I have a Sharp AL-1641CS and when I copy something half of the page is faded and the back of the page has a black stripe on it. I have cleaned it and replaced the toner but no improvement. What should I do?
  • 1,219 Answers
Clean the lase unit and check the drum.
Posted on May 11, 2010
Sharp 1641cs - Dark/black page after replacing drum & toner
Hi you have not said the toner type you replaced with though that will give not completely black copy. The problem may have been the drum unit installation. Make sure the charge unit over the drum service is present ie the one with a mesh wire like grid. If present, clean it or wipe with a soft clean and dry cloth. Clean the saw-tooth like metal plate inside that unit by slow blowing and make sure no toner particles are there. Finally screw the unit properly on the drum unit and your problem is solved.
Jan 11, 2013 | Sharp AL-1641CS All-In-One Laser Printer
Tip
Sharp AL-1641CS Scanner Manual Download
Free Sharp AL-1641CS Scanner Manual Download
Models: Sharp AL-1632 / Sharp AL-1641CS
Would you like to review the features of the Sharp AL-1641CS Scanner?
Have you lost your Sharp AL-1641CS Scanner Owner's Guide?
Would you like a free digital, searchable, pdf version of the Sharp AL-1641CS Scanner Manual?
Follow this link
(& click FREE) to download a pdf version of the Sharp AL-1641CS scanner documentation.
I hope that helps.
___________________________________________________
on Jul 24, 2010 | Office Equipment & Supplies
Tip
Sharp AL-1641CS Copier Manual Download
Free Sharp AL-1641CS Copier Manual Download
Would you like to review the features of the Sharp AL-1641CS Copier?
Have you lost your Sharp AL-1641CS Copier Owner's Guide?
Would you like a free digital, searchable, pdf version of the Sharp AL-1641CS Copier Manual?
Follow this link
(& click FREE) to download a pdf version of the Sharp AL-1641CS Copier documentation.
I hope that helps.
MY AL-1641CS LEAVES A THICK LINE ON THE PAPER. I
If the drum is rotated in the proper direction, it should be clean. If the line on your copy is in about the same location from to back as the line on the drum then your only option is going to be to replace the drum unit. The drum unit contains a drum cleaning blade that is supposed to clean the drum as it is being rotated. This is apparently not working in your case. These cleaner blades can be replaced if you have someone locally that can do it. The cost of a cleaner blade is about $20.
Good Luck and Thank You for using Fixya.
Jul 09, 2010 | Sharp AL-1641CS Laser Digital Copier
Tip
Follow this link
I hope that helps.
on Jul 24, 2010 | Sharp AL-1641CS Laser Digital Copier
DARK SPOTS
Are the dark spots random and moves location with every copy or are they at exacly the same place on every copy? Random you will need to remove the drum/toner and use a blower to clean the inside of the machine,failing that replace the drum unit.If the spots don't move clean the top glass.Let me know
May 21, 2009 | Sharp AL-1641CS Laser Digital Copier
Right side of paper is faded
remove the cartridge out, you can see a piece glass on the bottom inside the machine. clean up by acohol both side.
Dec 09, 2008 | Sharp AL-1641CS Laser Digital Copier
SHARP AL-1641CS
If there is a clicking chances are a gear has gone out. It should be checked out be a technician.
Jul 06, 2008 | Sharp AL-1641CS Laser Digital Copier
32 people viewed this question
jasbo
jasbo
