Question about General Electric A835 Digital Camera
How can I correct my lens error on my A835 digital camera?
    Brigadier General:
  • 11,967 Answers
Fixing a Lens Error on a Digital Camera
This has to be THE most common failure mode for a digital camera. Some common error messages that might show up on the LCD's of cameras with this problem include “E18 lens error”, or “lens error, restart camera”. Some cameras might show nothing at all, but merely make a beeping noise as the lens goes out, then in, then the camera shuts off. Sometimes the lens won't even move.
The problem is actually quite common throughout all camera brands. Usually it's sand or grit interfering with the lens extension mechanism. Or the camera's been dropped with the lens extended. Or the camera has been powered on, but the lens had been blocked preventing its extension. Or the battery ran down with the lens extended. Believe it or not, one BIG contributor to lens errors is using a camera case. Sand, gunk, case fibers, etc... accumulate at the bottom of the case. These materials love to cling to the camera by electrostatic build-up from the camera rubbing against the side of the case (especially those cases with soft fibrous intreriors). Once these materials work their way into the lens mechanism, that's all she wrote. I have many Canon's, and NEVER use a case for this very reason.
A camera owner that suffers this problem may have no recourse for having the camera repaired. Many camera makers will not honor repairing this problem under warranty as they claim it is due to impact damage to the camera, or sand or debris getting into the lens gearing mechanism (neither of which is covered under warranty). The quoted repair cost is usually close to or more than what the camera is actually worth.
Fortunately, about half the cameras that suffer this failure can easily be fixed by one of the following methods. None of these methods involve opening the camera, although some have potential to cause other damage to the camera if excessively done. If the camera is still under warranty, before trying any of these, please please first contact your camera's maker to see if they'll cover the repair, or to determine how much they'll charge for the repair. Who knows, you might get lucky. But if they quote you a number that's higher than the value of your camera, you may want to consider the following methods.
The methods are listed in the order of risk of damaging your camera. Thus make sure you try them in the listed order. And remember, these fixes (especially #6 and 7) should only be considered for a camera that's out of warranty, who's cost of repair would be excessive, and would otherwise be considered for disposal if unrepaired:
Fix #1: Remove the batteries from the camera, wait a few minutes. Put a fresh set of batteries back in (preferably rechargeable NiMH 2500mah or better) and turn the camera on. If that didn't work, try pressing and holding the Function or OK button while turning the camera on.
Fix #2: Remove the batteries, then remove the memory card. Then install new batteries, and turn on the camera. If you get an Error E30, it means you don't have a memory card installed, so turn it off, slip in the memory card and turn it on one last time.
Fix #3: Insert the cameras Audio/Video (AV) cable, and turn the camera on. Inserting this cable ensures that the camera's LCD screen remains off during the start process. Thus extra battery power is available to the camera's lens motor during startup. This extra power can be useful in overcoming grit or sand particals that may be jamming the lens. If the AV cable doesn't fix the lens error by itself, consider keeping this cable installed while trying fixes 4, 5, and 7 as a means to provide extra help to these fixes. But note that I DON'T recommend keeping the cable installed during Fix 6 as you may damage the AV port while tapping the camera. Reinsert the cable only AFTER tapping the camera.
Fix #4: Place the camera flat on its back on a table, pointed at the ceiling. Press and hold the shutter button down, and at the same time press the power-on button. The idea is that the camera will try to autofocus while the lens is extending, hopefully seating the lens barrel guide pins in their slots.
Fix #5: Blow compressed air in the gaps around the lens barrels with the idea of blowing out any sand or grit that may be in there jamming the lens. Other variations include blowing with a hair dryer in “no heat” setting, or sucking the gaps with a vacuum (careful with this one).
Now we're entering into the realm of potentially damaging your camera in conducting the fix. There is definitely some risk here, so take care when conducting the following two fixes.
Fix #6: Repeatedly tap the padded/rubber usb cover on a hard surface with the intent of dislodging any particles that may be jamming the lens. Other variations include hitting a side of the camera against the palm of your hand. A lot of people have reported success with this method. HOWEVER, there is also some potential for damaging or dislodging internal components with this method, such as unseating ribbon cables, or cracking LCD screens.
Fix #7: Try forcing the lens. More people have reported success with this method than with any of the other methods. HOWEVER, there's obviously some potential for damaging your camera by using this method. Variations include gently pulling, rotating, and/or twisting the lens barrel while hitting the power button. Attempt to gently straighten or align the barrel if it's crooked or twisted. Another variation includes looking for uneven gaps around the lens barrel, and then pushing on the side of the lens barrel that has the largest gap (note pushing the lens barrel all the way in is NOT recommended as it may become stuck there). While doing any of the above, listen for a click that indicates that the lens barrel guide pins may have reseated in their guide slots. If you hear this click, immediately stop and try the camera.
