Leaving brown stains on clothes, messing them up,
Leaving brown stains on clothes messing them up will not come out afterit is there. i cannot find where or how the spots are coming from.please help me.
If it isn't rust, I suspect cotton can decompose if moist for a long time (in the laundry or machine), causing brown spots. In that case, the spots probably cannot be removed. Or can they?
Posted on May 23, 2010
My dryer is leaving brown stains on my clothes. I think that the drum needs to be aligned. Is this an easy task?
If your dryer is leaving small brown streaks on your clothes, then your drum seals need to be replaced. It is not a hard task if you know what youre doing. It is a complicated one for a beginner because you have to take your whole dryer apart to replace the seals
Jul 13, 2011 | Dryers
Why is my washer leaving black stains on my clothes
It sounds like it might be leaving mold deposits. Try running a cycle with no clothes in it, hot, with a cup of bleach. If the stains are more brown than black, though, that would be rust in the pipes.
Oct 16, 2010 | Kenmore 44102 Front Load Washer
Starting to leave brown oily like stain on clothes
The first place that I'd check would be the small metal screens inside the openings on the water inlet valve. They can get really rusted, epecially in areas with hard water, so I would recommend removing the water supply hoses and take a gander at the screens. They can sometimes release the iron oxide into the wash water and cause brown stains or blotches on clothing. Hope this helped and best wishes.
Sep 07, 2009 | Whirlpool Calypso GVW9959K Top Load Washer
My Kenmore heavy duty tumble washer is leaving a light brown stain on white or light clothes. It is likely staining dark clothes but of course they are too dark to see a light stain. It is definitely...
The brown stains are likely coming from the felt drum seal. The OEM adhesive is tar based - and after time and use - breaks down.
You'll need a new felt seal - and the adhesive that is used should be silicone based... eliminating the brown streaks.
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question
Jun 06, 2009 | Kenmore 44102 Front Load Washer
Kenmore Calypso Washer is leaving dark brown stains on clothes
hi is the machine noisy on spin cycle if so ur bearings have gone
May 11, 2009 | Whirlpool Calypso GVW9959K Top Load Washer
Washer whining when washing and spinning leaving brown stains on clothes
Turn water off. Remove hoses and clean the rust out of the strainers at hose end. If they are clogged they will sound funny when water goes through them.
May 04, 2009 | Whirlpool Ultimate Care II LSQ9564J Top...
Kenmore dryer
ck rear (or front if it has one)drum seals they tend to develop rust stains over time the rust comes off on clothes leaving brown streaks ..seals will need to be replaced although you may try a bleach and water solution first drum will need to be removed to replace seals
Nov 03, 2008 | Kenmore Dryers
Stains from dryer
rear seal on drum needs replacing front 1 too if it has one the felt seals tend to turn brown and the "rust"will come back off on clothes leaving brown streaks
Jun 30, 2008 | Kenmore Dryers
Dryer is leaving brown streaks on cotton clothes
The 417 dryers have two seals on the front panel, the top seal has drum glides which wear down over time. Because the drum rests on those glides, when it wears down it leaves a gap between the drum and the seal, clothes will drag in that gap and come out with rust and/or seal adhesive stains. Try replacing the top and lower seals, this works most of the time...sometimes though, if left unattended long enough, the lack of support from the front glides causes too much strain on the rear drum bearing, and even after replacing the seals clothes may still catch, although the brown spotting will stop for awhile. You can feel the gap if you run your hand along the inside of the drum at the seal point.
Dec 29, 2007 | Kenmore 73952 Gas Dryer
Washing Machines Logo
622 people viewed this question
Top Washing Machines Experts
Gerry Harvey
Gerry Harvey
