Question about Galaxy Radios DX-949 40-Channels Base CB Radio
Dx959 galaxy do you know why i would not get and type of communication when some one else with a diffferent radio is next to, or far away from me. I can not even hear people talking. [email protected] bn
  • AnyMHz.com
    AnyMHz.com May 11, 2010
    any more info would help. is your radio on AM or on FM?? make sure your not on SSB what else can you help with?
  • Dean Pitts
    Dean Pitts May 11, 2010
    It can be a number of things. First off, have you tried your radio in another persons vehicle with a known good setup? Can other people hear your? Does your meter move when you try to transmit? Does is move when receiving someone else? Try to check your CB/PA switch, and make sure it is in CB. It you be anything from your radio, mic, speaker, coax, or your antenna.
    After you check it out with another persons setup, please write back. I just need more information to help you work through this.
    I will also email you from [email protected]
  • 32 Answers
Do you have any knobs or switches that say 10k or just switches on the side. It should also be on AM if the other person is on AM (this is not a 10m radio anymhz it only has AM, it is a legal CB Radio) Generally you should just be able to put it on AM and talk if your on the same channel. if its been modded and has switches a 10k switch or (high low norm) these may no be in the right place. if the clarifier is unlocked that may also cause a problem, it needs to be on with the switches and knobs in the right place.
good luck! play with the switches, with someone else who has a radio.
Posted on Feb 12, 2009
SOURCE:
How can wire a Truckers commercial microphone to my Galaxy Dx959
does your truckers commercial mic work on a cobra 29? If it does then ,no problem,plug the mic into the radio and have fun . I have a cobra power mic on my 959B.
Dec 15, 2017 | Galaxy Radio Communications
Sound is lost and regain when mic button is pressed
i would assume you have wired it incorrectly or have tried another 4 pin mic such as an midland which are wire differently for the galaxy, ranger, connex, cobra an undien 4 pin mics. Galaxy Radios DX959 MOSFET Final Service Manual
Aug 01, 2013 | Galaxy Radios DX-959 40-Channels Base CB...
Galaxy dx959 will not receive. Speaker is working. S meter is showing incoming signal.
the over power doides may be blown. you should start there .they should be marked D-1 and D-2. you may want to replace them with diodes of a higher rating.
Jun 26, 2012 | Galaxy Radios DX 959 SSB CB Radio
Low modu DX959
http://www.cbtricks.com/radios/galaxy/dx959_mosfet/index.htm
http://www.cbtricks.com/radios/galaxy/dx959/index.htm
Has links to pages to show you how the alignment is performed, plus a schematic if you need to trace the transmitter portion for faults..
Feb 22, 2012 | Galaxy Radios DX-949 40-Channels Base CB...
Just purchased a new galaxy dx959. Coax and k40 10k watt antenna. Installed it in my peterbilt 379. I have a lot of background noise. I tried unhooking the coax from back of radio and the noise goes...
You probably have the 959 that has a MOSFET final. It is not recommended that you try to get more power/mod by just turning pots. This can shorten the life of the MOSFET drastically. I normally set the power output to 7 watts and the mod to 100%. This give around 30 watts peak on AM and around 25-30 watts sideband. You need proper test equipment to align the radio.
As far as background noise, this type of radio does have more that others. Make sure the Noise blanker and ANL are turned on. If you are getting noise from equipment in the vehicle, you should take your truck to a good CB shop. They can find out what is causing the noise and fix it.
....Don at NTCB, Inc.
Jun 08, 2011 | Galaxy Radios DX-959 40-Channels Base CB...
Have new dx959 doesnt get out very far talking 100yrds or so use rdking 56 mic mic works fine on old radio pc 78 and gets out fine also are 959 radios ok or junk has good reception
The DX959 has an output power setting knob. It's located next to the channel selector and is labeled RF Power. Turned counterclockwise will reduce output power. Turned clockwise will increase output power. Your switch is probably turned all the way counterclockwise resulting in low transmit volume.
Also, make sure the wiring for the RK59 is correct for the Galaxy. Even though it's a 4 pin plug, the pinouts may be different for the Uniden and Galaxy radios. Do a Google search for mic pinouts for your two radios to check.
Jul 12, 2009 | Galaxy Radios DX-959 40-Channels Base CB...
Galaxy DX959
it can not be tuned to go high or low you need to add switches for that and then realign the radio.
Mar 08, 2009 | Galaxy Radios DX-959 40-Channels Base CB...
Galaxy DX959
The 959 is not one radio you can get alot of power out of possibly 25 watts if it is tuned properly
Mar 16, 2008 | Radio Communications
Galaxy Radios DX-949 40-Channels Base CB Radio Logo
125 people viewed this question
Top Galaxy Radios Radio Communications Experts
Marvin
Marvin
Mike Charette
Are you a Galaxy Radios Radio Communication Expert? Answer questions, earn points and help others
