Question about Microsoft Windows XP Professional With Servise Pack 2 (e8503040) for PC
Installing a program
Trying to inatall a program thats works good on 2 other computer that I tried 1 running XP home and 1 running Vista works good. I am now trying to install on XP pro and get, " can't run 16-bit windows program" can you help me
  • Microsoft Master
  • 5,569 Answers
MS is trying to kill off older software to reduce problems with later OSs but your problem might be touched upon in this discussion:
http://www.tek-tips.com/viewthread.cfm?qid=760343
Posted on Mar 28, 2008
SOURCE:
Running windows vista service pack 2 but quicken 2014 won't open
One solution would be to run it pretending your Vista is XP. I have seen it done but as I have no Vista machine, I cannot tell you the steps. Search for running Vista in XP mode - once you have managed that, try installing the software.
The second solution would be to open a virtual machine on Vista and running that as an XP machine. Again, I have seen it done.
Try the links I have added below.
The problem I had was with Quickbooks, not Quicken, but the principle is the same and worth a try. Good luck.
Use XP Compatibility Mode in Windows Vista Win7 Vista Windows XP Compatibility Mode in Windows 7 and Vista
Feb 13, 2014 | Intuit QUICKEN 2014 DELUXE
Will not function with Windows 7, what is wrong?
Not all programs that worked in Windows XP will run in Windows Vista or Windows 7.
I suggest you try compatibility mode to see if it helps.
If the program is not compatible, then you may try to install and run the program in compatibility mode.
Use the following steps:
1) Right click on the Program
2) Click on Properties
3) Click on Compatibility tab
4) Select Run this program in compatibility mode and select Windows Vista or whatever operating system the program was running successfully.
Refer to the link here: Make older programs run in this version of Windows
http://windows.microsoft.com/en-us/windows7/Make-older-programs-run-in-this-version-of-Windows
If the compatibility is not successful, then try and runthe Program Compatibility troubleshooter:
1. Open the Program Compatibility troubleshooter by clicking theStart button.
Then click Control Panel. In the search box, type troubleshooter, and then clickTroubleshooting. Under Programs, clickRun programs made for previous versions of Windows.
2. Follow the instructions in the troubleshooter.
If you cannot install a program, insert the installation disc for the program and, using the troubleshooter, browse to the program's setup file, usually called Setup.exe, Install.exe, or something similar. The troubleshooter is not designed to work on programs that have an .msi file name extension.
If you run Windows 7 Professional or Ultimate version, install Windows Virtual PC and Windows XP mode (http://www.microsoft.com/windows/virtual-pc/default.aspx) and execute your software in Windows XP.
If you run Windows 7 Home Premium, try VirtualBox (www.virtualbox.org) or VMware Player (www.vmware.com) and install a separate copy of Windows XP (either Home Edition or Professional) for that purpose.You can find virtualization software free of charge that will run on Windows 7 Home Premium.
Hope this helps.
Oct 28, 2010 | MGI Software PhotoSuite 3 for PC
MasterCook 6.0 will not open up
It Took Me About 40 min. to figure it out
1. install master cook 6.0
2. open sierra on c drive c:\sierra\mastercook6\program
3. delete msvcp.dll file
mastercook 6.0 will now run
there will be no cookbooks
1. goto file\open add it will list all the cookbooks
2. open each one and then everything works as normal
Apr 11, 2010 | Sierra Master Cook Deluxe 5 Full Version...
I had my comp. fixed and they put windows vista home premium on here and i can't play my old games that need xp what can i do
You can do 2 things:
1 - try to run them in XP mode  - right click on its icon, then Properties, then Compatibility, check 'Run this program in compatibility mode for' and select Windows XP in the drop down menu and finally at the bottom of the compatibility tab, check 'Run this program as administrator'.
2 - install http://www.microsoft.com/windows/virtual-pc/ , configure it and in it install XP and all the soft with problems, starting with the games.
Mar 07, 2010 | Microsoft Windows Vista Home Premium...
CAN'T INSTALL PRINTMASTER GOLD 10 ON VISTA COMPUTER
Maybe your edition of Vista is more bugged?
Try updating...
And take caps off. That's called flaming.
Jul 11, 2009 | Microsoft Windows? Vista Home Premium...
HP 4470c flatbed
If you can get the software onto your computer, try right clicking on the scanner program--properties--compatability tab--check "run this program in Xp compatability". Worked for me in Vista
Jul 06, 2009 | HP Scanjet 4470c Flatbed Scanner
MASTERCOOK COOKING LIGHT INSTALATION PROBLEM
When you purchased the program was it designed for win98, xp, or vista?ti sounds like you may be using an incompatable OS. What exactly is a PEN 4? is it something to write on the screen? The software may be picking the pen up and doesn't support the pen.. try unplugging it if it is a PNP item.. You may want to goto the software site and see if there is an upgrade or a patch that you can download Hope that helps a little at least
May 20, 2009 | Computers & Internet
We have a windows vista computer and a game which we havent installed yet because we were wondering if it might damage the game or computer because on the minimum requirments it says that the computer must...
the worst that could happen is that the computer may not run the program. try installing the game, your cd (assuming that's the source of the setup files for the game) should not be affected.
after you install the program try to run it as usual by double clicking the icon to run the program if it doesn't run as expected try this.
1. right click the icon you use to run the game.
2. select properties
3. select the compatibility tab and select an appropiate mode. (ex. windows xp service pack 2)
not completely sure but you may also want to try to run the installation/setup program by changing the compatibility mode so you may be able to trick the program into believing the app/game is being installed on a windows xp service pack 2 system increasing your chances to have the installation running properly.
Sep 27, 2008 | Computers & Internet
Installing AT&T communication manager for data card conflict
Dear sir/madam,
The more you go in to alter settings and programs in your
DELL, them less likely they will be to honor the warranty. Having said that, one
thing you can try IF you have a restoration disk of any kind, is to try to repair
the boot files and sequence. you can use one of two methods. You may get a handy
utility called "VistaBootPro" that does the job very nicely or follow the link below
to MS and run their bootrec scheme. click this link for more information to how to boot to update
windows update.
http://support.microsoft.com/kb/927392
Thanks
good luck
Don't forget to rate the solution
Jul 27, 2008 | Microsoft Windows Vista Home Premium with...
Software compatibility
Hi san, many of vista's problems can be resloved by useing there combatilty mode, its in the properties if you right click on the programe. Make sure to click "Run this program in XP SP2" and "run as administaror" are checked. Good Luck
CoDoc
Dec 11, 2007 | Microsoft Windows Vista Ultimate Edition
Microsoft Windows XP Professional With Servise Pack 2 (e8503040) for PC Logo
Top Microsoft Computers & Internet Experts
Ekse
Alun Cox
Are you a Microsoft Computer and Internet Expert? Answer questions, earn points and help others
