Question about Cobra 29 LTD CB Radio
Very hard to get signal and keep talking with people unless they in front back or on the side of me
    Champion:
  • 219 Answers
Remember your antenna is 90% of your radio.Some how your antenna not a match for your truck. There could be a ground problem bad coax bad mount or the wrong antenna. Hard to try to help unless you give me an idea of what you got.
Posted on May 14, 2010
Right turning signal blinking constantly even when the car is turned off
Pull the turn fuse in fuse box, see if it kills it? Your talking about right side front and back, correct.
Also, with key off and out, check for voltage at the turn fuse circuit, use a testlite, should be no voltage. If there is voltage, something wrong with ignition switch or wiring circuit to fuse is shorted to voltage.
Also, with turn switch in neutral position, there is no continuity for the turn circuit. Unless you can do some testing, I'm going to have a tough time trying to help?
Mar 15, 2016 | 2001 Kia Sportage
Right turn signal possible short
the wire is shorted.
trailer hitch hack job.
collision damage to rear.? wrecked the harness.
why would the flasher be bad, if left side front and rear works perfectly
we use a 15amp circuit breaker to replace the flasher fuse.
then find the short, (beaker keeps popping) when right turns are selected.
is this car under warranty?
did some one put in an illegal larger fuse in this circuit? dont
its a simple shorted line
we have a thing (real edison like) called an ammeter
we can measure the actual short, all look here its 15amps
just as the breaker trips, bingo city
then all we do is start pulling all inline connectors to find the section that is shorted, front or rear.
does that help?:
Jan 07, 2015 | 2011 Kia Sedona
I keep doing a hard reset but all it does is go back to the recovery screen
Check the manufacturers web site for key combination for factory reset. Make sure you have all your needed information save. IE: Data (Photos, Documents) Unless this is what you are talking about and with so little information, makes it hard to better assist you in a possible repair. Leave me information - I'll try to check later.
Nov 08, 2014 | Computers & Internet
How to remove front turn signals on a 2007 harley sportster
If you are talking about just removing them for the handle bars, look on the front of the grip assembly, in line with the turn signal post. You will see a hole where an allen wrench set screw is. Just loosen those screws until the signal unit pulls free. If you are not going to put them back into the same place, you might want to remove the set screw completely so you don't loose them due to vibration. If you are going to remove the turn signals completely and not reinstall them, you may want to look into some kind of load resistance to plug into where they were plugged in so the back ones still work (if you are keeping the rear one on and use them).
Dec 06, 2012 | Harley Davidson XL 1200 C Sportster Custom...
How to reset the hard disk
What do you mean reset the hard disk? There's no such thing. Exactly what is it that you are trying or wanting to do? What type of problem are you having that makes you think your hard disk needs resetting?
Are you talking about Formatting the Disk which wipes it out completely and makes it unusable until you reinstall the operating system?
Are you talking about doing a System Restore which takes your computer back to a certain date and time before you started having problem. And it keeps your documents, music, pictures, videos, programs (unless the program was installed after the date you selected).
Are you talking about a System Recovery which sets your computer back to the first time you brought it home after you purchased it. You will lose all your data, documents, music, pictures, videos and program that you installed.
Apr 08, 2012 | Toshiba Satellite L305D-S5881 Notebook
1995 buick skylark 2 door. both driver side bulbs light but do not flash
I take it your talking about turn signals. Are they on the front, back , both? Need info.
Dec 30, 2011 | Cars & Trucks
Front passenger side turn signal is out. how do i get to the bulb to replace it? it seems to be inaccessible unless i take out the battery.
there should be a screw on the left and right side on the front of the light. if you unscrew them the light should pop out then you can get to the bulb in the back of the light.
May 31, 2011 | 2005 Pontiac Grand Prix
What kind is it? Try a wilson 1000 or 2000, they are great antenna,s. Make sure your antenna is free of blockage,metal,etc. If you have a bumper mount,mount it on the right rear of vehicle, 102" whip is a good one also. ..hope this helps...
Mar 16, 2010 | Cobra 29 LTD CB Radio
Cobra 29 LTD CB Radio Logo
41 people viewed this question
Top Cobra Radio Communications Experts
AnyMHz.com
AnyMHz.com
Steve
Are you a Cobra Radio Communication Expert? Answer questions, earn points and help others
