Question about Apple MacBook Air
Macbook air is locked and i don't know how to reset it?
    Guru:
  • 206 Answers
Font.f1 {font: 12.0px Helvetica} Thanks for asking your question with Fixya Support. I will be glad to assist you.
If you are referring to locked in regards to your user administrator account, all you have to do is take your Mac OS X installation disc and run the Password Reset utility to reset your password and gain access back into your Macbook Air once again.
Here are some steps you can try to resolve the issue:
BOOT TO TIGER/LEOPARD or SNOW LEOAPRD DISK-
• Place your installation Disk (Tiger, Leopard or Snow Leopard) into your drive and
allow it to load.
• Restart your Mac
• As soon as you hear the Apple Chime, press the "C" key on your keyboard
and hold it.
• You will see a White Screen, Grey Apple first, do not release the C key until you
see a Spinning gear.
• Once you see that Spinning gear, release your C key and allow the disc to
continue loading
- RESETTING ADMINISTRATOR PASSWORD-
(Works for both Mac OS X 10.4 (Tiger) and Mac OS X 10.5 (Leopard))
• When the booting to the Mac OS X disc is completed, you will now be in the
Installer environment
• Enter to next page, look up on upper left corner you should see "Installer" near
the Apple menu.
• Two spaces over you should see Utilities. Click Utilities>Reset Password.
• Select your user name from the drop down list and reset your password.
• When you are done, simply exit the Reset Password and Installer and reboot.
• At the Login window, enter your new password and you should be back into your home profile.
Let me know if this helps!
Thanks!
Regards,
-Mactechtrainer
Posted on May 12, 2010
Locked
Resetting the PRAM may do the trick:
You reset the PRAM by rebooting a Mac and then immediately hold down the Command+Option+P+R keys, you will then hear the Mac reboot sound again, signifying your PRAM has been reset. You must hit the key combination before the grey screen appears otherwise it won't work.
you've tried rebooting, you've reset the PRAM, you've done it all, but your Mac is still behaving strangely. What next? In certain circumstances, resetting your Mac's System Management Controller (SMC) can be a solution. This is sometimes necessary to restore normal lower level system functionality to your Mac.
Here's how to reset the SMC on any type of Mac (and any version of OS X) and the type of problems that it may resolve.
When & Why Reset SMC on a Mac? Some Common Hardware Reasons
Typically it's power and hardware related issues that can be helped or resolved by resetting a Mac SMC, particularly if you're having these types of problems:
* Issues with your Mac's cooling fans and fan management: fans run constantly at high speed, fans run high despite low CPU usage and adequate ventilation, fans not working at all, etc
* Power management and battery problems: Mac isn't turning on, sleep isn't working, random shutdowns and reboots, battery isn't charging, Mac won't wake from sleep etc
* Light problems and improper lighting management: battery indicator lights aren't working, display backlighting isn't adjusting to ambient light changes, keyboard backlights not working, etc
* Video and external displays not working: display brightness functionality not working properly, target video mode isn't working properly, external display isn't working, etc
* General performance and functionality problems: abnormally sluggish behavior despite no CPU or disk usage, external ports not working, airport & bluetooth aren't showing up, external devices are not being found, etc
So now that you've concluded you need to reset your SMC (Note that the SMC is on Intel Mac's only), here's how to do it on MacBook's, MacBook Pro's, iMac's, Mac Mini's, and Mac Pro's. Notice that the reset instructions are different for MacBook and MacBook Pro's if you have an internal or detachable battery.
Reset SMC of a MacBook Air, MacBook Pro Retina, or MacBook Pro's with an internal non-removable battery
This is how to reset SMC on most modern Mac laptops:
Shutdown your MacBook Air / MacBook Pro
Connect the power adapter to your Mac
On the MacBook/Pro's keyboard, hold down the Shift+Control+Option keys and the Power button at the same time
Release all keys and the power button at the same time
Boot your Mac as usual
Here's the key sequence to hold down:
Reset the SMC of a MacBook Air or Retina MacBook Pro
Do keep in mind that by resetting the SMC you will lose power specific settings, like the time it takes to sleep a Mac and other customizations to power settings. No big deal, but if you have made many changes to your hardware behavior you will want to adjust stuff like sleep behavior again.
