Question about Dell Dimension 4600 PC Desktop
Motherboard and case
What motherboard do I have? I want to know how to figure out if I have an ATX case and motherboard.
  • 44 Answers
HI,
I would advice you to go to http://support.dell.com and put in your computers service tag code and you'll have all the information about your computer in your finger tips...
Thanks and Regards
Posted on Mar 28, 2008
Not getting any video from a msi 880gma-e55 integrated video motherboard
This may sound simple, but make sure the monitor is set to correct input. Many are auto detect, but you never really know.
You could also check BIOS for onboard video. Disable if you have an add-on video card. Enable if you don't
Reseat the video card if it an add-on.
Jan 08, 2013 | MSI Computers & Internet
I have a tidalwave W32 motherboard to which i need to know what size pc case i need.Thanks for any help
Motherboards and cases are designed according to standard dimensions called form factors. The specs for that motherboard say that it is designed according to the ATX form factor (which is the most common one). If you go to www.newegg.com you should be able to look at cases and filter by "type". There are several sizes, but as long as it says it's an ATX case (NOT microATX) you should be good to go.
Aug 15, 2011 | PC Chips Tidalwave W32 Motherboard
I am purchasing the i7 2600k intel chip and want to know if the p67 extreme 6 will work with this chip in additon I need to know if this motherboard will fit in the Antec 900 case. If you can recommend a...
Go to the motherboard manufacturers website. You will find a list of supported processors on there. Also you have to determine if your motherboard is either ATX or Micro ATX (mATX). Your particular case supports both types and it is a good brand and good case.
Mar 14, 2011 | Computers & Internet
I need a power supply that is compatible for a customers computer
first thing you need to figure out is is it a 20pin connection motherboard or 24 pin connection is it a high horsepower gaming rig or a web surfing machine most PSU's are an ATX form factor got NEWEGG.COM they have quite the selection of power supplies.. hope this helps
Jan 17, 2011 | Cooler Master CAC-T05-UW ATX Mid-Tower...
I need a motherboard that can use the same case and everything els as the p4vmm2 My case is the ATX with Intel celeron 2,4GHz
you can use any ATX mainboard into an ATX case, they are universal. Your cpu will only fit boards with the same cpu footprint so you need to know what socket your cpu is.. lga775 is most common now. I would advise a Gigabyte EP45-UD3LR board. Excellent board and well worth the outlay.. no issues with windows xp or vista and you can expand drives and ram as you wish..
Nov 02, 2009 | EliteGroup P4VMM2 Motherboard
Aftermarket case trying to figure out the wiring not full plugs and don't know where on motherboard they fit anyone have my solution it's a hp board ms6577ver 4.1
if the motherboard is atx and the power supply is atx then the mb connectors should be marked on the mb and power supply. the mb side you will need a magnifier to read the small print. they will be in a line together somewhere near the lower corner of the board, in a straight line. usually rst is reset - hdd led is hard drive led and the square 20 pin conn, goes somewhere near the processor. if you have at board or powersupply it won't work they both have to be the same form factor. there are others and not knowing the case or ps i cant give you more info.
Jun 15, 2009 | Microsoft Windows XP Home Edition
Pc tower motherboard upgrade
you can put in any new micro-atx motherboard no problem. I can be 100% sure if the case is Atx full size- best way to check is to see how many pci expansion slots are available at the back of the case. Any Atx case can hold micro-atx mobo's but a micro atx case wont hold atx mobo.
May 27, 2009 | Compaq Presario 5000 PC Desktop
Problems on PCCHIPS M701G Motherboard
connect your three pin socket in your power plug
Jan 12, 2009 | PC Chips M701G V1.1 Motherboard
Computer cases
an at case doesnt have the extra ports than an atx case has, take for instance an atx motherboard has printer port, comp port, usb and ps2 ports near the top left side, an at motherboard only has an at keyboard connector, all the other things are put in an empty isa/pci slot
Here is a picture of an AT motherboard note top right the keyboard port and the white strip behind that is a 1 row set of pins for the power as the switch is in the power supply and not on the motherboard
http://www.pcbuyerbeware.co.uk/images5and8.htm
And This is an ATX motherboard you can see the 20pin atx power connector, because the motherboard has an electronic switch to control the power.
http://www.nuggetlab.com/comptia_files/equipment/mother_ATX%20Motherboard.jpg
Dec 12, 2008 | Diablotek BLACK ATX CASE W/ 400W PSU...
No boot, casing problem?
What is the powersupply in the 1U case. Is it sufficient for this motherboard? Try using the powersupply from another case that you know works with this board and see what happens. The larger standard ATX powersupply won't "fit" the 1U case but you should be able to run wires to allow you to test with.
Dec 27, 2006 | Intel SUPERMICRO X5DP8-G2-0 E7501 CHIPSET...
Dell Dimension 4600 PC Desktop Logo
21 people viewed this question
Alun Cox
