Question about Dryers
Replaced element and thermostats still blowing cold on my whirlpool dryer
  • 269 Answers
I dont know the model but it may be that the safety thermostat has failed or the water tank is full.Or the float switch is stuck.
Hope this helps
Posted on May 12, 2010
Kenmore dryer blows cold air. I replaced heat element still no luck? model 96263800
It doesn't necessarily mean the heating element is busted when an electric dryer stops heating. The heating circuit is not just composed solely by the heating element, it is composed by the thermal cut-off, high-limit thermostat, cycling thermostat, motor centrifugal switch, and the timer. The first thing to look at when an electric dryer stops heating is the thermal cut-off. It cuts power to the heating element when it blows most likely due to the failure of the high-limit thermostat. The thermal cut-off must be replaced, together with the high-limit thermostat, if found open. Click on the link below for the detailed instructions in troubleshooting this problem.
Troubleshooting Whirlpool and Whirlpool-Made Electric Dryers (Filter on Top and with Removable Back Panel) Running But Not Heating
Mar 25, 2011 | Kenmore Dryers
Replaced thermostat and heating eliment still not heating up dryer runs and blows ari just not heating up.
ALWAYS UNPLUG DRYER BEFORE CHECKING
1.loose wiring---check terminals & wiring
2.defective centrifugal switch in motor---replace switch (check linkage to motor
3.defective timer---replace timer
4.open heater element---replace heater element
Jul 31, 2010 | Whirlpool Dryers
Did you replace the safety thermostat I dont know the model dryer you have but on most condensor dryers you would find it at the front bottom right hand side behind a small plastic grid which normally has one screw fixing you can remove this panel and normally get access to this t/stat. you could either test with a meter or link it out just to prove it is the fault.
Hope This helps.
Mar 16, 2010 | Dryers
My dryer is blowing cold air. I replaced the
if you hooked up yhe wires on the heating element check the thermostat it will be a oval shapef unit on housing of element and has wires going to it it may be bad.
Dec 28, 2009 | Washing Machines
My dryer only blows cold air I replaced the
Yes it is quite possibly your thermostats, A kit can be purchased for the majority of all Whirlpool dryers and is around $30.00 part number is LA-1053. But it can vary based on your model. However the first place i would have technician check is the fuses or breakers inside your home as this can often cause the dryer to only run on 110v when 220v is need to run both the motor and the element.Hope this helps.
Thanks
Nov 22, 2009 | Whirlpool Dryers
Blows cold air only
replace thermostat
Apr 15, 2009 | Dryers
Dryer runs but will not heat. Replaced fuse and
your cycling thermostat needs changed too. the thermal fuse is your last safety measure that goes, which means your cycling thermostat is not shutting down the heat element once it detects the right temp hot air in the blower housing so it let the heat element glow until either the high-limit sensor shuts the heat down or the thermal fuse blows. Change the cycling thermostat and good luck
Mar 06, 2009 | Whirlpool LER4634J Electric Dryer
WHIRLPOOL DRYER MODEL LEQ8858JQO
Thermostat, High limit and low limit thermostat or even a safety Temp limiter. All three are similar in cost and located on the back inside of the dryer and 1 by the airflow tube under the lint trap.
Apr 08, 2008 | Whirlpool LEQ8858J Dryer
Dryers Logo
43 people viewed this question
Top Dryers Experts
