profile you are copying files to or from.
2. In Windows Explorer, click Tools, click Folder Options, click the View tab, click Show hidden files and folders, click to clear the Hide protected operating system files check box, and then click OK.
3. Locate the C:\Documents and Settings\Old_Username folder, where C is the drive on which Windows XP is installed, and Old_Username is the name of the profile you want to copy user data from.
4. Press and hold down the CTRL key while you click each file and subfolder in this folder, except the following files: • Ntuser.dat
• Ntuser.dat.log
• Ntuser.ini
5. On the Edit menu, click Copy.
6. Locate the C:\Documents and Settings\New_Username folder, where C is the drive on which Windows XP is installed, and New_Username is the name of the user profile that you created in the "Create a New User Profile" section.
7. On the Edit menu, click Paste.
8. Log off the computer, and then log on as the new user
on Feb 07, 2008 | HP Pavilion a1410n (ER890AA) PC Desktop
How to copy contact from pc to mobile model sch w259
I am using "Godsw Mobile contacts Transfer" (which just suppor the pocket pc running on WM5 or WM6)to backup and restore sms for my phone.
GodswMobile contacts Transfer could do everything u want. it could transfer contacts into txt file on ur mobile, could backup and save ur mobile contacts to any computer, could view, edit and print exported contacts on computer then restore contacts from computer to ur mobile phone.
May 23, 2010 | Samsung Cell Phones
How i can sync my Ipaq h3955 with my pc win xp
In order to sync your iPAQ with Windows XP or earlier, you will need to download and install Windows Microsoft ActiveSync 4.5 from:http://www.microsoft.com/windowsmobile/en-us/downloads/microsoft/activesync-download.mspx.
Notes:
You can use ActiveSync 4.5 only with phones that run Windows Mobile 2003 or later versions. ActiveSync and Windows Mobile Device Center won’t work with Windows Embedded CE 4.2 or 5.0, Pocket PC 2002, or Smartphone 2002 phones. (To see which Windows Mobile operating system you’re using, if your phone doesn’t have a touch screen, click Start > Settings > About. If your phone has a touch screen, click Start > Settings > System tab > About.) To sync information to any of these phones, you must use a USB or serial cable and your computer’s Internet connection and File Explorer.
You must use Microsoft Outlook 2002, Outlook 2003, or Office Outlook 2007 to sync your e-mail, contacts, tasks, and notes from your computer.
Download and install ActiveSync:
1. Click the download link on this page, and then click Continue.
2. Select whether you want to register for the Windows Mobile newsletter, and then click Continue.
3. Click Download files below, and then click Download (next to the Setup.msi file).
4. In the File Download dialog box, click Run.
5. Follow the instructions in the Installation Wizard to install ActiveSync.
Note: You must use a USB cable to connect your phone to your computer the first time you use ActiveSync to synchronize information.
Jan 10, 2010 | Compaq iPAQ H3955 Pocket PC
Hi i am having htc touch mobile i want to know how to save all my sms in my storage card please help me
There is no setting that i know off that can transfer the SMSes to the storage card.
However, if you are looking to save the smses on your pocketpc, you can use this software called Pocket SMS. This will create a copy of your sms on the computer. Later you can transfer the data to the storage card for safe keeping.
Its available free at the link given below
http://handheld.softpedia.com/get/SMS/Pocket-SMS-Pocket-PC-60249.shtml
Hope it helps.
Regards,
Paritosh
Jun 18, 2009 | HTC Touch HD Smartphone
About installed software..
I think that “Microsoft pocket pc 1996 - 2003 os” called now “Windows Mobile 2003”. To upgrade your PDA to 2003SE please go to TOSHIBA Site http://www.toshiba-europe.com/. Than go to Computer systems. Under “Support &Downloads” there is option Download Drivers. Please chose your PDA and there are all useful Drivers for “Windows Mobile 2003 SE”. In every zip File there is “Upgrade Guide”. Read it. It can help you to make update without problems.
Sep 08, 2005 | Toshiba e830 Pocket PC
Sep 08, 2005 | Toshiba e805 Pocket PC
Sep 08, 2005 | Toshiba e800 Pocket PC
Hx2410 & Windows 2003 with Acrobat reader for PPC
download the latest version from Adobe (just www.adobe.com) Here is the link to the download page: http://www.adobe.com/products/acrobat/readstep2_mobile.html#pocketPC You will need to select the "Pocket PC Version 2" (not the Pocket PC 2002). The Pocket PC Version 2 is both for the Pocket PC 2002 and Windows Mobile 2003. Enjoy!
Sep 07, 2005 | HP iPAQ hx2410 Pocket PC
Backup and restore data
Section A - How to use a Toshiba Pocket PC e740 without loss of data: Never let the battery fully discharge. Never disconnect the battery from the e740. Regularly backup your stored data. Always connect the product to an external power source before changing the battery. Section B – How to backup your data: B1 – Using Activesync You can make a backup of the Toshiba Pocket PC e740 data to your notebook or desktop computer. If you have backed up your data to your notebook or desktop you can restore that data to your Toshiba Pocket PC e740. Periodical data backup is recommended. The following types of data can be backed up: FILE: Includes files created by Pocket Word, Pocket Excel, Notes etc. or an additionally installed program. REGISTRY: Setup information of Windows or programs. DATABASE: Database information from Pocket Outlook. When making a backup or restoring data please DO NOT remove the Pocket PC e740 from the USB cradle and DO NOT turn off the power to the device until the backup or restore is completed. Backup Instructions: Insert the Toshiba Pocket PC e740 into the USB cradle. A connection between the e740 and your notebook or desktop will be established. Please close all active applications on the e740. On your notebook or desktop start Activesync and select Tools and then Backup/Restore. Select Full Backup. Select Back Up Now to start the backup process. B2 – Using a Compact Flash (CF) or Secure Digital (SD) Memory Card: a) How to insert a Compact Flash Memory Card: Ensure the e740 is connected to the mains. Turn the e740 off. Remove the dummy card if necessary. Confirm the direction of the Compact Flash memory card by lining up the side grooves of the card and groove edge of the card slot. Insert the card smoothly and completely. b) How to insert a Secure Digital Card: Ensure the e740 is connected to the mains. Turn the e740 off. Remove the dummy card if necessary. Insert the Secure Digital card with it’s contact surface (the metal contacts) facing the back of Toshiba Pocket PC e740. Press the card down until it clicks. You can make a backup of the Toshiba Pocket PC e740 data to your Compact Flash or Secure Digital memory card. If you have backed up your data to your Compact Flash or Secure Digital memory card you can restore that data to your Toshiba Pocket PC e740. Periodical data backup is recommended. The following types of data can be backed up: FILE: Includes files created by Pocket Word, Pocket Excel, Notes etc. or an additionally installed program. REGISTRY: Setup information of Windows or programs. DATABASE: Database information from Pocket Outlook. When making a backup or restoring data using the DataBackup program please DO NOT remove the Compact Flash or Secure Digital card from the Pocket PC e740 and DO NOT turn off the power to the device until the backup or restore is completed. Backup Instr
Sep 07, 2005 | Toshiba e740 Pocket PC
Computers & Internet Logo
142 people viewed this question
David Payne
David Payne
