Question about Topeak Panoram V12 Mini 12 Function Cycle Computer
Where is the correct spot to put the magnet on the spoke for the v12 mini
  • 21 Answers
The only placement requirement for the magnet is that it pass exactly next to the sending unit you mount on the fork (there is usually a mark on the unit). So, really the placement of the sending unit determines the "correct" placement of the magnet on the spoke.
Posted on May 14, 2010
Flash player active x v12
no browsers stated, IE , edge, what?
no OS stated. XP?
no PC model stated, just mini (service tag on bottom has it)
hopeless,
(do now that many things like to block flash )
try running fire fox, and then put on opera brower.
see if IE , edge(w10) FF and opera all fail.
i bet one works. telling you why it does.
in most cases the browser has blocks setup.
or your malware or AV software doing that;.
ask ADOBE now to get older versions.
they will tell you the older one is a virus magnet and is blocked.
same with java and javascript.
old is bad, new is good.
forget 223Ghz... totally forget that.
Aug 16, 2017 | HP Mini Notebook
Can the spoke magnet go on the rear wheel sigma bc 906
You should be able to use it on your indoor trainer. The Sigma will need a wheel diameter callbration to give correct readings.
Jan 29, 2013 | Sigma Bc 906 Computer
Ive got a sigma sport 300 and need to know how far away from the centre of the wheel the magnet goes so that my speed reading is correct thanx
You can place it wherever on the spoke you like, as long as the distance is less than 5mm between the magnet and the sensor.
May 19, 2011 | Cycling
MY SIGMA 1009 COMPUTER SCREEN SHOWS 0 MPH WHILE RIDING.SEEMS AS THOUGH IT IS NOT TRANSMITTING ANY INFO. SOMEDAYS IT WORKS PERFECTLY.
You want to make sure the magnet on the front wheel is being picked by the receiver on the fork. Sometimes that magnet attached to the spoke will move on the spoke so that it no longer closely passes by the receiver. If the magnet has been lost, check with you can check with your local bike shop for an extra.
Feb 26, 2011 | Sigma Sport BC 1009 STS Wireless Computer
The front wheel on my new Trek Navigator 1.0 rubs slightly at one spot only on the brake. How can this be corrected?
Your rim is most likely bent at that point you may be able to correct this with spoke wrench, if you don't no how to adjust spokes take it to a bike shop and they will get you on your way in no time at all
Nov 12, 2010 | Cycling
Hi The pictures in manual docent show the direction clear . The magnet and the trnsmiter.
magnet gets screwed or clipped onto the spoke.the transmitter attaches to the fork.make sure the magnet on the spoke passes the centre of the transmitter (should be a mark on the transmitter)and also make sure the magnet passes the transmitter with 3 to 4 mm gap.you may have to turn the transmitter alittle to get it closer to the magnet.hope this helps
Oct 14, 2010 | Sigma Sport BC1106 Dts Wireless Bike...
Polar speed censor not working can I replace battery
The S410 watch is not designed to pick up a bike speed censor.
Detach the sensor from your bicycle.
1. Open the sensor by removing the two small screws, counter-clockwise, with a small screwdriver.
2. Lift the case off carefully. Hold the sensor cover upwards so that the PCBA (printed circuit board assembled) stays in the case.
3. Remove the PCBA carefully.
4. Press the battery holder gently. Release a hook of the holder from the opposite side of the PCBA and lift the holder upwards. Remove the old battery.
5. Insert a new battery with the plus (+) side facing up and press the battery housing gently so that it is attached to the PCBA at all corners.
6. Put the PCBA back into place. Attach the magnet by rotating it around the spoke before putting the metal cover on the magnet. Install the magnet at the same level as the sensor. The magnet must be facing the speed sensor. Or Attach the screw magnet to a spoke at the same level as the sensor. The magnet must be facing the speed sensor. Fine-tune the positioning of both the magnet and the sensor so that the magnet passes the sensor closely but does not touch it. The maximum distance between
the speed sensor and the spoke magnet should be 0.2"/ 5 mm. Once positioned correctly, tighten the cable ties securely and cut off any excess cable tie ends.
note: when you take apart and put back together the seal will no longer be watertight as these are pressure sealed.
Apr 19, 2010 | Polar S410 Heart Rate Monitor
I have fitted it hasnt worked. I have the wireless version. The computer unit is working but when I take it on the road, no reading...
While off the bike, try spinning the wheel (with the bike supported with the wheel in the air) and move the wheel sensor closer. Be careful not to get your fingers stuck in the spokes. Make sure the sensor lines up correctly. If this doesn't work you may have a defective unit.
Feb 28, 2010 | Topeak Panoram V12 Mini 12 Function Cycle...
Television
Sometimes if the screen was affected by magnets it will fade. you could try placing magnets around the screen and moving them around, BEWARE you could make it worse. If it dosent fade youve had it........Sorry
Jan 22, 2008 | Curtis-Mathis CM25011 25" TV
Topeak Panoram V12 Mini 12 Function Cycle Computer Logo
225 people viewed this question
Top Topeak Cycling Experts
Michial Gueffroy
dante
jimmarmor_ma
Are you a Topeak Cycling Expert? Answer questions, earn points and help others
