Siemens 587/advent 7096
Unable to connect siemens 587 and advent 7096
  • vixens Mar 28, 2008
    when i try to setup my siemens 587 router to my advent 7096 laptop i get the error mesage wrong wpa key i know that cant be correct as i am reading straight from the router
Hey i want to know wthr this router is locked for Tiscali. coz when i try to enter my ISP which is SLT.. the adsl light is off. it never lits up
Posted on Nov 28, 2009
Siemens 587 router is very strange about the wpa key
The wpa key is 12 characters no more no less the router doesnt seem to proccess it properly if it is not 12 characters eg 0123456789AB it seems to add extra junk chars to get it up to 12 so it initally works then drops out
The wpa key is always case sensitive
The router ip address is 192.168.1.1
standard username and password are admin
login page is not always displayed depending on firmware version
wpa key can be found under WIRELESS -> Wireless Security
there used to be an emulator used by the tiscali scottish call centres on the web
but page no longer displayed just a merry christmas from tiscali
Posted on Oct 19, 2008
  • 432 Answers
The router and the laptop read the WPA key differently. Your router may say "1A-2B-3C-4D-5E". On your laptop you need to type in "1A2B3C4D5E". Also can be typed in as"1A:2B:3C:4D:5E". You'll need to type in the again until you get the right format. As an example, my router is set to 64bit WPA and reads :1A-2B-3C-4D-5E". In WindowsXP I had to type in"1A:2B:3C-4D-5E". If this doesn't help, let me know and I'll try to walk you through it.
Posted on Mar 28, 2008
  • 44 Answers
Hi ,
If the problem is the wrong key entered then you should just modify it in the Access Point settings. Access Point settings can be accessed as Below.
In Tools->Settings->Connections->Access points
delete it then create a new one, or modify it !
Kindly give a feed back for this.
Thanks and regards
Which buttons do i press to turn on the internet on, on a dvent net book
Hi
do you mean to enable the wireless switch so that you can use the internet
as you have not told us which model you have i can not tell you where the switch is
please try some of these options if your model is mentioned
Advent 7086 ---- Button next to the power button
Advent 7096 ---- Button next to the power button
Advent 7100 ---- Fn / F2
Advent 7104 ---- Fn / F2
Advent 7201 ---- wireless key top right and then Fn / F2
Advent 8117 ---- small slide switch on the front of laptop
hope this has helped you
many thanks
Aug 17, 2011 | Advent Netbook
I can't switch on my HCL laptop's wifi
Hi
There are several models of Advent laptops and as you have not told us
which one it is i have included a few of which maybe one of them will be yours i hope
hopefully one of these options may help you to activate your wireless switch
good luck
please let us know if this helped you
so that we may be able to help others
many thanks
Aug 16, 2011 | Advent Netbook
Unable to find wireless switch on Advent laptop. There is a key combination like Fn + F10 but I cannot remember which.can you tell me?
Hi Friend,
Please find the key combination (for wireless/switch) for different Advent laptop models:
I hope this will resolve the issue.
Regards
Chiranjeet
May 20, 2010 | Computers & Internet
Getting 3 long beeps when switching on
could be a number of things that cause the beeps.
it sounds like it could be a fault with the graphics, the best advice is to have the fault properly diagnosed at a reputible repair center
Dec 09, 2009 | Computers & Internet
I have a advent 7096 after reinstalling windows xp media centre also the added install for wirefree card when thats done the wirefree works for about a minute and it then shuts off and i cannot get it to...
First login to BIOS and leave it as it is, if system crashes unfortunately, it is a possible hardware issue. Else used msconfig, disable all non microsoft services and startup using msconfig. Also try a BIOS default (most possible by pressing F5 on the BIOS). Also disconnected any peripheral connected. Also try creating a new account. also try in safe mode
Nov 21, 2009 | Computers & Internet
Need recovery discs for advent 7096 laptop
Visit the following site:
http://www.uktsupport.co.uk/advent/laptop/7096.htm
You will find the information under "Recovery Disk" section.
Nov 02, 2009 | Computers & Internet
Pvc selection keeps changing to dial up mode
  • delete the dial up connection on the internet option
  • click tools-internet options on the internet explorer - click connections tab, delete all dial up on the box, and select never dial a connection
Aug 04, 2009 | Siemens SpeedStream 2624 Router...
Linksys WMP45G will not connect to wireless modem
well!! I have an answer for you.your comp is loosing the IP address.
goto start - programmes - accessories - dos prompt.
type ipconfig.you`ll get ip address,subnet mask,default gateway.copy it.
goto network and sharing center,click on view status,goto propertiesand double click on internet protocol(tcp/ip) or IPv4.type in the IP address,subnet mask,default gateway.in DNS server address type the default gateway in primary DNS and in secondary 4.2.2.2.
ypur connection won`t drop after this.
Jun 09, 2009 | Linksys (WMP54GS) 802.11g/b Wireless...
Configuring Laptop for Flat TV S-Video Connection.
Greetings,
Connect the second monitor to the blue VGA port. Download catalyst control center from the below link and install it. Using catalyst control center, you can configure dual monitor. You may need to check 'force tv detection' setting in catalyst control center.
https://a248.e.akamai.net/f/674/9206/0/www2.ati.com/drivers/9-3_xp32_dd_ccc_wdm_enu.exe
Revert back for any clarifications.
Warm Regards,
Zulfir Sadat M
Apr 07, 2009 | Computers & Internet
Computers & Internet Logo
368 people viewed this question
David Payne
David Payne
