Programming AUX as a channel.
This is my Dad's tv. It has an input on the back for AUX and we've hooked up a new dvd/vcr to it. The tv remote is gone. With the buttons on the tv, I can access the menu and can get to the aux screen but I can't get the channel lineup to accept the aux selection. I have to mannually select the aux from the set. I want it so he can select channel 2 and then channel down 1 time to Aux.
  • flashbear Apr 01, 2008
    I have a universal remote that works the t.v. but I still can't get it to accept the Aux. as a channel so he can go from chan. 2 down to Aux..
    Thanks for trying anyway.
    Sergeant:
    Champion:
  • 375 Answers
Pick up a universal remote
Posted on Mar 28, 2008
Cannot change my TV to allow my new DVD/VCr to work
u can buy universal remote control for this options.
it will help you.
thanks.
Oct 28, 2008 | Televison & Video
I need to know how to hook up DVD player with Cable TV I have the cable with the white yellow and red. I hook one end into the TV and one into the DVD player. I don't get a pic or sound. I do not havethe...
The key is having at least a Universal Remote ($10.00 or less) that will operate your brand of TV. Your TV is only looking at "stations". You need to make it see Aux-1, Aux-2, or Line In mode. BUT, another trick is to run the DVD into your VCR (if capable). Select the VCR proper "input mode" (Aux-1, Aux-2, or Line In mode) then the DVD will play through the VCR and it will play through the TV on either channel 3 or 4. Problem solved!
Jun 27, 2009 | Sony DVP-NS501P Progressive-Scan DVD/CD...
Need the remote code for a phillips dvd player
These are the codes printed in the owners manual for your dvd/vcr player.If they do not work you will have to contact Emerson and ask them for help getting the code. The contact number should have come with the instructions for the remote. Just give them the model number of you remote and the units model number and they should be able to help you. I hope this information helps you with your problem. Switch the input selector on your TV to an appropriate external input channel (usually near channel 0).
Press a button on the TV’s original remote control that selects an external input channel until the DVD
recorder’s picture appears. Check your TV owner’s manual for details.
Admiral
Curtis Mathis
GE
Hitachi
JVC
Kenwood
LXI-Series
Magnavox
AUX
LINE1, LINE2, 00, 90, 91, 92, 93
INPUT, TV/VCR, 00, 90, 91, 92, 93
INPUT, AUX
VIDEO, VIDEO 1, VIDEO 2, VIDEO 3
AUX
00
AUX CHANNEL
Input Mode Names for Common TV Brands (Example)
Panasonic
RCA
Samsung
Sanyo
Sharp
Sony
Toshiba
Zenith
TV/VIDEO
TV/VIDEO
VIDEO
00
VIDEO1, VIDEO2, VIDEO3
TV/GAME
00
Apr 25, 2009 | Philips Magnavox MWR20V6 DVD Recorder/VCR
Hooking up dvd player
Look for any button either on the unit or the remote marked with common stuff like A/V, Input, Source, Aux or Au, Line, TV-VID. or try dialing in Channel 0, or 00, or 1, or Channel Down surf below Channel 2. Alternately, get into the menu and look for stuff concerning Auxiliary inputs.
If all else fails, you can run a DVD's audio and video line-signals THROUGH a VCR. Hookup the VCR to the TV's RF (threaded) connector using standard coaxial cable. Hookup the DVD a/v output lines to the Line-ins of the VCR. Tune the TV to Ch. 3, tune the VCR to Line-in or Auxiliary and press the play or tv/vid button on the VCR to force the DVD signal through on channel 3 onto the TV.
Jan 25, 2009 | Disney 13" TV
Connect tv vcr and dvd player to digital converter box
Yes you can first connect the converter box to the antenna first. Next hook the tv out on converter box to vcr in on vcr. Next hook the vcr out to the tv in and watch vcr and converter box on channel 3 sometimes channel 4.on the actual tv and of course change channels with converter box remote. For dvd player hook it straight to tv with red,white,and yellow cables that come with your dvd player. Then to watch dvd player if it's hooked up that way you have to put your tv on a input like video 1 or input 1. This can be done by using the tv remote and looking for a button that says tv/video or input or source button. This is some common names for that button on tv remotes.
Nov 02, 2008 | Insignia Digital-to-Analog Converter for...
No remote for small Orion TV - Input mode?
did you figure it out? i am trying to get my orion tv1333 to go into aux mode without a remote. thanks.
Sep 16, 2008 | Orion STV2763 27" TV
Rca vcr
there a a bunch of different ways. 1) if you don't have a cable box hooked up to this tv,plug the main cable wire into the vcr input then the vcr outout to the tv.2) if you do have a cable box, plug the main cable into the cable box input, then the output to the vcr input, then the vcr output to the tv. put both the tv & vcr on channel 3 for this connection. [ you must have the vcr on channel 3 to record from the cable box!] 3) if you have aux line/video or source inputs on the back of your tv,you can hook up rca cables [ red, white,& yellow ] from the rca outputs on the vcr to the tv inputs.
hope this helps
wg
Feb 04, 2008 | RCA VR637HF VHS VCR
How to set the telelvision to use a dvd,
when you ran the autoprogramming it scanned all the channels you are receiving.the dvd is probably plugged into a line or aux input on back of your tv.look for a input or source button on the remote. some tv's have more then 1 input source so be sure to scan thru all input choices.also if it is a dvd/vcr combo & if there is a coax out connection to your tv coax/rf input the tv and/or cable box should be on channel 3
hope this helps
w.g
Jan 28, 2008 | Philips 19PR19 19" TV
Can't get TV onto the AUX channel
You can purchase an RCA universal remote that will let you access the A-V inputs. These only cost about $10.00 or so. Stargazer
Sep 09, 2007 | RCA F25254GY 25" TV
Televison & Video Logo
826 people viewed this question
Top Televison & Video Experts
