Question about Scytek 2000RS Remote Control
Dont know how to work it
I bought a used Kia sportage with the galaxy remote starter in it, dealer could not tell me anything about it, when I lock my doors by hand cause I can't get the remote to do it, it automatically beeps a horn as a alarm is on and when I try to go to my car the horn beeps loudly but I cannot get the remote to shut it off I have to hurry and start car with key to shut off.
  • badsheart Mar 30, 2008
    It is a 2001 but my problem is that the remote wont lock the doors or unlock them, I have to do it with the key or lock by hand but when I push the lock down the alarm automatically sets, also I am not sure what the factory switch is I just have a remote car starter that a previous owner had installed, it has a lock and unlock button on it but does not work except for the car starter, also has a little buttton on the side but not sure what it is for, if it helps the remote starter is a Galaxy with four buttons on top a lock, unlock, a trunk whick dont work cause I have the spare tire over the back whick must be open before the back will open and a star button which starts the car and button on side. if you have any other suggestionns they are much appreciated. thanks
  • badsheart Mar 31, 2008
    All I know is when I lock the doors by hand the horn honks once signaling the alarm went on, also I looked at the wires saw lots of wires and alot of colors but not hooked up as you suggested, so I am still lost, lol
    Problem Solver:
  • 13 Answers
Do not lock doors with facory switch it is setting the factory alarm must shops dont get the factory disarm alarm wire to shut it off.this will always happen use the remote with the remote starter to lock and unlock doors and it should be fine
Posted on Mar 29, 2008
  • 3 more comments
  • Anonymous Mar 29, 2008
    what year is your vehicle
    for 98-02 your wire colors for door lock wires are white/red and red/green in the drivers kick panel you should see a green and blue wires running to these if it was hook up for 05-07 the wires are green and blue these are also in the drivers kick panel
  • Anonymous Mar 30, 2008
    is this the factory alarm that is making the noise.if you leave doors unlocked and remote start what happens?then if you lock doors and remote start does it do the same.also look in driver kick panel and see if you see two wires one blue one green giong to the white with red and the red with green these are the factory wires to hook up to.when i say factory switch im talking about the power door lock button inside car.let me know
    i dont know what happened to the post lets try again is it factory alarm making the noise? if you lock doors from the inside switch on drivers door does it make the noise. also look under dash and see if you see a green wire giong to the white/red wire and blue wire giong to red/green wire they will be giong to the driver kick panel which is just to the left of your feet when siiting in the car
  • Anonymous Mar 31, 2008
    a good stereo shop would hook up the door locks for 35-50 bucks if the plug is in the remote starter to hook up the door locks to it what happens if when you unlock car you turn key to the right twice does it shut off factory alarm or the horn noise you talk about
SOURCE:
Cooling fan starts up when I turn on engine on Kia Sportage 2006
I have two 2006 Kia Sportages and they both do the same. I'm not sure but I think the cooling fan is programmed to start if using a remote starter.
Mar 04, 2017 | 2006 Kia Sportage
"i have a 99 kia sportage i just replaced the
That is a problem for the experienced mechanic
I would start at the battery,all cables,wires ground wires
& look at the alternator output,current & diodes.
Sounds like a module is not getting battery voltage or
could be an issue also
Don't see the starter in that picture unless you had no
problems before it got put in ,then something other
than the starter was disturbed or grounded out by the key
being on etc,sloppy work practice & ruined something
Aug 08, 2013 | 2001 Kia Sportage
How do i reset my new remote control for my alarm immobiliser for my 1997 kia sportage
YOU DONT ,you have to take it to a hyudai/kia dealer and they will recode the KEYS/REMOTES to the car.takes about 1/2 hour max.take all keys/remotes with you.
Jan 11, 2011 | 1998 Kia Sportage
200 Kia Sportage door lock remotes will not work
Did you replace them with the same batteries ? Some people assume all batteries are the same. Some are 3 volts, while others are only 1.5 volts.
Apr 24, 2010 | 2002 Kia Sportage
Reset remote central locking key fob for 2003 Kia Sportage
Should be able to take it apart and take the battery out for 15-30 seconds or longer. Then put it back in. While your at it, you might as well change the battery but doing this will reset it.
Jun 12, 2009 | 2002 Kia Sportage
Just bought a 2001 Kia sportage but don't have the code for the radio. Have taken it out (RC600 Phillips) and the only number anywhere is stamped on top of the radio case - it is 4010200302. Anyone know...
look in dash board for the manual that come with vehicle . it will tell you that you have to give it another code. if you dont have the dash manual .dealer ship get you one.
Mar 09, 2009 | 1999 Kia Sportage
Need key for 2006 Kia Sportage LX
Dealer, and most likely will need to be programmed.
Mar 07, 2009 | 2006 Kia Sportage
99 kia sportage starter
Theres a solenoid on the starter to engage the starter onto the flywheel. The solenoid could be going out.
-Captain Jake
Feb 13, 2009 | 1999 Kia Sportage
REPLACE STARTER IN 1999 KIA SPORTAGE?
at the right side of the vehicle under the battery there is the starter bolted by three screws you need to get under the vehicle to loose the screws use a 14mm socket and wrench to get the bolt loose it takes a bit of maneuvering to get it out of the tight space but it is possible and simply reverse to get the new one in remember to disconnect the battery and the lines to the starter before starting to work.
Nov 27, 2008 | 1999 Kia Sportage
I want to know the code for my radio in my kia sportage
try 1111 if that does not work radio needs to removed for dealer to use reference number on back so they can get code from kia
talk to dealer first.
Aug 24, 2008 | 2002 Kia Sportage
Scytek 2000RS Remote Control Logo
280 people viewed this question
Top Scytek Televison & Video Experts
Ekse
Are you a Scytek Televison and Video Expert? Answer questions, earn points and help others
