Question about RCA F36669 36" TV
RCA CTC203 Replaced HOT, Flyback-solder coil and Hor Driver-set powers up and audio w/pix-have "jail bars" on left of screen-(about 4 or five)This set was given to me. I never seen it work.?????? Thanks ,Wayne
    Sergeant:
    Champion:
  • 375 Answers
With your new flyback transformer ther should have had a resistor and cap in the kit.if you look at the fly back from the rear ,on the right side very close to the transformer.and on the other side 3 resistors one has changed value about 38k-ohm.
Posted on Mar 28, 2008
RCA D52W20B Vert/ Hor Hold Problem
Nothing inside to adjust. try re-soldering the vertical output IC and also the flyback connections RCA has had some issues with the flyback solder connections
Feb 23, 2008 | RCA D52W20 52" Rear Projection HDTV-Ready...
RCA 26in.
Bad solder connection..small coil in horiz driver circuit near
center of circuit board....solder both leads even though they
look good..........................T.
Jan 08, 2008 | RCA F27442 27" TV
42H83 Occasional shutdown
Check convergance amp ic and loose connections to the yokes.
Nov 17, 2007 | Toshiba 42H83 42" Rear Projection...
32v434t dead
please go according to procedure 1 isolate h/output section supply. 2 check power supply output is ok if not repaire it. 3 after power supply is ok 4 check hor osc, driver &output if problem repair it. 5 check for loose contact or print break. 6 connect supply to hor section. set will work fine. good luck.
Sep 21, 2007 | RCA 32V550T 32" TV
No raster no audio,Zenith SJ 2065S5
as horizontal transistor gets very hot so no eht so no raster &no sound due to nosupply to vif & tuner. as hor output is getting hot please isolate supply to hor. section & check power supply output is ok as due to high voltage h/outout may get hot & demaged. if supply is ok check for leaky or short parts in hor output. 1 hor. output transistor itself if it is replaced that may not be of proper matching. 2 diode& cap.in eht section. 3 clean print near eht. 4 moisture near yoke due to rain in rainy season only. so keep it hot for few hours. 5 at last if all are ok eht or fly back transformer. re connect power to hor output after rectification
Sep 18, 2007 | Televison & Video
RCA F27669 27"
The F27669 uses the CTC203 series chassis. The most common cause of that symptom is a shorted horizontal output transistor, caused by a cracked solder joint on a small coil connected to that transistor's base. When this happens, the main B+ supply is shorted to ground so the power supply squeels. Every once in a while I also see the horizontal output transistor shorted due to a shorted flyback (high voltage) transformer. A good tech will replace the horizontal output transistor, resolder the coil and drive transformer, test the flyback (replacing it if necessary) and your set will be back to perfect.
Aug 08, 2007 | RCA 27V570T 27" TV
32" model# F32668
The F32668 uses the CTC203 series chassis and I usually see 2 problems when the set will not run. The first is poor solder joints on a small coil near the horizontal output transistor, but if thats the case the set tends to run for a while and randomly shut off. When the set clicks and never runs I usually find that the flyback (high voltage) transformer has shorted out inside. In this case the flyback should be replaced by an experienced tech.
Aug 05, 2007 | RCA F32668 32" TV
31GT740
The GE (actually RCA) 31GT740 uses the CTC203 series chassis. The first thing I would do is resolder the coil on the base of the horizontal output transistor and the pins of the horizontal drive transformer, as well as any other solder joints on the main PC board that look weak or cracked. 9 times out of 10 that cures the symptoms you described. If you do not have experience soldering parts on PC boards then have a qualified tech handle it for you.
Jul 26, 2007 | GE 31GT740 31" TV
56" RCA projection TV (FLYBACK related problem)
the base to emitter of the hot will read short on a diode checker/test on ohms it vairies but typically about 50 ohms.e to c, or b to c should have very high resistance. unsolder the collector of the hot. make sure all solder is gone. now test the ohm between your tuner ground & the pad of the hot collector it should read open.
Jan 16, 2007 | RCA P52921 52" Rear Projection Television
RCA F36669 36" TV Logo
100 people viewed this question
Top RCA Televison & Video Experts
jason
matt martin
matt martin
Are you a RCA Televison and Video Expert? Answer questions, earn points and help others
