Question about LG CHOCOLATE VX8500 Cellular Phone
LG Chocolate Ringer problem
My LG Chocolate cell phone won't ring. After choosing a ringer tone, it may work for a day and then goes silent. Even when I select the ring tone, it won't play the tone. All other tones work, touchtone, volume control, menu tones when selecting from the menu work. But not the ringer. Please, I like my phone, any suggestions??
Thank you in advance!
  • 4 more comments
  • Anonymous Aug 29, 2008
    Yup, new phone and service, no ring...
  • Anonymous Sep 11, 2008
    Same problem. Started out ringing, now all of a sudden no ring tone what so ever. Phone 2 days old
  • Anonymous Mar 14, 2014
    I need help
    I need your help
    I need help
  • Anonymous Mar 27, 2014
    have 2 cordless phones, both stopped working on the same day, my pc is still working ,all on the same line
Go to tools, phone settings, voice commands, call alert then do not select name repeat, the other 2 selections have a ring.
Posted on Apr 21, 2008
SOURCE:
Blu Advance 5.0 ringer sounds won't work.
Hi if u have silent mode turned on u won't hear a sample ring tone check where u adjust volumes there should b a silent mode on or off..Cheers..
Dec 20, 2016 | Blu Cell Phones
My lg 8575 won't ring
MY dear Your Phone Ringer Default So Please change Ringer
And Ringing Sound Problem will solved
Sep 11, 2012 | LG Chocolate Touch 8575 Crystal Case Hot...
How do I turn off the ringer to 'no' volume ?
SiSi Si As you have not mentioned the make and model of your phone I will have to be general in my answer.
In SETTINGS all phones have an option of Ring Tones and then Volume of Ring Tones. Here you must select 0 or Silent. And you ringer volume will be reduced to nil.
Aug 13, 2011 | Cell Phones
Uniden Model EX 14560 Ringer off How to put ringer on
Here some solutions for your problem + a link to the user manual.
**Selecting the Ring Tone and Volume
Your phone has five different ringer tone/volume combinations you can choose from.
To select the ringer:
1) With the phone in standby, press [vol/ / ] or [vol/ / ].
2) The phone will sound the different ring tones at different volumes. To turn the ringer
off, select RINGER OFF.
3) When the phone sounds the ring tone and volume you wish to use, press [end].
**Temporarily Mute Ringer
If the handset is off the base while an incoming call is ringing, simply press [end] to mute
the incoming ring. The ringer will sound with the next incoming call.
Note: You can only mute the handset ringer if the handset is off the base when the phone starts
ringing.
Adjusting the Earpiece.
**Here is also a link to the phone manual http://www.uniden.com/pdf/EXI4561om.pdf
May 18, 2011 | Uniden Cordless Phone
Hi how can i increase volume on my blackberry 9000. Even on high volume setting there is no ringtone sometimes
Hi there
On your Blackberry menu, there's an icon that resembles a person's head that represents profiles. In the profiles menu, you can select the volume for the notifications you receive when messages or calls come in. Choose "Loud" to hear all notifications at an equal volume, equivalent to the maximum output possible.
Some ring tones just remain less audible than others even when they're set to maximum volume. If you've tried increasing the volume of your notifications but still can't hear the ringer sometimes, try downloading a custom ringtone from the Blackberry App Store.
When selecting a custom ringtone, choose something distinctive and hard to ignore. When previewing the tone, determine whether it seems louder or easier to hear than your existing tone. Download more than one tone and experiment throughout the day.
After you've downloaded custom ringtones, set your phone to use these ringers by going into the applicable notification profile. Select "Show Tunes" and open the media folder where you've chosen to save your downloaded tones. Select the ringer you want and click "Set as Phone Tune."
Oct 04, 2010 | RIM BlackBerry Bold 9000 Smartphone
Got a new Blackberry Storm and my ringer won't ring
Check either your profile or under "Options" -> "Sounds and Ringer Tones" and see if your volume is set to "Silent". Change volume to something other than "Silent" and see if your ringer works then.
Oct 23, 2009 | RIM BlackBerry Storm 9530 Smartphone
How to inactivate melody ringer
Base unit ringer tone
(use either the handset or the base unit)
Make sure the base unit is not being used.
Setting the base unit ringer tone by using the
4 Select the desired ringer tone by pressing [d]
or [B].
• The handset will ring and the ringer tone will
change. If the ringer volume has been turned off,
the handset will not ring
• You can also select the ringer tone by pressing [1]
to [7].
5 Press Save, then press [OFF].
Press VOLUME [<] or [>], then select the desired ringer tone by pressing
[1] to [7].
[1] to [3] : Bell ringer patterns [4] to [7] : Melody patterns
• After pressing VOLUME [<] or [>], the base unit will ring using the current ringer
tone.
• The base unit will ring and the ringer tone will change.
• To stop ringing, press [STOP].
1 Press [MENU].
2 Scroll to “Initial setting” by pressing [d] or [B], then press
Select.
3 Scroll to “Set base unit” by pressing [d] or [B], then press Select.
4 Press Select at “Ringer tone”.
5 Select the desired ringer tone by pressing [d] or [B].
• The base unit will ring and the ringer tone will change. If the base unit ringer
volume has been turned off, the base unit will not ring
• You can also select the ringer tone by pressing [1] to [7].
6 Press Save, then press [OFF].
This Can Be Found On Page 17 And 18 Of The User Guide.
If You Do Not Have The User Guide It Can Be Downloaded Here
http://support.radioshack.com/support_phones/doc73/73355.pdf
Thank You For Choosing Fixya.com
Dec 21, 2008 | Panasonic KX-TG2357 Cordless Phone
Allert tone
you go to settings and then go to alert tone or ring style witch ever one works and turn it to silent.....
May 12, 2008 | LG CHOCOLATE VX8500 Cellular Phone
LG CHOCOLATE VX8500 Cellular Phone Logo
726 people viewed this question
Top LG Cell Phones Experts
William Norris
William Norris
George Etukudo
George Etukudo
Sheldon Dedek
Are you a LG Cell Phone Expert? Answer questions, earn points and help others
