Question about ViewSonic VA1930WM LCD Monitor
Can I change the angle of my viewsonic screen
    Problem Solver:
  • 12 Answers
Here is what you can do ergonomically;
Height adjustment range 8.1cm / 3.2", tilt, swivel range 360º
So, yes you can tilt the monitor's angle, but if you are asking about the viewing angles then no you cannot.
Posted on Aug 20, 2010
Plastic cover
How to remove back cover of ViewSonic G71F+. First remove the 3 screws at the bottom , one on each side and one above the VGA cable. Now look for three small slots on the top of the monitor near the screen. From the side opposite the screen insert 2 medium-small flat blade screwdrivers into the center slot and the slot on one side at an angle of about 25 degrees from the top plane of the monitor then gently pry up by pushing the screwdriver handles toward the top plane of the monitor. Once the plastic latch in the center and one side are released move the screwdriver on the side to the opposite side to release that side.
Mar 07, 2014 | ViewSonic Computers & Internet
ViewSonic VP201b with Black screen. I think the problem is the back light power supply. If I shine a light on it at an angle I can see the image on the screen. what is the part number to get a replac
The power supply board is model L20C-2 In most cases you can repair the board cheaper than you can purchase a new one. The problem is the filter capacitors go out and this keeps the back light bulbs from powering up right. If you feel like doing the repair on the board here is a link that shows the board with the bad parts circled and a parts list on the capacitors that needs to be replaced.
http://www.ccl-la.com/catalog/product_info.php?products_id=88
Nov 12, 2012 | ViewSonic VP201b 20.1" LCD Monitor
ViewSonic VX2235WM turns on than screen goes blank changed power cords cable cords viedo card cpu still same problem
The problem is most likely the monitor itself. Hook up an old monitor (usually someone has an old monitor laying around) if the computer works with another monitor you'll know for sure.
Look at your monitor using a flash light at an angle, if you can see a picture in the background you have a bad inverter.
Nov 28, 2009 | ViewSonic VX2235WM Monitor
Extremely Dim/Dark ViewSonic Monitor
There are two places to look for the problems, the backlight inverter board and the power supply. Look at the power supply first since it is easier to get to, look for burnt parts, bad capacitors, etc.
http://en.wikipedia.org/wiki/Capacitor_plague
Please post back what you find.
Nov 13, 2009 | ViewSonic VX2235wm LCD Monitor
Audio but no pic. believe it the backlight. very handy is this a part avail for the DIY er
If you hold a flash light to the screen ,on an angle you should be able to see the picture in the background if its the backlight. Try lookin on ebay for the part or a site called shopjimmy.com.
Nov 11, 2009 | ViewSonic N2750w 27 in. HD-Ready LCD...
Flicking on and off
If the LCD screen flicks on and off and you can see a dim image on the screen when you view at a sharp angle, then most likely you have a faulty inverter or a faulty CCFL lamp.
Check out LCD Parts for service, parts, DIY info. Use this Link :-
www.lcdparts.net
Sep 11, 2009 | ViewSonic VE710S (Silver) (Black, Silver)...
I have a Viewsonic flat-screen tv, it displays "menu locked" ??
Try holding the VOL + and VOL - buttons on the TV (not on the remote) down together. You should see a "unlocking buttons" message on screen. This might work. However, I tried it repeatedly, as told to by the Viewsonic "service" rep, and it didn't work for me. Viewsonic is ****, and so is its "service"!
Jun 06, 2009 | ViewSonic N3251w 32 in. LCD HDTV
Our viewsonic monitor tilts forward. how do we tilt it back?
Hello again.
The ViewSonic VG1930wm has a height adjustment range of 3.2", TILT capabilities, and a swivel range of 360 degrees.
So yes your monitor should be able to tilt back and forth.  Most likely if you hold the base of the monitor, and press somewhere on the front at the top or bottom (do not press on the screen itself) then it should easily tilt back and forth.  Occassionally there is a switch you may have to hold while you push on the front-top/bottom of the monitor which acts as a lock for the tilt angle.
Hope that helps, and don't forget to vote/rate!
Height adjustment range 3.2", tilt, swivel range 360º
Mar 12, 2009 | ViewSonic VG1930WM LCD Monitor
How do I replace the backlight in a ViewSonic N1800TV?
Hi Jake.
You most likely have a bad backlight inverter, there is a small chance it could be a power supply issue but I doubt it.
Replacing the inverter should be straight forward and easy but working with high voltage electronics can be very dangerous, I must tell you that it should be repaired be a trained professional but if you decide to do it yourself I will walk you through it.
You can buy the inverter at www.shopjimmy.com. When the part comes in get back with me and we can proceed in a chat from there.
In the meantime please rate me a FixYa.
Lone99star
Feb 24, 2009 | ViewSonic N1800TV 18 in. LCD Television
Same problem
It may be the back plane lamps, and or the back plane power supply that is in a failing condition. If in your model they are changeable, they should be changed together.
You can verify this by turning on the monitor, feeding it with a known working source, and shine a flashlight in to the screen at an offset angle to your view. If you can see some image in the screen, then you know that the monitor itself is functioning, and the problem is back plane lumination.
Jerry G.
May 07, 2008 | ViewSonic VX900 19" LCD Monitor
ViewSonic VA1930WM LCD Monitor Logo
119 people viewed this question
Top ViewSonic Computers & Internet Experts
mukhtar21 shaikh
mukhtar21 shaikh
Are you a ViewSonic Computer and Internet Expert? Answer questions, earn points and help others
