Give me 4 sample problem solving using of for loops
  • 86 Answers
  1. Searching
  2. Sorting
  3. Updating arrays.
  4. Waiting until certain condition is meet.
Posted on May 16, 2010
When attempting to solve graphing equations GETTING graphing error says INVALID DIM
You're probably trying to graph a function that does not involve stat plot features. You can correct this by turning off the stat plot features. Press "2ND" "STAT PLOT" and then select 4:PlotsOff.
If this doesn't do it, please reply to this post and give a sample equation that causes this error.
Sep 09, 2011 | Texas Instruments TI-83 Plus Calculator
Hey there, i have an rc 50 and when i loop the first bit is cut off. was told that i dont need to update my spftware as its vers1.02 but was told to follow instructions on PDF to change some settings/ mode...
Make sure you start and terminate the sampling on the beat... otherwise when looped the thing can't "splice" the sample without clipping the sample to tie the start and finish together... and keep the rhythm.
You might want to review your manual regarding modes they may have that are more tolerant of the splicing of the sample.
Understanding the problem is half the solution!
Feb 24, 2011 | Boss Rc 50
How much space should i leave between loops on roof tape?
1st You must know that you can attach the heat tape by spiral wrapping, or by straight run (in- line with the pipe); held temporarily with a few pieces of tape. Of course you will need to apply an insulating wrap (in either case).
The straight run gives the least heat per foot but covers more pipe. The tighter (closer) the spiral wrap of the heat tape loops, the more heat per foot but the shorter the coverage. If the pipe is 1/2" or 3/4" DIAM. then a straight run is sufficient. If 1" to 1 1/4" then a very wide spiral. If 1 1/2 to 2" then a closer loop spiral. In no case should the loops touch each other nor be closer than 3/4" to each other. And avoid having the heat tape cross itself at valves, elbows, etc. PLease note that this is all based on winter temps of 0 degree F. or above and using normal 1" THICK WRAP INSULATION. If you have temps down to -30 or so, then give minimum 2" thick insulation.
Good Luck Macgivor.
Nov 27, 2010 | Easy Heat Water Pipe Heating Cable
Looping
you need to lower the loop volume for it is taking a small sample every time you loop.
Feb 11, 2010 | Korg Mini Kp Kaoss Pad
When i open remote management showing a error message''error:1004'' please help me to solve this problem.
his problem can occur when you give the workbook a defined name and then copy the worksheet several times without first saving and closing the workbook, as in the following sample code: Sub CopySheetTest() Dim iTemp As Integer Dim oBook As Workbook Dim iCounter As Integer ' Create a new blank workbook: iTemp = Application.SheetsInNewWorkbook Application.SheetsInNewWorkbook = 1 Set oBook = Application.Workbooks.Add Application.SheetsInNewWorkbook = iTemp ' Add a defined name to the workbook ' that RefersTo a range: oBook.Names.Add Name:="tempRange", _ RefersTo:="=Sheet1!$A$1" ' Save the workbook: oBook.SaveAs "c:\test2.xls" ' Copy the sheet in a loop. Eventually, ' you get error 1004: Copy Method of ' Worksheet class failed. For iCounter = 1 To 275 oBook.Worksheets(1).Copy After:=oBook.Worksheets(1) Next End Sub
Nov 18, 2009 | Computers & Internet
Zebra lp2844 printing incorrectly with paypal multi order
Same here... Can't be the printer - has to be something with either the paypal software or the driver since my 'SAMPLE' prints solid as well. Did you ever find a solution?
Oct 15, 2009 | Zebra LP 2844 Thermal Printer
Hey how come i cant use my loop features on my cdj800 with my serato?
It's the limitations of Serato. Because it's sampling in real-time, the signal cannot be manipulated by the CDJ800. Sorry, there is no way around this. Talk to Serato about this.
- OPTiC
DJ Equipment Repair Videos
DJ Equipment Repair
DJ Equipment Sales
Pioneer Parts
Jan 15, 2009 | Pioneer CDJ-800 Turntable
Hi i want to ask you something bout c++ programing language
http://en.wikipedia.org/wiki/History_of_programming_languages
The above is a link to wikipedia.It has almost all the history required and sample programs.Please do rate if the problem is solved.
Sep 10, 2008 | Computers & Internet
MPC 500 PROBLEM!!
you need to set your Parameters Params and make sure the you set enough bars for the sample.. if it cuts out you could try hitting the track button and putting the drums on track 2
Mar 15, 2008 | Audio Players & Recorders
Computers & Internet Logo
56 people viewed this question
David Payne
David Payne
