Question about Refrigerators
Jenn Air Frige problem
Every time I open the door (doors) of my Jenn Air I smell a chemical smell. Would it be Freeon leak?
  • 68 Answers
Check if it's internal body is not tempered. Often sharp edges of dishes, knives or other things causes damage to the internal plastic walls and the internal gases come out. It may be due to compressor's malfunction. Check the compressor if it is hotter than usual.
Contact me again so i may help. Don't forget to vote me
Posted on Mar 28, 2008
  • Faheem Safdar
    Faheem Safdar Mar 28, 2008
    Don't check the compressor with bear hands. ok
Had a problem with voltage (edison) smelt something burning while micro-wave was in use. now the lite+time works but nothing else. jenn-air jmc813odds
If you open the door of the microwave can you smell an odd odor? if yes the magnetron is probably fried "heats food" the other parts that need to be checked are the high voltage capacitor and diode. I recommend appliance repairman or tv technician to further check with an estimate.
Jan 30, 2011 | Jenn-Air JMC8130DDS Microwave Oven
Water slow ice not thick
if you have a side by side frige thin wen you open the door on your frige side thare shud be two diles one for the freezer and one for the other thurn the one that has freezer two the rite intell it gets on 5 or wen it gets to max and if its a reguler frige then and it a new one then its in the freezer part if its a older one thin there both in the bottom frige an torwds the roof of the inside if that dont work have your filter cleaned and ask a frigeration company geve you a shot of freeon in it
Dec 16, 2009 | Dishwashers
Kenmore side-by-side has CHEMICAL SMELL ODOR inside.
You have a freon leak. With this only being 5 years old, iot's probably worth repairing, unless you are just able to buy a new one. I would have a local tech come out and check it before tossing it. I hope this answers your question and gives you some resolution. I hope to work with you again, so please record our name, email and phone number for future needs. Have a great evening!
Sep 09, 2009 | Kenmore 53642 / 53644 Side by Side...
Water is leaking from the bottom in the front left side of side by side maytag. water line is ok not leaking. can't see where it is coming from.
the water for the dispenser (ice/water dispenser in the freezer door) comes from under the frige then up thru the bottom hinge of the freezer door .. it then goes inside the door up to the dispenser .. its a plastic hose and it has to twist near the hinge each time the door is opened .. thats where it usually breaks or develops a pin hole leak .. you can replace the whole hose or just the damaged section if that easier ... since the bottom freezer.hinge where that hose comes up thru, is at the position of your leak then i suspect thats your trouble ... ..also check the condensate pan to make sure its not full .. thats a flat pan under the fridge can usually get acess to it by removing the front kick panel at the bottom of the frige .. if thats full then look for a door seal leak (damaged rubber seal) ... a broken seal or open door will allow moisture to condense inside the machine ..that runs down into the condensate pan where it normally evaporates .. but a problem (like open door) will fill it up to overflow in time ....
Aug 05, 2009 | Maytag Refrigerators
Refrigerator door doesn't close and seal. Nothing is blocking it.
make sure big compartment door on frige side is completely closing and not holding door open
Apr 11, 2009 | Jenn-Air JCD2389G Side by Side...
Jenn-Air electric wall oven door opens slightly when in bake mode
you either have a bent door hinge or a broken door spring.
check the hinges by opening the door and see if it opens past 90 degrees. if it leans towards the floor then the hinges are bent.
if not then your door springs are broken off. you can check this by seeing if the door "feels" heavy when opening.
either way the door should close tight against the frame when up and the light should not come on without opening the door.
Jan 22, 2009 | Jenn-Air 27 in. Electric Single Wall Oven...
hi thanks for the question the freezer is more than likely frosted up now with the door left open the drain hose from freezer is clogged shut down let thaw remove panel at the back of fridge allow 24 hrs to thaw clean out the drain tube re level the fridge so that if the door is left open the door will close by its self raise the front legs to achieve this thanks the appliance doc
Aug 12, 2008 | Jenn-Air JCD2389G Side by Side...
Jenn air jcd2389g side by side refrigerator water leak
sounds like a leak where your incoming water line hooks to the water valves might just need to tighten the coupling or a mouse has chewed through one or both of the lines access the lines on the back and watch while some one gets water out the door to locate the leak
Feb 11, 2008 | Jenn-Air JCD2389G Side by Side...
Jenn-Air 30 in. Electric Wall Overn jjw8530ddw
lendebr is right...
Same problem here on combo microwave and convection oven. The hinges are a horribly wimpy design. Jenn air has a replacement part thats helps..but the replacment hinges will do the same thing in very short order. 1 month after I fixed ours my sister in law opened the oven door and let go of the door when it was about 2/3 open and that was all it took to tweak the new hinges so the door doesnt close all the way again. i should have clued in when the girl at Jenn air sent me three sets of replacement hinges. I thought it was a mistake..turns out she knew it wasnt going to fix it permanently.
The moral is that Jenn air appliances are POS and I will not ever buy anything from the again..But I will tell everyone I possibly can not to buy anything from them.
Jan 08, 2008 | Jenn-Air 27 in. Electric Single Wall Oven...
Refrigerators Logo
199 people viewed this question
Top Refrigerators Experts
Charles T Nevin
Charles T Nevin
John Tripp
John Tripp
