Question about Toshiba Satellite A15-S127 Notebook
Cannot load fresh windows xp professional
I am tryin to install fresh OS on my A15, but cannot get through it. It does the install upto the point where it says copying files and then starts giving me errors that cannot cave **.dll and other files one after the other and just gets stuck at this for hours.
I tried formatting the drive and deleting the partitions, but, still no progress.
I got an error once that it cannot partition the drive, so I am thinking that it is the HDD itself. I have ordered another hard drive and will try again. Meantime any suggestions will help....
  • 1 more comment
  • KZAM Mar 28, 2008
    Thank you geikogirl for your response. I don't understand what you mean by uncertified OS. The OS I am trying to install is XP pro with license key and the disk is in good condition. I just installed it on a desktop and it worked fine. That's why I was thinking that may be the HDD has something physically wrong with it. I am buying another HDD and will try to put that it and see if I have any luck..
    Again, thank you for your post and help..
  • KZAM Mar 28, 2008
    By Certified, do you mean is it Legit?? Yes it is a XP Professional that I have used on my other desktop also and it installed without any problems and also went thru the validation from Microsoft.
  • Patrick Michaels
    Patrick Michaels May 11, 2010
    shall we assume your os is certified?
Yes, a non-copied version, or the original disc, a "certified" os.
It's possible that your HDD is failing, but 9 out of 10, it's the software. Did you check to see if everything was seated properly. Your HDD was full plugged/inserted in? This can cause issues as well.
Posted on Mar 29, 2008
    Problem Solver:
  • 5 Answers
I will agree, that uncertified OS often come back with refusals to install certain files as those files weren't copied correctly.
It's also possible that your OS disc is old and very scratched, which could cause information transfer issues. I suggest either using, or getting a DiscDr. if at all possible. They really do work, and it might save you from having to purchase another OS.
Posted on Mar 28, 2008
My problem to my pc is i can`t install a new operating system,my old operating system is an windows xp and this is a japanese os, i want to be change the os at windows 7.i had 1g of ram 2 point something...
Hello, I´m from Argentina, then, sorry by my English. Try to install other XP, you can find in pages XP in English or Spanish, probably your problem is the language of your OS. After that, install Windows 7. If you fix the problem or not, please, write me at vcginformatica@gmail.com and tell me then will find other solution.
Feb 18, 2011 | Microsoft Windows XP Professional
How to reformat PC
Boot to your XP Pro OS CD and hit enter to load OS. Hit f8 to accept agreement. Delete present partition and you'll get an option to format the C drive and load a fresh version of XP. If you don't want to load XP again- boot to the XP disk and go into the Recovery console - after logging in, type format at the C: prompt.
Nov 09, 2010 | Microsoft Windows XP Professional
The computer hangs all the time and will not boot about 40% of the time.
If you have the operating systems disk boot to the disk like you are going to reload operating system ( OS disk example Window XP or Vista Disk) Run though the steps on screen till you get to the point where it asks if you want to load a fresh copy of OS, this will be past the point where you press F8 to continue. Do not load fresh copy of OS. There should be an option to repare you OS. This will fix the OS with out loosing any of you files and stuff on the PC.
Sep 17, 2010 | HP PAVILION SLIMLINE S7520N AMD Turion 64,...
We bought an Acer netbook (Aspire One) already loaded with Windows 7 Starter. We would like to replace Windows 7 with Windows XP. How do we do that?
One Possible way is to format the partition used by Win 7 OS and install a fresh copy of XP else you can enter the BIOS and then select System Configuration then Device configuration then change SATA native mode from enable to disable. Place the XP disk in the drive and reboot the system follow the instructions install the XP...
Sep 15, 2010 | Microsoft Windows XP Professional
I have a A15-S127 Toshiba laptop. It was not working. I bought a Windows XP pro OS to install. It did not want to install. I wiped the drive and tried F2 F8 Del. and it will sometimes start to load the...
You need to get into 'setup' (watch the screen as it starts) and delete the hard drive, then reinstall it. Be sure to save and exit. When windows starts to install, it will see an un-formatted drive and offer to format it. Select 'NT' file type and let it proceed. Windows will install as on a fresh drive.
Sep 28, 2009 | Toshiba Satellite A15-S127 Notebook
Windows xp trouble shooting
hmm. It seems like you have a corrupted operating system installed. as you have said that after you have installed it wont go in on windows. try installing win xp again and if problem still persist find another windows xp installer and fresh install it 2 your pc
Jan 25, 2009 | Microsoft Windows XP Professional
Windows
pls tell me the exact error or wher you getting stuck tell me that or you can do 1 thing take a backup of data and format the c drive and install fresh copy of windowsx xp or if you want exact solution pls tell me the error msg which you are geeting bye
Oct 07, 2007 | Compaq Presario 5000 PC Desktop
Toshiba Satellite A15-S127 Notebook Logo
44 people viewed this question
Top Toshiba Computers & Internet Experts
Are you a Toshiba Computer and Internet Expert? Answer questions, earn points and help others
