Question about Xerox WorkCentre M20i All-In-One Laser Printer
Error message Xerox Phaser 8400 07.010.43.4819
  • Xerox Contributor
  • 185 Answers
The post was a little confusing. You have an 8400, correct? (not an M20)
The 07,010 error is normally a bad process motor 401-1000-80
You should also change 2 camshafts at the same time 401-1003-80 and 384-1874-80. The whole job is medium difficult and takes 2-3 hours.
Whit
Item, Inc.
Posted on Aug 10, 2010
2 Suggested Answers
  • 57 Answers
SOURCE: xerox phaser 8560 DX error
This fault occurs due to the printhead being stuck in the tilted position. There are many reasons why this fault will occur, too many to mention.
More often than not, your problem will require the printhead and process gear to be re-aligned in order to get a reboot but sometimes it is possible to get a reboot by doing the following;
Turn the printer off, wait ten seconds then turn it back on again. Wait for the printer to start warming up to about 5 or 10 percent. At this point, switch the machine off again by the machine switch NOT your wall/plug switch. Wait ten seconds and switch on again. Now let it run through its normal cycle. The success rate for this method is small, possibly only 1 in 30 machines will recover.
The reason this will sometimes work is that, when you turn the machine off from the warm up, it powers down using its proper head parking routine, you will notice, it takes a while to shut down. If the original fault was due to say a power cut or someone pulling the plug out it is possible for the printer to find its home position and boot ok.
Unfortunately, a lot of the time, the reason for the fault is printer related and such, this method does not work. But it is always worth a try.
Hope this helps.
Posted on Jan 19, 2011
ERROR MESSAGE PHASER 8560 09,006.41:150694
9,006.41: The magenta ink melt heater is On, but ink is not dripping.
Manually verify that the ink stick is able to advance in the ink loader chute. Check for broken or wrong type ink cubes.
Apr 07, 2014 | Xerox Phaser 8560MFP Laser Printer
I own a Xerox Phaser 3100MFP and it keeps giving me an error message saying "Printer error Fuser temp"...Help
please your xerox phaser is in fuser light is checked is not courently okthis parts is damaze? then changing the fuser temp and new added.
Sep 22, 2009 | Xerox Phaser 3100MFP/S Laser Printer
Phaser 8560DN Printer ~ Error Message
An error code due to the print head, check the waste tray area for a spill, has the printer been moved lately? remove left cover and look for spill.
-Carl, please let me know if this helps.
Jun 25, 2009 | Xerox Phaser 8560DN Printer
Xerox phaser error code is : 07.002.44:10318 what dose this mean
07,002.44:
PM_FAULT_PROCESS_MOTOR_STALL
Verify process motor operation with the Process Motor diagnostic
test. Also exercise processes run with the process motor;
transfix, drum maintenance and head tilt. This can be caused by
the power control board. The process motor may have more than
one task initiated. Reset all solenoids and the pressure roller
prior to cycling power.
Jun 17, 2009 | Xerox Phaser 8200 Laser Printer
Xerox phaser 8500 error 13,327.42:31555
If you have Warranty Still, CALL XEROX!!!, That error message indicates that you have a failed temprature sensor inside the print-head, 90% chance Xerox will have to replace print-head. Print head is VERY expensive to replace out of pocket ($500-800+)
Jan 23, 2009 | Xerox Phaser 8500/DN Printer
Phaser 7300 Error Code/Message
Seems to be something to do with the Ram.
More help HERE
Jun 01, 2008 | Xerox Phaser 7300DN Laser Printer
PRINTING ERROR
Online Repair Services For Printer Users At Low Costs Call 1- 800-956-0247
We are an authorized service center at toll free number to provide Printer Repair Customer Support services for online printer users at low costs. We have dedicated and professional team, who is very trained and experienced to repair printer rightly. Our printer technicians are highly proficient and depth knowledgeable to solve all technical errors related to printer. Our experts are simply available to help you for any type of technical error. Our online repair services are also available at your desk to solve your problems immediately.
Corporate Office:-
1680 Michigan Avenue,
Suite 700, Miami Beach, FL, 33139
USA Phone Number:- 1- 800-956-0247
http://www.printerfixit365.com/
Youtube:- https://www.youtube.com/watch?v=71cwRgd1W7M
Blog:- https://printerfixit365blog.wordpress.com/2018/03/12/how-to-use-a-printer-at-affordable-cost/
Facebook:- https://www.facebook.com/Printer-Fixit-365-1061418913976081/
Twitter:- https://twitter.com/printerfixit365
Google Plus:- https://plus.google.com/103524620603339733341
Mar 04, 2008 | Tektronix Phaser 860DP Thermal Printer
Ram Error message
Have you tried reseating the ram?
Dec 13, 2007 | Xerox Phaser 7700 Laser Printer
Xerox Phaser 6100 Fuser Error
Try this,
Reset Fuser Life
  1. Using the control panel buttons scroll to Maintenance, press OK.
  2. Scroll to Check Others, press OK.
  3. Scroll to Fuser, press Reset
Oct 22, 2007 | Xerox Phaser 6100/BD Laser Printer
Xerox WorkCentre M20i All-In-One Laser Printer Logo
236 people viewed this question
Top Xerox Office Equipment & Supplies Experts
Michel
Xeroxrep
Level 1 Expert
Philip Hughes
Are you a Xerox Office Equipment and Supply Expert? Answer questions, earn points and help others
