Question about Pioneer Premier DEH-P580MP CD Player
STILL HAVIN TROUBLE
IF I DONT CONNECT BOTH YELLOW AND RED, THEN I DONT GET POWER... WHICH COLOR WIRE SAVE THE SETTING.... THE ONLY WIRE THAT DONT CONNET 2 ANYTING IS ORANGE.. AND IT SAIDS ILLUM....
    Brigadier General:
  • 6,966 Answers
"WHICH COLOR WIRE SAVE THE SETTING" - yellow must be connected to an always on B+12 such as the positive terminal of the battery and
red to a switched B+12 such as the ACC terminal of the IGN switch
orange goes to the park/instrument light
Posted on Mar 29, 2008
My S&S camper is generator prewired white, brown, yellow, green wires, my Onan 2500 LP has Blue, Red, Brown, Green, Orange, what do I connect what to???
White Brown green and yellow are normally The 12 volt vehicle lighting colors, not 110 volt power. Generators do not have FIVE wires for the power wires out of your generator. Is this the remote control circuit? If so, I dont have a clue!
Aug 08, 2016 | RVs
1994 honda accord radio wont save settings.
If you have a multimeter or test light, try to find a wire that still has 12v when the key is off. Connect that wire to the yellow wire of the radio. The yellow wire has to have constant voltage going to it to maintain the memory.
Feb 11, 2013 | JVC KD BT11 CD MP3 CAR RADIO IPOD AUX...
I dont know how to hook it up
2 grey 2 green and 2 purles are speaker outputs. one of each color should have a black line. thats usually the speaker negative. blue is remote power out to connect to remote power to amp. red is 12 volt power(+). black is power ground (-) yellow is switched power from fuse block.
Mar 29, 2010 | JVC AM FM CD DET FACE CAR STEREO
JVC stereo not working properly - 2001 Sonata
generally wiring from the car is as follows...
red = ignition controlled live
yellow = permanent live
if you want stations saved and manual switch off of uni connect radio's yelow and red wires to the cars yellow.
if you want stations saved and radiounit switch off controlled by ignition (i.e only when car is running) then yellow to yellow and red to red. anything else will cause issues...
Feb 21, 2010 | JVC KD-R200 Car CD/ MP3 Player
Trying to set the radio stations on Alpine stereo
The radio either does not have the yellow power wire connected(constant 12v) or the wire is connected to a switched source and when the key is turned off the radio has no backup power. You will need to pull the radio out and verify the yellow wire is not connected to switched voltage and connected to constant power. It is also possible that they have the red and yellow wires mixed up. Remember yellow constant power and red is switched power(with ignition key). And also disconnect your negative battery cable when working on the electrical system of your vehicle...you may short something out and damage your vehicle's electrical system or head unit.
Sep 19, 2009 | Alpine TDM-7543
Security Camera
it is important to know model and make or camera if you want a solution
Jul 09, 2009 | Home Security
To wireup 160c Garmin fishfinder, there are seven clored wires. The book shows red and Yellow to hot. Black and blue to ground. Do the white, green and brown connect? Can the black and yellow be connected...
You only need the red and black wires to supply power to the unit. The red positive wire goes to a positive terminal on your battery or positive side of a bus bar or switch, the black negative wire goes to the negative terminal on the battery or negative common bus bar. Do not try to earth the black wire to an aluminum boat hull... You are asking for trouble! Best to run the black wire straight back to the negative battery terminal or negative bus bar that is wired to the negative battery terminal. The other colored wires on the 160C plug are used for interfacing with NMEA2000 compatible devices, like a compatible GPS.
Jun 14, 2009 | Garmin Color Fishfinder 160c
I bought a C80 Raymarine Plotter this has a NMEA pigtail with Brown, Screen, Yellow, Green And White wires I haave also bought a RS 125 Receiver this has a pigtail lead with Red , Green, Yellow, Brown and...
If you have a Raymarine pilot it makes sence to wire it all up to Seatalk. Wire as follows Red to red , silver to silver, yellow to yellow, brown(on rs125) to silver on seatalk buss Green (on rs125) to red on seatalk buss.The above is for the conection between RS125 and C80.
To hook the pilot to system you just need to hook the seatalk lines (red, yellow,silver) from the pilot to the conection with the RS125 and the seatalk cable to the C80.(Color for color).The sea talk connection for your pilot can be picked up from you course computer they are labeld and colored on the unit.
If you are not running a course computer as in the case with the older wheel and tiller pilots you will need to take a sea talk cable and cut it. Once it is cut you will see the red yellow and silver wires and you can tap into there . Remember to connect the cable back together were you cut it. Hope this helps
Dec 15, 2008 | Raymarine C80 GPS Receiver
Sony cdxm610
Red- Constant Power -
Yellow - Ignition power - 12v
Black - Ground
Blue - Ant & memory
Orange - Dimmer
All the wires that have 2 of the same color are speaker wires
ex - green, and green with stripe. The one with a stripe is the Negitive
In most cases the red and yellow need to be together to get the cd player to start if you dont have 2 hook ups for both constant and ignition powers.
The black ground can go to any bolt that is screwed into a metal grounded object. The blue and orange are not needed unless you have a harness that supports the dimmer and memory feature.
If you cd player works with this but wont keep settings or time, hook up the blue to the power so it can constantly save your settings.
All the speaker wires a total of 4 diffrent sets of 2 can go anywhere as long as you dont want to fade or bal your speakers if so you need to test them by hooking up 1 speaker at a time to find out where it leads to. GOOD LUCK
And
Thank you for your question
Aug 04, 2008 | Sony CDX-M610 CD Player
We are having trouble connecting our dvd player to our samsung tv.
couple of ways but the easiest way would be connecting the video and audio out from DVD need rca connections yellow red and white)
Yellow --- Video
white and red is audio out left and right.
find in your tv set inputs with similar colors its going to be input 1
or input 2 (as an example)
once you conect the cable matching colors yellow to yellow red to red and white to white make sure you select the same input on your set (video 1 or 2) that its throu input selection in remote control from tv or set itself.
Jul 04, 2008 | Samsung Televison & Video
Pioneer Premier DEH-P580MP CD Player Logo
111 people viewed this question
Top Pioneer Car Audio & Video Experts
Are you a Pioneer Car Audio and Video Expert? Answer questions, earn points and help others
