Question about Quasar VHQ400 VHS VCR
Video head need cleaning is it wet or dry - Quasar VHQ400 VHS VCR
  • Quasar Master
  • 5,190 Answers
The best way to clean a video head is to remove the top outer cover, then you can spray the head with Servisol Video 40. You can also spray the audio/control head at the same time. You can get Servisol from electrical shops and also online (image below).
Posted on May 11, 2010
No video display from Sony SLV-ED10 Video Record Player
The video head is probably dirty, buy a blank VHS 120 tape, set speed to sp about 2 hours running time, and let the tape run. This works like a dry cleaning tape and is safe, repeat up to 3 times if required. I do not recommend wet tapes to ******* the video head.
Mar 19, 2012 | Sony Televison & Video
Playback flickering
The most common cause of this is dust, debris or contamination on the heads.
Firstly, it's extremely important that you use only DRY LUBRICANT type DV tapes on the Canon branded camcorders.
Different manufacturers design their heads to be used with either Dry or Wet (coating lubricant type) tapes - NEVER BOTH. Canon is DRY type.
Consumers are led to believe that they should be using well known branded DV tapes, such as Sony. This is fine, if your camcorder is a Sony. However, you should NEVER use Sony tapes in your Canon - Sony tapes are of the WET type.
So, the question is, "Are you currently using Dry or Wet type tapes, or a mixture of both?" If you have used either a WET tape, or a mixture of both in your Canon, then this may have contaminated your heads.
If this is so, then don't panic - simply run a special Head Cleaning cassette (for Dry tapes) in your Canon for no more than 5 secs. Note: your heads are very delicate, so only run the cleaning tapes for a few secs at a time.
Also, try to avoid recording over the cassette too many times, as the quality will sometimes degrade each time.
An example of the Dry tapes are the Panasonic ones (Myself and other Pro Videographers often use Panasonic Prof, Studio or Master Quality tapes, as these are some of the better quality Dry tapes on the market).
As your XL2 is a Pro Camcorder, I recommend you stick with Studio quality (or higher) cassettes.
See this link for Dry DV tapes: http://cgi.ebay.com/Panasonic-mini-DV-digital-video-cassette-AY-DVM63SQ-5pk-/170645949017?pt=US_Camcorder_Tapes_Discs&hash=item27bb4a8a59
or
http://cgi.ebay.com/5-Panasonic-Master-HDV-HD-video-tape-HC9-Mini-DV-/220519311691?pt=US_Camcorder_Tapes_Discs&hash=item3357f9a94b
See this link for Head Cleaner cassette: http://cgi.ebay.com/MiniDV-mini-DV-Panasonic-Head-Cleaner-Cleaning-Tape-/220683036059?pt=US_Camcorder_Tapes_Discs&hash=item3361bbe59b
If the problem still exists after head cleaning, then suspect either a faulty cassette (most likely) or damaged heads requiring service.
Let me know how you get on...
Scott
"If this has helped you, please be kind enough to leave a testimonial"
Jul 09, 2011 | Canon XL2 Mini DV Digital Camcorder
WILL NOT TRACK. +/- BUTTONS ON FROM OF VCR ARE FUNCTIONAL, BUT IMAGE OF IMAGE IS DISTORTED AND NOT IN COLOR.
I will assume you have tried to clean the video head, if you have not use a wet or dry cleaning tape "dry better choice" and see if that will work, the other option is use a brand new store bought blank tape T120 and set the vcr speed at sp and let it run all the way through. If all this fails it means either the video head is bad or you need alignment done inside the vcr.
Jan 10, 2011 | Sony SLV-N750 VHS/S-VHS playback VCR
The best way to clean a video head is to remove the top cover and Spray the heads (both video head and audio/control heads) with Servisol Video 40 see image below. Just let it dry up (which wont take long) and that should do the trick. If you spot some nasty bits of dirt, spray a cotton bud and wipe it away.
Mar 16, 2010 | Quasar VHQ400 VHS VCR
Head Cleaning
Please use good quality video head cleaning tape. Dry tape is better if you are about to clean camcorder video head.
Feb 03, 2009 | Sony Handycam CCD-TRV608 Camcorder
Image missing
When was the last time you "cleaned" the heads? Use a good commercial head cleaning tape. They have both "Wet" and "Dry" types. I prefer the "wet" over the dry. I think it does a better job but they are hard to find sometimes.
you can also do it manually with "foam" swabs and "methanol1.gif". Alcohol works but the methanol leaves less residue behind.
Jan 27, 2008 | Sony Handycam DCR-DVD108 DVD Camcorder
Help
When was the last time you "cleaned" the heads? Use a good commercial head cleaning tape. They have both "Wet" and "Dry" types. I prefer the "wet" over the dry. I think it does a better job but they are hard to find sometimes. you can also do it manually with "foam" swabs and "methanol". Alcohol works but the methanol leaves less residue behind. If that doesn't solve the problem the next step would be to take it to a repair shop for cleaning and re-alignment.
Mar 08, 2007 | Sony Handycam CCD-TRV308 Camcorder
No picture when recording, please help
Before you send it out to be fixed, when was the last time you cleaned the "heads"? I suggest you buy a "cleaning tape" first. Sony makes an excellent one. Follow the instructions that come with it. Takes 5-10 seconds. There are two methods in cleaning the heads, "Wet" and "Dry". Dry uses a small amount of special abrasive on a tape that is designed to remove and trap dirt and oils. Wet uses an alcohol solution to remove the dirt. you can use either. I prefer the wet because it is less damaging to the heads but it is also harder to do and takes more time and I have have a lot of patience. With the wet you can also clean the tape guides where you can't with the dry. For the general public use the dry tape system about every 25 hrs of recording or playback time. This should fix your problem. If it doesn't then you know you need to have it professionally cleaned and repaired.
Dec 02, 2006 | JVC GR-D50 Mini DV Digital Camcorder
Quasar VHQ400 VHS VCR Logo
60 people viewed this question
Top Quasar Televison & Video Experts
 Grubhead
Grubhead
Are you a Quasar Televison and Video Expert? Answer questions, earn points and help others
