Question about Frigidaire Electric Dryer
Squeaking noise - Frigidaire Electric Dryer
  • Frigidaire Master
  • 43,501 Answers
Here is a tip that I wrote about dryers and noises...
It will help you determine what is happening there...
DryerSqueaking noise - 2_bing.gif Repair Squeaks, Grinding, Clicking and Knocking Noise
http://www.fixya.com/support/r4416566-dryer_repair_squeaks_grinding_clicking
heatman101
Asker's Testimonial " This should give me an ida of what to look for once I open er up " -
Posted on May 12, 2010
V6 engine knocking and squeaking noise
check for play in the distributor sometimes the slop will make the pick up window under the cap will hit the distributor cap , the squeaking noise may be your belt or tensioner pulley bearing the knock can also come from a bad tensioner as well .
Feb 16, 2014 | 1997 GMC Sierra
When i steer my 2003 mountaineer it makes a squeaking noise inside and a clicking noise outside
Not sure about the squeaking noise, possibly the rack-n-pinion or a dry seal. The clicking is a CV joint or joint in the steering system needing replaced.
Jul 06, 2011 | Mercury Mountaineer Cars & Trucks
Weird squeaking noise from under hood started from sitting an hour after being driven ,noise goes away when accelerating but comes back when not ,when parked noise is constant a type of squeaking noise
You should have your belts checked for proper tension. If they're squeaking when the engine is at a low RPM then they are most likely loose and need to be tightened. However, that squeak may also be an indication that one of the tensioners in the belt's line may be wearing down. If that is the case the tensioner will need to be replaced since the bearing inside is worn down beyond the point where lubrication would be useful.
Mar 05, 2011 | 1988 BMW 3 Series
When bringing car to a stop using the brakes I hear a squeaking noise I drive a 2007 pontiac vibe
Check to see if the brake pads are low. They might be low enough and the squealers may be touching. Which will make a squeaking noise. If they are not low you may have metallic brake pads that will also make a squeaking noise. If this is the case you can try disc brake quiet. This is a spray that you can get at most auto part stores.
I hope this helps!
Jul 23, 2010 | 2007 Pontiac Vibe
Squeaking noise in engine. not serpentine belt.
You might have a dry bearing in the alternator. I've had a squeaking noise from them.
May 15, 2010 | 2004 Chevrolet Silverado
Dryer making squeaking noise
Dryer2_bing.gif Repair Squeaks, Grinding, Clicking and Knocking Noise
heatman101
May 11, 2010 | Dryers
Intense squeaking noise
When microwave is running, turntable squeaking when rotating. Can problem be fixed? Microwave is about twelve years old.
Mar 07, 2010 | GE Spacemaker JVM1640SJ Microwave Oven
Squeaking noises
First check the brake pads , a worn out brake pads may create a squeaking and grinding noise, if its delayed then you need to change rotors the brakes,get check ....
Good luck...
Feb 03, 2009 | 1999 Ford Explorer
Makes loud squeaking noise, cuts off after a few minutes
Dryer Repair Squeaks, Grinding, Clicking and Knocking Noise
heatman101
bxx
Dec 02, 2008 | Maytag Neptune MCE8000AY Electric Dryer
Admiral Washing Machine Makes Squeaking Noise
THE BRAKE IS VERY FAMOUS FOR THAT NOISE NOT INSPECT THE PUMP ,, CAN BE GRINDING ON BOTTOM BASE OF WASHER ,, BEARING POPPED OUT
Nov 22, 2008 | Washing Machines
Frigidaire  Electric Dryer Logo
88 people viewed this question
Top Frigidaire Dryers Experts
Dan Webster
Dan Webster
Tim Whalen
Are you a Frigidaire Dryer Expert? Answer questions, earn points and help others
