Question about Sony PFM-50C1 50 in. Plasma HDTV
Sony Plasma PFM 50 ci black screen
I have a sony plasma PFM50 Ci. First amulit coloured lines an inch thick was going down the near middle then a black one appeared going up now in a different place. The screen is black now I can hear a fan kicking in so I know there is power but I don't know what to do.
. Check blink of leds
check the 5 v control voltage.
check Ysus and Zsus board.
check Voltage sc, Vs and Voltage a .
Yareth De Matos - Venezuelan -
Posted on Jun 28, 2008
How do I get rid of vertical black bars on a plasma television
Fix Panasonic Plasma TV Vertical or Horizontal Bars ...
? 10:21
https://www.youtube.com/watch?v=CpWZTnAXbLg
Dec 30, 2013 - Uploaded by Pet Rock's Garage
This video covers how to fix a Panasonic 42" Plasma TV model TH-42PX600U that has vertical distorted ...
Horizontal black lines on Samsung 50" plasma tv - Forums - CNET ...
www.cnet.com > Forums > Samsung
CNETJun 11, 2015 - This past spring, a thin black horizontal line appeared across the screen, everything else is working fine. Next day ... In reply to: Horizontal black lineson Samsung 50" plasma tv .... I tried a white wash on the TV, but that didn't removethe line. Plasma TV has 3 thin black lines
Jun 11, 2015
Black Line across Samsung 50" Plasma has appeared?
Jun 11, 2015
Vertical black line on Sony PFM-50C1 Plasma Display
Jan 28, 2007
More results from www.cnet.com
Jan 05, 2016 | Samsung Televison & Video
42" LG plasma
It sounds like a bad panel, which is not what you want to hear. Replacing the panel on a Plasma TV usually costs more than just replacing the TV. However a bad panel causes vertical lines exactly as you describe.
Sep 10, 2007 | Sony PFM-42X1 Plasma TV
Sony ke42m1 plasma 1-1/2 black line down the middle vertically of the screen pic is otherwise clear started as a thin green line down the middle which would go away after a minute or so than the black...
hi all .ive had the same problem,a thick black line down screen.sometimes it flickers from top to bottom and other permantly in view.but i have solved it.forget your ic boards and taking apart tv.have you got either a ps3 or wii connected to tv.if so unplug power lead from socket and relocate in seperate socket.make sure the lead is completely free of any other leads and you might just find this works.i think the power lead creates some sort of frequency that the tv picks up .good luck hope it works
Jul 31, 2010 | Sony WEGA KE-42M1 42 in. HD-Ready Plasma...
3 inch thick black line almost at centre of screen
Hey mate, very common in all makes of plasma TV's. See this how to video on to fix it, the video is for a hyundia but it is the same for your TV. http://www.youtube.com/watch?v=9NPobj0_GSo
It's pretty easy, just get a soldering iron and take your time, best of luck. Bro
Apr 03, 2010 | Samsung PS50A466 50 in. Plasma HDTV-Ready
Sony PFM-42B1 with black bar in 720p
yes, stop using a plasma TV as a computer monitor. Using the TV this way is an invitation to phosphur burn which these are very prone to. The issue you describe is due to the limitations of the TVs scaler circuit to properly center the image in 720P.
michtech
Feb 13, 2009 | Sony PFM-42B1 42 in. HD-Ready Plasma...
Sony plasma 50 inch has lines in the middle of screen
It sounds like a bad plasma panel but I would have to see a picture to be sure
Oct 19, 2008 | Televison & Video
Sony pfm42x1 colour problem
Check the settings in the menu and make sure you have the input properly set to RGB and not color difference settings (Y, RY, BY).
Apr 22, 2008 | Sony PFM-42X1 Plasma TV
Sony plasma
SOUNDS LIKE YOU NEED A NEW PDP(PLASMA DISPLAY PANEL) HOPE YOU HAVE WARRANTY$$$
Feb 19, 2008 | Sony PFM-50C1 50 in. Plasma HDTV
Vertical Black line on display
Rakesh, You have a "dual scan" panel, this is why the line only decends down the screen half-way. This could be a connection problem on the buffer board which causes loss of the drive signal only to that part of the display which it is connected to. The vertical address buffer will be located on the top rear of the display, use great caution in inspecting these cables and connectors. If the integrity of the cable and connector is good the panel itself may be bad due to the drive IC being located on the ribbon cable attached to the panel body. this is better known as COF or, chip-on-film technology. I hope this helps you. Good luck. Joe Weibel CustomElectronics.Org
Jan 28, 2007 | Sony PFM-50C1 50 in. Plasma HDTV
Sony 42" Plasma
This could be caused by a buffer board on the lower part inside the set
Aug 15, 2006 | Sony PFM-42B1 42 in. HD-Ready Plasma...
Sony PFM-50C1 50 in. Plasma HDTV Logo
324 people viewed this question
Top Sony Televison & Video Experts
Are you a Sony Televison and Video Expert? Answer questions, earn points and help others
