Question about Gaggia Titanium Espresso Machine
Coffee not flowing out normally
After I decalcified, the unit would go into ventilate mode about once a week of use. It would not clear by using the hot water valve. I would have to prime using the turkey baster method described in another thread. I decalcified two more times back to back. During the rinse portion I noticed the flow of water was intermittently not strong and steady. It would get weak and almost stop then back to normal. Now the coffee pour does the same thing, the machine seems to know the amount of coffee that is flowing because it will keep pouring until the cup is at the correct amount even thought it now takes three times as long. Does this sound like a clog in the line or a weak pump?
    Problem Solver:
  • 6 Answers
Most likely is a broken/failed "Steam Valve Cam" which actuates the steam/hot water needle valve. This part is made of plastic and prone to wear/failure.
Posted on Jun 30, 2010
How do I make ventilate message go away
  • Check to make sure there's nothing inside your flow meter.
  • Check the flow meter wire connection at the board (cpu/pcb).
Jun 22, 2015 | Saeco INCANTO DELUXE Espresso Machine
Why won't the ventilate message go away?
you have to decalcify your machine,but not sure will yuo can!!!
Jun 15, 2015 | Saeco Royal Coffee Bar Coffee Maker,...
What shall i do machine shows decalcify Ventilate?
Decalcify means that there's calcium buildup inside the coffee maker. You can buy stuff to put through it, but white vinegar works about as well. Fill the reservoir with vinegar, and start the coffee maker. You may need to run it more than once.
after it's run through, run 2 or 3 pots of clear water before you try to actually make coffee.
May 05, 2015 | Coffee Makers & Espresso Machines
What does ventilate mean
Hi
You have to flow water through the steam wand. Push the button for water. Then open the knob on the right to flow water. Once the computer see the the flow meter is spinning again it will clear the light for ventilate. If it doesn't clear the flow meter is not spinning.
Jan 01, 2010 | Gaggia Syncrony Compact Coffee...
Machine doesnt produce coffee
Try this, your machine has a manual/coffee grounds input, press the button for that option and see if water flows from the coffee spouts, if yes then adjust the grind on the grinder to coarser, if it gives you a ventilate error, then one of the lines to the brew unit is blocked, nd you will have to run the descale again or open machine and find blocked line and clear.
Mar 16, 2009 | Gaggia Titanium Espresso Machine
Decalcification and Ventilate
Try to make a cup of water (tea), make sure you get a full cup of water. If you only get a half cup of water then i think you have to replace the flow meter in the machine.
Best regards
/Mirran
Sep 25, 2008 | Solis Master 5000 Espresso Machine
Ventilate problem
Can you make a cup of water or there will only comes a half cup?
If you only get a half cup then you have to replace the flow meter in the machine.
Apr 27, 2008 | Gaggia Syncrony Compact Coffee...
My coffee machine says decalcify ventilate
For ventilate:
When it says to ventilate, it is asking you to prime the pump. Put acup under the panarello wand ( the steamer/frother) to catch thedischarged water and press the hot water button (upper left button onmy machine). Wait until air stops coming out with the water, usually3-5 ounces, and then press the hot water button again.
You machine is now ventilated (primed) and should be ready to go.
For decalcify:
Recommend downloading and following these directions.
http://www.partsguru.com/user/Safe%20Descaling%20method.pdf
Apr 27, 2008 | Saeco Royal Digital Plus Coffee...
Hardly any brewed coffee comes out and will not stop ventilatng!!!!
If you run water through the wand and the ventilate does not clear then there is a problem with the flow meter. Possible a piece of something got in there and wonlt let it do it's job. I don't think it is something you are going to be able to deal with. Do a search for an authorized Saeco repair center and tell them you were told the flow meter may be faulty. Sorry.
Jul 30, 2007 | Saeco Vienna Digital Coffee Maker,...
Open Questions:
See all Gaggia Titanium Espresso Machine Questions
Gaggia Titanium Espresso Machine Logo
140 people viewed this question
Top Gaggia Coffee Makers & Espresso Machines Experts
Henry  Thomas
Henry Thomas
Shehu Pro
Shehu Pro
Are you a Gaggia Coffee Maker and Espresso Machine Expert? Answer questions, earn points and help others
