Question about Vacuums
Electrolux power nozzle, model 1692, power cuts on and off
Electrolux power nozzle model 1692 power cuts on and off. I don't have the manual for it but I'm trying to remove and clean the brush compartment. I removed the top but not sure how to get to the brush. I would like to find a manual for it because it's completely different than the one I use to have.
3 Suggested Answers
  • 15 Answers
SOURCE: vacuum hose replace electrolux how to
YOU DON'T SAY IF YOU HAVE THE NEWER HOSE OR THE CLASSIC ONE WITH THE STEEL TIP (BETTER DESIGN). IF IT'S THE LATTER UN-SCREW THE SCREW CLOSEST TO THE STEEL TIP,TAKE A SMALL SCREW DRIVER AND LIFT THE THE PIECE OF PLASTIC THAT WAS SCREWED DOWN JUST ENOUGH TO SLIP THE HOSE OUT.
WHAT YOU'LL BE FACED WITH IS SOMETHING I WOULDN'T SUGGEST CUTTING.
IT MAY BE MORE PRACTICAL BUYING A NEW HOSE. AN ELECTROLUX WILL LAST FOREVER,BUT YOU DO HAVE TO REPLACE THINGS LIKE THE COMBO DUST/UPHULSTRY ATTACHMENT. THE HOSE IS PROBABLY THE FIRST THING YOU WOULD NEED TO REPLACE BECAUSE OF AIR LEAKS. I'VE HAD MY OLYMPIA ONE FOR 27 YEARS AND HAD TO REPLACE THE HOSE ABOUT 10 YEARS AGO. YOUR CHOICE.
Posted on Dec 02, 2007
  • 694 Answers
SOURCE: my electrolux epic 6500 power
No. If the power nozzle motor is running, then a new belt will do the trick.
Posted on Sep 26, 2010
I have a Electrolux Guardian Encore E and the power head quit working. It has suction power head off and all other attachments work.
Try this. Remove the power nozzle from the lower wands. Remove the wands from the hose handle. Snap the power nozzle directly to the hose. Make sure all switches are turned on and try it. If the power nozzle now works, there's an issue with one or both of the wands. If the power head does NOT work, you've secluded the problem to the power head. With that being said and although it could be a power nozzle switch or a wire that disconnected inside, it's most likely the power nozzle Elbow assembly wiring that's worn out. This has been an issue with this model after so many years and you simply need to replace the Elbow assembly.
I hope this helps and let me know if I can be of any more help.
amerivac4u@yahoo.com. Hope this helped. :-)
Apr 02, 2015 | Electrolux Vacuums
How do I reset Electrolux deepclean motor
not sure of you rmodel but I found this statement on one of them This vacuum includes a safety cut off power option if an object gets caught up in the deep clean nozzle, which can easily be reset by pressing a reset button located on the power nozzle.
Jan 31, 2015 | Electrolux Vacuums
Older canister model 1521 with PN6a power nozzle. movers broke power nozzle elbow and lower sheath. what part numbers should we order?
Hi. With electrolux its best to take the parts to a vacuum or electrolux store and match it up. Chris
Feb 21, 2011 | Electrolux Vacuums
I need a new power cord for the power nozzle on my Electrolux 2100 canister vacuum. The power nozzle has part number N115M written on the bottom. I have found the power cord for power nozzles PN6 and PN7...
You can buy the hose at an authorized Aerus Electrolux store. If near enough, they will deliver, if too far, they can ship it. The nearest dealer can be found using the below link. Just follow the instructions.
Just provide the model of the machine. They will know what hose you need.
http://www.aerushome.com/storelocator/
Dec 12, 2010 | Electrolux UltraLux 2000 Bagged Canister...
When I vacuum with the power nozzle, it keeps cutting off. Do I need to replace the hose or the power nozzle?
Not necessarily. It's hard to tell without checking it out. I strongly recommend taking it to an authorized Aerus Electrolux store and letting the service tech check it.
If you have the "Sidekick", you can try using it. If it still cuts out, it's the hose. If not, the wiring in the power nozzle is loose or worn and needs to be replaced.
Keep in mind that you may not need to replace the hose or power nozzle, just have some wiring repaired.
Nov 07, 2010 | Electrolux Epic 6500 Vacuum
Need a new electrolux power nozzle model N106m
If you're looking for a new head for your vacuum. Then you're going to have to replace it with the same type of nozzle.
However, wall inlets are standard so you can purchase any kind of attachment kit and it'll fit your inlets and work with your system. Their are many online retailers that offer a wide range of kits that will fit your system.
Mar 22, 2010 | Electrolux Centralux Vacuum
Parts for Electrolux Epic 6500
You need to look under AERUS Electrolux to find a Dealer with parts.
Electrolux USA sold the brand name back to AB Electrolux of Sweden a few years ago and there is no relation between the two.
You may also find a common component of a different color at a Tri Star dealer as they shared some power head and hose technology in the era of the EPIC although they don`t tell people that
Sep 14, 2009 | Electrolux Epic 6500 Vacuum
Electrolux model 2100
The power nozzle is equipped with a automatic shut off if something gets jammed inside it. Try resetting the button on top of the power nozzle after making sure the brush still rotates freely. A broken drive belt may also be the problem. You'll need to open up the power nozzle to check the belt. Pay attention to the screws as you take them out. One of them is shorter and is made to go into a specific slot.
Jul 27, 2008 | Electrolux UltraLux 2000 Bagged Canister...
Power head hose to fit power nozzle PN-4. Electrolux MDL 1401B
Generic problem for all Vacuums
I would advise you to ALWAYS to FIRST UNPLUG YOUR VACUUM before beginning any service procedure.
I would advise because this is an older Electrolux Power Nozzle PN-4
Model #1401B that you could buy a replacement hose of which would save you money or you can spend the price for a genuine hose – replacement hoes work just fine and are less money.
www.A-1Vacuum.com 1-800-657-1874 -- they can ship one to you UPS….
Don - The Vac Man
Apr 21, 2008 | Vacuums
ELECTROLUX / ULTRALUX VACUUM
I assume that you are talking about the power head for cleaning carpets. If so I have a spare.
Dec 29, 2007 | Electrolux UltraLux 2000 Bagged Canister...
Vacuums Logo
Top Vacuums Experts
AskDyson
AskDyson
D. Floyd Kolb
D. Floyd Kolb
Are you a Vacuum Expert? Answer questions, earn points and help others
