Question about Pioneer HTD-520DV System
Drawer closes by itself
When I open the tray to put in a DVD, it closes by itself. I can hold it open to put the disc in but once it closes, the light for that disc doesn't light up so it doesn't recognize it. But if I hit the Open/Close button again and just let it open and close by itself, it then recognizes the disc and I'm able to play it. It plays...so that's good. But why does it close by itself when I first open it?
  • KMully2438 Mar 28, 2008
    Thanks! It's good to know it's not really something we did to it!
    It's been doing it for a while now. Since the discs still play, I never really looked into it. We are going to be getting a HD TV. Do you think that we can still use this system with a new TV?
  • Anonymous Feb 03, 2009
    I am having the same problem. Is there a recall?
  • 4,234 Answers
The loading mechanism is off by a tooth or 2. The tray out position switch is not being triggered properly and the tray will reenter the machine. Did this just start happening? It is possible that the sensor switches are defective too. Worse case scenerio is about $5 in parts plus the local labor rate for repair.
Dan
Posted on Mar 28, 2008
6ya staff
SOURCE:
DVD tray will not open on my Toshiba DVR620KU
Googled this for two days with no success! Finally, out of despiration I took the screwdriver to the top cover. (four screws in the back, and two screws on each side) Lifted up the rear section of the cover which the released the front for removal. The input pc board is right on top of the dvd tray so little could be seen, so I removed the screws and clips holding the pc board. Make sure that you you disconnect the power before doing this however. Once you have removed the three screws, (two of which have attached grounding clips) you will need to disconnect the HDMI cable which plugs into the back of the board if you had not already done so. Now carefully plug the unit back into ac power, and while holding the board in your hand careful not to allow it to touch anything,press the open button on the front of the unit, and as you move the board slightly while pressing the button, the tray mechanism will start to try to release. Press the button several times till the tray opens completely and stops. Now comes the tricky part: Unplug the AC power plug while the tray remains open. (Otherwise the tray may close again and you'll have to go through the wiggle routine again to get it to open) Once it is open, remove the DVD Disk if there is one in there. OK, so now if you have followed these instructions so far the tray is open and empty, and there is no power to the unit, you can begin reassembly. Put the three screws and two clips back into the PC board loosely at first till you have all three started, then proceed to tighten each one. Replug the cable into the back of the PC board and then replace the top cover and the screws following the same procedure. Plug the unit back into the AC receptacle, and turn the unit on, then press the open/close button, and the tray should open and close as normal. I think what caused the problem to begin with is that I had left a DVD disc in the player for an extended period of time in the start play mode, and it either jumbled the programming or damaged the disc. I have not tried to put the original disk back in the unit to find out! I want to use it for awhile first!
Jul 10, 2012 | Toshiba DVR620 DVD Recorder/VCR
Go Video DV 2150 - DVD door won't open at all. You can hear a mechanism working behind the closed door, but nothing happens and the door remains shut. Any advice??
There is a small belt under the loading tray which would have gone slack ( loose ) and the sound you hear is it slipping on the motor pulley. If you are confident you can remove the mechanism and turn it upside down and access this belt. Dismantle only if you can get the spare belt or your efforts will be in vain.
Sep 13, 2011 | GoVideo Go Video DVD/VCR Combo
DVD tray won't open
Try to reinitialize the DVD functions, in the manual:
http://books.jvcservice.com/booklist.asp?Model=DR-MV1SU
Page 84
Turn the player OFF,
Press and hold the power button, While holding it, press the Stop button for 2 seconds or more.
Once its reset, see if it will eject.
Dec 27, 2008 | JVC DR-MV1SU DVD Recorder/VCR
Tray will not stay closed
This fault usually happens if the disc being read is not compatible with the player's firmware.
If discs are burnt from a computer, or copies, this can happen.
Does it do this with all DVD's?
Are you using commercial retail DVD's?
Otherwise something else is telling the player 'No Disk'.
Try a disc-based lens cleaner as laser may be grubby.
Or the laser diode could be defective.
Nov 21, 2017 | GoVideo D645 DVD Player
Xbox open/close disaster
u have the dvd rom damage y u dont try to change it
Aug 14, 2008 | Microsoft Xbox 360 Console
Locked DVD Tray
I'm pretty sure the force disk eject is the same across all Panasonic models - however I couldn't find anything specific for your model number. Still worth a shot, though.
With the unit in standby, press and hold the 'Stop' and 'Ch up' buttons together. It should power up and force the tray open. If this doesn't work, try changing up your timing by pressing and holding 'Stop' first, then a half-second later, press and hold 'Ch up' and keep them both held together. You can also try the opposite.
If none of these work, it will have to be taken apart to get the disc out. If you aren't comfortable trying, it will have to go to service.
Mar 09, 2008 | Panasonic DMR-HS2 DVD Recorder
Dvd player
First, make sure the DVD Recorder is completely disconnected from the Main Supply.
Then, if you look on the base of the unit, (just underneath the front of the Disc Insert/Eject Tray), there is a small slot, (approx 25 x 8mm), in which you can see a small, white, plastic lever probably situated near the right-hand side of the slot.
Then move this lever gently to the left, and then turn it on and the tray opens by pushing the button.
Jan 14, 2008 | Televison & Video
Not closing
Hello, with mechanical problems with sophisticated systems of gears etc, the only way thate one can fix it is if you send me a digital picture yourself. To access the inside of the DVD player, you will have to get a handyman to open the DVD player up with a screwdriver, by undoing some screws which hold the cover to the player itself. Then, with the player's circuit boards (The Green/brown Boards with weird components on it) showing, take around 5-6 photo's of the loading tray and the playing tray.(Where the disc is when watching a movie)In the time being, open the layer's cover as instructed before, and look at the inside of the tray for any broken plastic, debris or anything stopping the tray from opening. Good luck!
Oct 05, 2007 | Sony DVP-NS305 DVD Player
Xbox does not read discs.
Getting to the dashboard screen is a good thing but still cannot rule out a bad circuit board or power supply. All the symptoms point to a bad DVD drive but the opening/closing by itself do indicate a problem with the microprocessor. Can you turn the power on and off with the small button?? If not, would definitely suspect bad board.
Aug 16, 2006 | Microsoft Xbox Console
Pioneer HTD-520DV System Logo
239 people viewed this question
Top Pioneer Audio Players & Recorders Experts
 Grubhead
Grubhead
Steve Sweetleaf
Steve Sweetleaf
Ben Armstrong
Are you a Pioneer Audio Player and Recorder Expert? Answer questions, earn points and help others