Reset SMC of an iMac, Mac Pro, Mac Mini
Resetting SMC is different for non-portable Macs:
Shut down your Mac
Disconnect the power cord
Press and hold the Mac's power button for 5 seconds
Release the button
Reattach the power cables and boot the Mac as usual
Reset the SMC of a MacBook or MacBook Pro's with detachable batteries
mac reset the smc Older MacBook laptops with a removable battery can reset SMC with the following approach:
Shutdown the MacBook/Pro and remove the battery
Disconnect the power adapter, hold the Power Key for 10 seconds
Release the power key and reconnect your battery and power adapter
Turn your Mac on
Let boot as usual
Hopefully that will clear up your problems, if not it might be worth a visit to the Apple Store or a certified repair center.
Happy New Year,
Kerry
Feb 23, 2014 | Apple Air Computers & Internet
Baclight not working some water inside keyboad
sorry no fuses on mac, if water gets into any electronics put the entire unit into dry uncooked rice. check the apple website for resetting the EMC, this might help
Feb 03, 2014 | Apple Macbook Air 13 Intel I5 4gb Ram...
How i reset apple macbook air 4 digit pin code
Follow these Simple steps to reset your Apple MacBook Air - http://www.ehow.com/how_6934095_reset-macbook-air.html
and share any Mac problem with Apple Customer Service for help.
Apr 19, 2013 | Apple MacBook Pro Notebook
Hello:
1) What model and what year is your Macbook Pro?
2) What country are you in?
3) Is your Macbook still under warranty? That is, can you call Apple or send it to Apple for repair if you have to? Because on some Macbook Pros, only Apple can reset the EFI PIN
How do i bypass macbook air master password without a disk
Maybe the owner's manual might make reference to some sort of reset option. If the password is a simple 4 digit code, then guess it. Most peoples' passwords have something to do with the person who set the password, I.e. a nickname, name of a family pet, anniversary date, etc.
Nov 17, 2012 | Apple MacBook Air Mac Notebook
My apple macbook air shows a question mark when i turn it on
Shut down your Mac
Release the button
Turn your Mac on
Let boot as usual
Happy New Year,
Kerry
May 22, 2012 | Apple MacBook Air
My MacBook pro is asking for a system lock pin how do I bypass it because I don't know the pin
You can reset your password with the OS disc. Reboot using the disc and choose Reset Password from the menu bar.
May 20, 2012 | Apple MacBook Pro Notebook
I have a used macbook pro and I don't have the
There are two options you have. You can either acquire an OS (Operating System) disc to reformat the drive and reinstall the OS or you can return it to first user using the Single User boot mode.
The first option is easiest and erases their data so you don't have to worry about it being there.
The second option requires knowing some basic terminal commands.Final note: Have you tried just pressing enter on the login screen? Many times people don't have passwords but it will still ask for them.
Jul 25, 2011 | Apple Computers & Internet
Hej. Yesterday, suddenly my Macbook air´s keyboard and the touchpad started not to react. I didn´t do anything, just let my laptop on the tabel for 5 min. and when I came back, it wasn´t...
when your keyboard and touchpad are not working, try to connect an usb mouse and keyboard to the laptop, just to be sure the system is responding.
if the usb devices work, you can be pretty sure there is an hardware problem. if the usb devices don't work too, maybe the system got stuck, and the best thing to do is a system reset
How to Restore MacBook Air to Factory Settings
if the usb devices work, give a try to the apple hardware test to see if it detects anything.
Using Apple Hardware Test
i had a similar problem a few years ago.. if it's an hardware problem you will need to change all the top case
MacBook Air 13 Top Case eBay
Jul 30, 2017 | Apple MacBook Air
Apple MacBook Air Logo
776 people viewed this question
Top Apple Computers & Internet Experts
Paul Carew
Martin Buck
Martin Buck
Paul Bade
Are you an Apple Computer and Internet Expert? Answer questions, earn points and help others