Posted on May 11, 2010
The camera turns on and says "lens error and turns off. GE-A835
Hello
The problem is that the lens has become stuck in the barrel. There are some DIY solutions you could try, but the probability is that you will have to get it fixed by a professional.
Use these at own risk as it may further damage the camera.
Firstly , try connecting your ac adapter or usb cable.
Try holding the shutter button while switching on the camera.
Look at the lens , and if some of the lens 'circles' is misaligned or not concentric then try wiggling it (while holding camera lens down).
Try gently pushing or pulling the lens when it extends but this is risky as it may cause the lens barrel to slip out of its guidance system.
Another way to do this is to place the camera lens down on a hard surface and then power it up. Be sure to use a soft cloth or something similar as to not scratch your lens or casing. Let the lens push the camera up and down a few times and sometimes the little resistance provided by the camera is enough to get things going again.
Try hitting your camera near the lens on the body with the soft tissue on the palm of your hand.
Other than that , I would take the camera to a repair center for a evaluation to see if it would cost more to repair than to replace the camera.
If it is still under warranty I would suggest you take it in before trying any of these steps and remove any off-brand batteries or accessories as some stores are really fussy about warranty repairs on camera's with non-brand accessories.
You can also have a look at THIS link.
Hope the advise is useful. please do not hesitate to let me know if you need any further assistance. Also, please be so kind to let me know if you found this helpful.
Regards
Andrea
Nov 20, 2010 | General Electric A835 Digital Camera
The camera is saying lens error and not allowing to take picture how can i fix it?
if taking the batterys out for short time dont work then its likely to be the focas setting censor out of alinement,,, has the camera lens been bumped lately,,, is it set up for the kind of photo your trying to take,,,
IE: not set on close up!!! for a long shot?
Jun 27, 2010 | General Electric A835 Digital Camera
Lens errors are fairly common. Usually it's sand or grit interfering with the lens extension mechanism. Or the camera's been dropped with the lens extended. Or the camera has been powered on, but the lens had been blocked preventing its extension. Or the battery ran down with the lens extended ... Unfortunately, many cameras that fall prey to this can only be corrected by professional repair. But, here are some things that you can do that may correct it. They only seem to work for less than 40% of the lens errors, but if the camera is out of warranty, they're worth a try:
Mar 16, 2010 | General Electric A835 Digital Camera
Everytime i turn on my a835 it says lens error and shuts itself off. what do i do to fix this problem
Hi Dear,
This might be due to Hard ware problem. The lens of your camera might be getting stuck at some point.
Please do not try to fix this on your own as the problem might become complex.
Please show this to your nearest service center.
If you need more information please do write to us again.
Have nice day.
Nov 09, 2009 | General Electric A835 Digital Camera
My ge a835 dig. cam says lens error but comes out and goes back in
The lens cannot fond the home position. It will need to be send to GE for repair. If it was dropped or the front of the camera bumped then it may not have the manufacturors warranty since most manufacturors don't cover dropping or impact.
Nov 08, 2009 | General Electric A835 Digital Camera
Ge A835 camera has lens error
Problem: dust in the gaps near lens which makes it jammed. Effect: the sceen shows blk color. Solution: just blow over it or vaccum it.
Sep 15, 2009 | GE A830 Digital Camera
Lens Error
I am sorry to say but you have a physical issue with the camera. Your either going to have to take the camera apart yourself or bring it in for service.
Try working with their support
GE Consumer Electronics
1-800-447-1700
Automated response 24 hours/day, Live agent 8 a.m. - 8 p.m. ET
Jan 06, 2009 | General Electric A835 Digital Camera
Can't Install Software from GE A835 CD-Rom
I need a solution to install the camera en the computer
Dec 28, 2008 | General Electric A835 Digital Camera
GE A835 lens error
....if you are within the window to exchange the camera for another at the place of purchase, i advise that, if not, send it off for service or get a quote first to see if it is cost-effective to repair  if it is out of warranty.
Dec 26, 2008 | General Electric A835 Digital Camera
LENS ERROR
My daughter had the same problem with her pink A735. I tried removing the batteries, resetting the default settings and every combination of buttons. Finally I grabbed the lens as it was opening and forced it out all the way. There was about 1/8" that it was short of being fully extended. This fixed the camera for at least a while, but it sounds like there is a problem with the mechanism as it clicks every time the lens deploys and retracts now. I suspect this is a short term fix, but if you are planning on tossing the camera out it is worth a try. This camera is only about a month old.
Dec 07, 2008 | General Electric A735 Digital Camera
General Electric A835 Digital Camera Logo
125 people viewed this question
Top General Cameras Experts
pontelemon
pontelemon
JOHN ALBURY
JOHN ALBURY
Are you a General Camera Expert? Answer questions, earn points and help others
