Question about Dryers
My dryer stopped spinning and will not start again. I have been hearing a small screw tumbling inside when dryingbut its been like that for some time and never stopped spinning.
  • 269 Answers
It sounds like that screw has finally done its damage and got trapped in the end of the drum the drum would normally have to be removed to free it off.Can you turn the drum by hand if so then it would be advisable to check the drive belt if thats ok then it may be the motor or the capacitor of the motor.
Hope this helped.
Posted on May 12, 2010
Maytag neptune dryer heats but wont tumble
When you spin it by hand, is there resistance? Can you hear the motor turning? In fact, when you switch it on and it starts to heat, can you hear the motor turning, or is it silent?
Sounds like the belt is broken, in which case there will be little resistance.
If there is resistance, it may be the motor or circuitry controlling the motor.
Aug 24, 2015 | Maytag Dryers
Not spinning
A dryer has a lot of parts to make it heat, tumble and blow air. If it quit tumbling there are many things that could be wrong. You could start with checking the thermal fuse or belt switch or door switch, from there your into timers and motors. If you have electrical experience go for it :-) unplug first ;-)
Aug 02, 2014 | Whirlpool Dryers
Pressed reset button on left hand therm0stat dryer runs but still error code f10 elements not getting warm
I found this, an answer already posted on Fixya.....
If you remove the back cover of the drier with the appliance un pluged, you will see the heater bracket.
un screw this from the back panel, and at the top you will see three thermostats. There is a brown one with a small hole in the middle, if you use a pin and press in, you should hear a click. This resets the thermostat and you should be able to use the drier again.
Dec 12, 2013 | Hotpoint Dryers
Dryer does not spin easily. stops in mid cycle, sometimes makes whining sound, and does not start without rotating drum by hand first.
It is an electric tumble dryer? Most likely it has a faulty capacitor. This electrical component energises the motor on starting. It is usually located next to the motor, a small white cylinder shaped object, with 2 or 4 connections on it. very simple to replace. In Australia, the capacitor costs around $AU30.00 only.Hope this fixes your problem.
Aug 18, 2010 | Amana Dryers
How can i fix my indesit is70c tumble dryer? my indesit is70c tumble dryer wont heat up during performance
open the back panel , not the the full back just the smaller panel located near the bottom half.
the termo will be screwed onto this panel . unscrew and you will see two circles near the top one will have a small pin hole in it . stick a pin in till you hear a click replace and should work fine
Mar 05, 2010 | Dryers
Dryer wont tumble
i think the belt is slipping bad on your dryer,,
what puzzels me is you say you can here the motor hum? is it a hum? or a buzz?? if its a buzz then its more likley to be the motor as its past its best and it needs if it needs a new motor as well, it would work out cheeper to buy a new tumble dryer
Nov 16, 2009 | Dryers
My Danby dryer dcd5505w hums but wont tumble. I opened it up and pushed it and it ran for a bit and stopped. I pushed it again and it ran for about 3 minutes before stopping. The motor is okay and so is...
the motor is most likely the cause. once it starts to hum, it's not spinning :( bad brushes inside. replace the motor or get new dryer, sorry :(
Joe
Aug 26, 2009 | Danby Dryers
Won't run
If "won't run" meaning; "does not tumble/spin" this can be a couple things;
1. Defective Drive Belt (Likely): Broken or jammed (not properly attached to motor/pulley). Nothing will happen when pressing start; unit will not heat or rotate/tumble. "Normal ware and tear"
2. Defective Door Switch (Very likely) - Very common due to constant "slamming" of door. The door switch enables power to be passed through-out machine when door closes for safety purposes. Switch located at door area and can be tested for continuity. "Nothing will happen when pressing start; unit will not heat or tumble/turn". * Fairly easy to replace; two mounting screws.
3. Defective/Jammed Motor (Rare, but possible): You may hear a "humming noise" and burning smell. Also, excessive lint in blower housing may jam the motor from rotating. "Does not come on; does not tumble/turn"
Remember to disconnect power from unit before servicing.
Jan 27, 2009 | Kenmore 659 Electric Dryer
How to fix Hotpoint CTD00 Tumble Dryer?
http://www.fixya.com/support/t232066-hotpoint_ctd00_trips_power
The link above should solve your problem. I have the same problem and my parents who bought the same tumble dryer also had the same problem. Its water backing up to the fan then its hitting the heating element which is tripping the electric off.
At the back of the Tumble dryer near the bottom you'll see a panel that has about 8 screws that you can taqke off as well as a small panel that cover the pivet for the drum. If you unscrew this you will see the fan and heating element and no doubt a small puddle of water and damp dust that has clung onto the panel. You should dry this with kitchen roll and clean the old dust off then carefully turn the tumble dryer on (at your own risk lol) or you can take the advice of the person who posted the link above and use a hair dryer. This will stop the element getting wet and tripping off.
Also there is a water reservoir to the right of the panel i mentioned. If you prise the clips open and remove the top section you will see the water in the reservoir. If you look inside it on the bottom left hand side there is a little **** that the water drains in from. If you use something like pipe cleaners or a knife and wiggle it about you may have some fluff or hair trapped there that is making the water back up to the fan and causing the tumble dryer to trip off.
Hopefully this willsolve your problem for the time being but the filter in the bottom of the dryer needs to be cleaned thoroughly every week or so to stop this happening again.
Personally i think this is a major design flaw and the tumble dryer should be recalled but Hotpoints aftercare service is awful to say the least so lesson learnt, don't buy a hotpoint tumble dryer!
Feb 01, 2008 | Dryers
Dryers Logo
Top Dryers Experts
Dan Webster
Dan Webster
