Question about Samtron 74V 17" LCD Monitor
I need to check and possibly change which port it is using. Want to use two at once but the monitor recently just flashes wrong resolution.... But is detected by windows 7. Little help please :)
  • 109 Answers
Is your video card capable of dual display?
Posted on May 11, 2010
Occasional odd coloring and backlight flickering
Please check it monitor color adjust button. If ok then you check it monitor cable if change possible then change it or power cable also proper connect. If not solved contact Good Monitor technician.
Thanks.
Feb 17, 2014 | Apple Cinema Display 23" HD Monitor
Out of Range problem with LED 19 inch viewsonic monitor
What is the source for the signal to the monitor? First, if the source is a computer, was the computer previously connected to a CRT monitor? If this was the case, you may have the wrong refresh rate as well as the wrong resolution being sent to the video port. Reconnect the computer to the old monitor (if possible) and reset the refresh rate to 60 Hz.
Next connect the monitor to the computer with both devices off. Then turn on the monitor and set it to the correct input (if needed). Then turn on the computer. Most versions of Windows should determine the best resolution for the monitor. (Some Unix versions and recent versions of the Mac OS will also automatically find the correct resolution.) If you are still getting the out of range message, you need to change the video resolution with a different monitor connected and then retry. Always turn on the monitor first.
For additional support, please add a comment with the specific monitor and source that you have. In a few cases, the video card/on-board video may not be able to output the correct resolution or lose the correct setting when the monitor or computer "sleep".
I hope this helps.
(I've seen most "out of range" messages with several TVs that were connected to computers and turned on and set to the computer input after the computer booted up.)
Aug 12, 2012 | ViewSonic Computers & Internet
Desktop icons stretched horizontally
Sounds like you need to set the screen resolution for the monitor. The computer should recognize each screen individually in the desktop options dialog. If it doesn't recognize the two different screens, you may want to change the resolution when you plug in the monitor.
May 14, 2017 | Computers & Internet
We have a bang and olufsen beovision 7 40 inch tv. when we try to connect our laptop through vga port the tv appears blank without any display, tried connecting the laptop through dvi port also. The...
First, try setting your monitor refresh rate at 60Hz using a known-working monitor. (The VGA input of the Beovision 7 is recommended for 60Hz refresh rate). If this fails to produce output from the Beovision 7, it is very likely, your video driver's resolution is set too high for the Beovision 7 to display signal. If you are using the Beovision 7 as your primary monitor, first connect a known-working monitor to the computer and reduce the resolution to 1024x768. Once you have changed the resolution, try connecting the Beovision 7. If you get video signal, increase the resolution incrementally until you find the maximum resolution the Beovision 7 will handle.
IF YOU ARE USING THE BEOVISION 7 AS A SECONDARY MONITOR USING EXTENDED DESKTOP, reduce the resolution on Monitor 2 output to 1024x768. If video appears on the Beovision 7 at that resolution, incrementally increase the Monitor 2 resolution until you find the maximum resolution the Beovision 7 will accept as a secondary monitor.
Jul 14, 2011 | Televison & Video
Moniter reads no signal but tower light is on
Have you changed your resolution recently? Have you installed any programs recently? Have you made any hardware changes lately? Make sure the monitor is firmly connected to the tower and to the back of the monitor. Is the monitor plugged into the wall outlet? If you have two video ports on the back of the tower make sure you are plugged into the correct one, you may also try switching to the other port. Try another monitor if you are able to or try the monitor on another tower to see if you can isolate the problem to the monitor. Do you get anything appearing on the monitor when you first start the computer up? Have you been using a video card or onboard graphics?
Jan 04, 2011 | Acer Aspire X3400 (2702458) PC Desktop
My cpu is on just i power off the monitor.,series is samsung SyncMasterB1930 is the model., now when i am trying to on the monitor the monitor is not responding it is still power off mode.
First check if the monitor is functional by removing the monitor cable connected to the CPU, once disconnected you should see a onscreen display on the monitor (Keep the power cable intact).
Second check if the CPU is working (not stuck / hung) if you hear the windows logging on sound, then your CPU is fine. If you do not have sound enabled during startup or no speakers then once the system is on give it some time to load windows and then keep tapping the Caps lock or the num lock key, if the lights respond / glow on and off when you press the keys then the CPU is working.
Third check if the CPU has two display ports (in case if you have a onboard VGA and a seperate video card) disconnect it from one port and insert it in another port and restart the computer and see it it works. If you do not have two video ports then skip this step.
Fourth - Restart the computer and keep tapping F8 Key while restarting, in the windows advanced menu choose enable VGA mode or Low resolution video mode (based on XP or Vista/Win 7 the menu changes), if you can see that menu then the issue is with the display settings only. Once in VGA mode or low resolution mode reduce the video resolution settings and restart the computer.
Please revert if you need further assistance, or clarification.
Thank you for contacting Fixya
Jan 03, 2011 | Samsung Computers & Internet
There is no display on the monitor. When I push the power button the display flashes on for three seconds,then goes dark. What can I do?
Hi, make sure leads are fully inserted. could also be faulty graphics card or wrong display settings, can you try it on another computer??
Aug 04, 2009 | Computers & Internet
Monitor comes on a boot then goes black
check video card it may be going out
Jul 08, 2009 | Computers & Internet
Samtron 74V 17" LCD Monitor Logo
48 people viewed this question
Top Samtron Computers & Internet Experts
William Miller
William Miller
Richard Lilja
Richard Lilja
Ted Maxwell
Are you a Samtron Computer and Internet Expert? Answer questions, earn points and help others
