Question about GE JVM1440 Microwave Oven
MY MICROWAVE TURNS ON, BUT IT DOESN'T HEAT STUFF UP.
My microwave turns on but it doesn't heat stuff up. Light turns on and you can operate you just can't heat up food. I'm thinking it is the heating element just not sure. Can you help me?
  • GE Master
  • 43,501 Answers
Here is a tip that will help you to figure out what is wrong with yourMicrowave Oven....
Microwave Oven Basic Troubleshooting Tips
heatman101
hjdfjhj
Posted on Sep 30, 2010
4 Suggested Answers
heatman101
  • 43501 Answers
SOURCE: MY MICROWAVE TURNS ON, BUT IT DOESN'T HEAT STUFF UP.
heatman101
gffdj
taran_2005
  • 10515 Answers
SOURCE: My microwave doesn't heat up
HI,
The most common cause of that is a shorted or blown high voltage rectifier diode.
If you or someone you know wants to look into this, we have critical safety, disassembly, and troubleshooting info at our site, and our link is at our listing here on FixYa: http://tinyurl.com/yzjozk
More info here: http://www.gallawa.com/microtech/diode.html
You can usually find helpful exploded view diagrams and order parts by entering your full model number here: http://tinyurl.com/gv383
There should also be a "mini-manual" hidden inside the unit behind the control panel or hidden on the left side behind the grille, which is very helpful when troubleshooting & testing.Be advised if you are getting a ' hum' noise, then the probability of magnetron is also there.
Let me know,if needed further assistance.
Hope i helped you.
Thanks for using ' Fixya ' and have a nice day!!
Posted on Apr 22, 2011
heatman101
  • 43501 Answers
SOURCE: How to fix an Emerson microwave 8992RD that
heatman101
Posted on May 08, 2011
Sharp micro doesn't heat
see this causes and fix it. God bless you
Diode The high voltage diode converts the A/C power output of the transformer to D/C, doubling the voltage to nearly 5,000 volts. This high voltage powers the magnetron which emits the energy that cooks the food. If the diode burns out, a lower A/C voltage reaches the magnetron, which is not sufficient to power the magnetron. When the diode fails it is often visibly burned out. If it appears to be good, it can be tested with a volt-Ohm meter capable of testing diodes. High voltage diodes frequently fail and are one of the most common points of failure in a microwave oven.
Door Switch If the microwave does not heat, one of the door switches might be defective. Microwave ovens normally have three door switches, if any of them fail the microwave does not turn on and does not heat. Check the switches for continuity with an Ohm meter.
Magnetron If the microwave oven doesn't heat the magnetron tube might have burned out. The magnetron uses high voltage, high current DC power to generate the microwave frequency that cooks the food. If the microwave oven is turned on when it is empty this can cause the magnetron to burn out. Once it is burned out it has to be replaced, it's not repairable.
High Voltage Capacitor If the microwave doesn't heat the high voltage capacitor might be defective. The high voltage capacitor works with the high voltage diode to convert the output of the transformer to DC voltage and to double the output voltage. If the capacitor is burned out the entire high voltage circuit stops working properly. The high voltage capacitor can be checked with a special VOM meter which has a capacitance testing capability. Be aware that the high voltage capacitor can retain a charge of more than 3,000 volts and can injure or kill a person if not handled properly. Only trained technicians should perform this type of testing.
High Voltage Transformer If the microwave does not heat, the high voltage transformer might be burned out. Microwave ovens produce a very high voltage in order to power the magnetron antenna, which emits the energy that cooks the food.
Thermal Fuse If the microwave doesn't heat the thermal fuse may have blown. It can be tested for continuity. Watch our fuse testing video for more information.
Thermoprotector If the microwave doesn't heat the thermoprotector may have tripped. This is a safety device to prevent the microwave from overheating. It can be tested for continuity to see if it's blown.
Main Control Board If the microwave doesn't heat the main control board may be defective. This is not common. When a microwave doesn't heat the problem is usually within the high voltage circuit; either the high voltage capacitor, diode, transformer or magnetron.
Oct 02, 2012 | Sharp Microwave Ovens
Maytag microwave problem everything seemingly works but does not heat. Help
Oct 01, 2012 | Maytag MMV4205 Microwave Oven
GE Profile Spacemaker 2004 JVM3670BF02 doesn't Heat up
Ensure that you have select the correct range of temperature.
Sep 11, 2012 | GE Spacemaker JVM1640SJ Microwave Oven
Electrolux microwave buzzes and food doesn't heat up
If the unit operates correctly except heating the food, then the unit needs a new magnetron.
Aug 29, 2012 | Electrolux EI30BM55H Microwave Oven
Microwave turns on but no heat and turntable doesn't turn
It is one of two things, a defective door switch, "most likely" or the keypad control board is faulty.
Apr 22, 2012 | GE Spacemaker JVM1540 Microwave Oven
My Kenmore Built-in microwave doesn't heat and the turn table doesn't turn. Model 911-47812200
It is good that the microwave does not work all together. It might be an interlock button or even a relay connection burn on the main mother circuit board.
Need a qualified technician. The service manual will be like $20-50.
e
Nov 22, 2011 | Microwave Ovens
My Oster microwave (model #OGG21401) doesn't heat. When operating the light will turn on and the carousel will turn but food will not get hot. Can you provide a solution to my problem? Thank you.
Check the door safety interlock switches for proper operation. #1 trouble with microwaves that operate in all respects but no heat.
Thanks for your question @ FixYa.com
Sep 16, 2011 | Oster 0.7 Cu. Ft. Compact Microwave
My microwave does not heat anything. The touchpad, exahustfan, light works. The motor turns on and turn-table works for the number of mins specified but does not warm up the stuff. Please help!
Sounds like the magnetron has failed. This is the component that produces the microwaves that heats the food.
The cost of the magnetron is about 95% of the cost of a microwave oven. Most people don't, for this reason, replace the magnetron, they replace the whole oven which is probably what you will end up doing.
There is a possibility that the circuit that provides power to the magnetron is faulty and you need to take it apart, find the proper electrical leads and test them with a volt meter. To do this you have to remove it from its mounting and take it apart. It is a fairly lengthy process however.
Benjamin
May 25, 2009 | Whirlpool MH2155XP Microwave Oven
Can't use the microwave at all
you have either a bad keypad or control board.
If you have operation of some buttons and not others its the keypad. if you have no operation out of the buttons at all you have a bad control board.
If you turn your microwave on and it sets and the timer counts down you have a bad interlock switch..
please let me know exactly what your microwave does when you set the cook time
Jan 08, 2009 | Emerson MW8102SS 1100 Watts Microwave Oven
GE JVM1440 Microwave Oven Logo
371 people viewed this question
Top GE Microwave Ovens Experts
D. E. Hev
 Larry
Larry
Shekar Avadhani
Are you a GE Microwave Oven Expert? Answer questions, earn points and help others
